Everything posted by PeterW
Choice of Pex-Al and Pert-Al at Wunda
Not unusual. From memory the door sizes and garage sizes haven’t changed in decades, and most developers don’t expect you to put a car in the garage - it’s for bikes, junk etc ..! I think the standard size is based around a Ford Prefect or something similar ..??
choice of material for foundation insulation
PeterW replied to scottishjohn's topic in Heat Insulation
PIR and PUR both absorb moisture and are not certified for permanent damp conditions. -
Can you show how you get to that figure ..???
Insulating under block and beam floor with perlite
PeterW replied to Patrick's topic in Heat Insulation
Polystyrene beads..?? It’s been discussed before !- 35 replies
Elevation, Elevation, Elevation
PeterW replied to Triassic's topic in Environmental Building Politics
Nice tool here that may help you make decisions http://www.floodmap.net/ -
How to clean textured floor tiles
PeterW replied to Ferdinand's topic in General Self Build & DIY Discussion
Steam mops are always pretty good for this. -
Looks like that manhole has seen better days .!!!
Thicknesses of insulation available to fine-tune FFL
PeterW replied to epsilonGreedy's topic in Heat Insulation
Yep - 50mm of EPS, then a DPM and 110mm of PIR and you will be fine. EPS is relatively cheap and will also stop any DPM getting punctured. PIR takes UFH staples much better than anything else. -
Got a photo of the inside of the manhole ..?? I’d reckon there is a 150mm clay section in the bottom of it. The “proper” way isn’t going to work so I would do the following Get a clay to UPVC connector and cut it just after the UPVC sleeve. Slide this onto your UPVC (Easier with a short section - 7-800mm will do, preferably with a socket on) the “wrong way round” so the open wider clay end faces out of the manhole. Bevel the end of the UPVC to 45 degrees and slide the whole thing into the manhole so you have 150-200mm inside the manhole, but not past the next branch. Now force the rubber back inside the clay from the outside, making sure it goes in all the way round - long screwdriver is good for this ..!! Set your levels so this short section has a 1:40 or less into the manhole and then fill round the pipe and the first 3-400mm with a semi dry concrete mix ( use Rapid Set or even post mix here) Once this is set, bench the inside of the manhole - don’t use rapid on the inside, use a 3:1 sand cement mortar and make sure it’s all nice and smooth and tidy...
As @JSHarris said - pitch fibre. They delaminate and deform over time. Get them all out and replaced as they are a nightmare to get a decent connection on to, and invariably collapse as soon as you mess with them. That hasn’t been bedded properly either so it’s probably unstable now you’ve exposed it.
125mm non-standard bends?
PeterW replied to phatboy's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Make one ..?? Have you got a length of 125mm pipe..? Cut the pipe at 20 degrees, rotate it 180 degrees and glue them together - gives you your 40 degree elbow. If you then smear with CT1 and tape with decent foil tape it will be fine. -
Yes you can over drill the core for a joint - you’ll need a 125mm core drill.
Can also use a Sonoff TH to do this - benefit is you can control via ITTT or the app. Here is the site
I’ve got rid of my rods and use one of these on the pressure washer. Drain Jet It will blast blast it’s way through the worst blockages and is also flexible enough when soaked in a bucket of hot water for 10 mins to go round a u bend ...
Blocks to 2.4m high before the facing bricks, gotchas?
PeterW replied to epsilonGreedy's topic in Brick & Block
Yep -
Ties may not be in line with joints perfectly but a tap down with a trowel sorts this. Never knock up, at worst give them a twist and put them in the perp if you have to. Are you insulating the cavity ..? -
Congratulations..!! Must mean the bathroom is finished ..???
Kwikstage scaffolding questions
PeterW replied to Vijay's topic in General Self Build & DIY Discussion
No it’s the right way ..! Got the clips ..?? -
Yes - it’s called Newton’s Law of Thermodynamics .... Just to advise, until there is some solid technical and accredited research shown by @Clive Osborne regarding Nexgen then please can we leave this thread as is.
Its because it isn’t hot. Thermostatic valves need a temperature differential to operate - it’s locking down the flow because there is no hot water to open the wax cap.
- 7 replies
- thermal store
- pressure
Yes - specify Ultion locks now, and they have a £1000 excess guarantee on them too. Some clever bits inside, and keys are incredibly difficult to copy. Not cheap but worth it. https://www.ultion-lock.co.uk/
Readymade 1/4 blocks? Getting fed up cutting.
Yep - concrete commons are available. -
HELP.. OUR VELFAC APPROVED WINDOW INSTALLER HAS GONE BUMP
PeterW replied to laurenco's topic in Windows & Glazing
Interesting as Aluforms director used to be the Ops Director of Velfac... I would push them hard to help you here ..! https://beta.companieshouse.gov.uk/officers/kCCZuqYUPmpgbqj_hbBUxX3OfI0/appointments- 28 replies
