Everything posted by PeterW
Roof Slates weird after Velux installation... ???
PeterW replied to Repsac's topic in Roofing, Tiling & Slating
Is this sarking board or battens under the slates ..?? -
How have they refitted the slates as these two are upside down ....! Look at the nail holes in the circled slates. -
Fan Coil Units for use with a (cooling) ASHP
PeterW replied to ProDave's topic in Air Source Heat Pumps (ASHP)
Or one of these https://www.spillhut.com/35ltr-flexi-generator-drip-tray-pan-d-70cm-x-52cm-x-10cm-ftpn1 -
Quickest way is a plastic tea tray sat under it as a condensate tray with a plastic tank fitting glued to a hole in the tray for the output. -
Yep they do - quite detailed too
- 64 replies
- aur cniditioner
- aircon
(and 2 more)
Or this https://www.ebay.co.uk/i/192460320123 -
You need to look for a water heat battery should be £80-150 -
Unico Units are really nice - manufactured in Italy, and are very neat at 16cm thick. https://www.olimpiasplendid.com/download_area?name=Air Conditioners Without Outdoor Unit&id=1105
- 64 replies
- aur cniditioner
- aircon
(and 2 more)
+1 to this. Recent temperatures have meant that a recent one I did that has 150mm of blown bead in the walls plus 25mm of PUR internally has stayed at a really cool 22c max with no MVHR running. Roof insulation is 200mm of Earthwool plus 25/50mm of PUR and again, its room in roof and has stayed cool. Over the winter, the heating cost via ASHP and UFH was around £40/month.
Earth bonding Copper incoming mains with all plastic internal plumbing
PeterW replied to Jody's topic in General Plumbing
Don't do it... I would leave that stopcock alone, and then clean off the pipe above it with some fine emery paper and add in a full bore lever ball valve. Use that as your isolator, and leave the existing well alone. -
Fencing not obligatory - but worth it ...!! Stops you falling in a ditch or a wagon reversing into your footings (ask me how I know....) Sign in book is especially useful if you have trades on a day rate to validate invoices.
Before anyone gets excited about CDM you probably need to read this thread ...
Hire one ..? Local place to me is £30 for a weekend to get to that height
Got a couple of nice Timloc vents that have the required flow rate that I can let you have for a reasonable price ... ?
I checked with FastenMaster a few years back and the standard black are fine - I’ve had some in for 10 years and they are still holding well.
I use the Timberlok screws for this but use a corded SDS drill as neither my impact or other driver gets them more than 2/3rds in. Happy with my 152 - it’s been heavily used and still going strong.
Aren’t the efficiencies on these only 3-5% versus 19% for standard panels..??
You need one of These
Non-Standard Front Door & Glazed Sidelight....?
PeterW replied to Rob99's topic in Doors & Door Frames
Here -
So this is a composite UPVC with a low profile threshold, Ultion high security locks and black outside / white inside. £1450 inc VAT..... I’d say your frame is chunkier than mine ... -
Geberit is head and shoulders above the rest - you’ve struck unlucky as you’ve been provided with a non-UK part as your shower tray supplier isn’t giving you the right info....
Wedge some timber or ply shims behind them and nut them up tight.
Manufacturers Instructions. Some of the syphon type shower wastes need a minimum distance before a bend to keep the water flowing and draw it out of the waste
Discount Offers of the Week
PeterW replied to Ferdinand's topic in General Self Build & DIY Discussion
Toolstation have an offer on twin pack of Stanley tape measures - works out as buy the 8m and get the 5m free. https://www.toolstation.com/stanley-tylon-tape-measure/p34472
