Everything posted by PeterW
Got a photo of the outlet from the box gutter ..?? Could possibly do some diversion on it. How many downpipes on the main run of gutter that is overflowing ..?? And what’s it made of ..? No need to replace everything just yet - always ways of making this work ..!!
See this a lot. Is there a shoe on the other downpipe or gutter that is causing the overflow ..?? Turn it at about 60 degrees to the roof so it casts the water sideways. Should slow the flow down.
Measure just the heater area and not under the wC pan..!! 50mm from the edge is fine.
Can you not make the plate 150..???
Stagger them alternate 50mm from each edge - I think this is stronger anyway.
Welcome ..! That’s a fabulous space ..! Ask away, I’m sure there should be someone who can help.
Because they are difficult to explain and expensive to produce ..! They are also a little more fragile than standard heat exchangers.
One of the other reasons to fill it with water and cap off is it makes it much harder to crush.
Sonoff TH10 would do it, which is more automated than a stand alone unit such as this one which just switches on and off by the relative humidity. You may prefer this as I know you like to keep your house slightly more humid.
You want automated humidity detecting @lizzie ..? @JSHarris has a very simplified system that uses a Chinese humidity switch to boost the unit at the manifold detection level.
Yep... the reason is because humidity varies and you can’t have a “standard” humidity at which to boost. Most people have used motion systems or just a link to a light switch is enough to make it boost when it is needed. Its about simplicity ....!
building a house....with future extension in mind
PeterW replied to Amateur bob's topic in Introduce Yourself
Only for a new build, not for an extension. All work after completion and a single VAT claim is VAT rateable at the correct rate. -
Microwave detectors are fine for garages. They are pretty immune to drafts and you can get some nice ceiling mounted central ones that cover a decent area.
So that 357 weighs nearly half a tonne... and the post detail is odd as the whole of the 203 is hanging on 4 bolts. The other odd bit is the post also only has 2 bolts..?? Should be 4, 2 each flange.
Two steels is the answer - sorry ..! Engineer who designed that wants a slap, and has completely ignored the lateral forces of the two different pitches. Also, the 356 has been chosen for the deflection over the span, as the intermediate is the same size. What is the total span of the open space as there looks to be intermediate walls in that design..?? Ridge board, steels around 7-800mm down from the ridge apex and stick decent ceiling binders in as that is one very odd roof design ..! Have you got the engineers sections to show what they think it will look like on the posts too..??
Yikes that’s expensive ..!!!! 200w/Sqm with digital programmable thermostat for less than £70 Here Good guys too - easy to fit and reliable.
Make sure you have your dump point and washout sorted. He will want to empty everything , and a mixer truck on full chat fills a barrow in less than the time it takes to say “oh fc*k where is the other wheelbarrow.....” Also, make sure you know where you want him to wash out, and it’s not into the skip....
Bringing a derelict UFH system into service.
PeterW replied to daiking's topic in Underfloor Heating
Sink In a 500mm is fine. Is the manifold fitted as you’re talking a 4 port manifold not 8, as they count as pairs. A manifold is probably 300mm wide, pump will add another 150-180mm so will be very tight in a 500mm cupboard. -
Discount Offers of the Week
PeterW replied to Ferdinand's topic in General Self Build & DIY Discussion
They never go for that. Every large building starts at £100 but ends around the £3-5k mark. They also have high buyer premiums and VAT to add -
Fold it. Pull the long edge taut, toe in the corner and take up the slack. Should allow you now to pull the middle up, then fold the excess over to the side like a reverse hospital corner and tape it you want
Are countertop basins use or ornament?
PeterW replied to Ferdinand's topic in Bathrooms, Ensuites & Wetrooms
Got one and love it. It’s set on a solid wood base, been there 8 years and no issue. Tap is a John Lewis tower mixer, works perfectly. Overflow is in the back of it, nice and simple. There is a 65mm hole through the 3” oak plinth, that was a bugger to cut..!! It bedded on white Unibond Sealant and hasn’t moved unless I’ve cut it off (to properly sand the plinth. -
VAT rise on PV systems coming
PeterW replied to MikeSharp01's topic in General Self Build & DIY Discussion
Why do you think I have a clean licence *......?? ? *it is actually due to my driving and no other reason ..!!! -
Yeh and my mate who is a traffic officer said they are now on the lookout for older vehicles ...!! No tax or MoT required, and a few are forgetting insurance ... Number of unsafe vehicles they pull is rising too - oddly newer ones and usually tyres these days. -
Just a thought if you haven't already done this - you could always hole saw a hole in the correct place to allow you to pull the tube and then just screw a plate on the outside to cover the hole..?
