Oz07
Everything posted by Oz07
It has just occurred to me why do we commonly sit FFL's 150mm above floor level just because DPC is at this level? Is there a reason we don't use have outside dpc higher than inside especially in cavity wall construction? Is this not what we invariably do anyway around the level access opening? Also is this why bottom of timber frames are not level with FFL so no timber in splash zone at level access? Your never going to get the bottom of a suspended floor anywhere near ground level without house sitting 600mm high once beams insulation and screed is accounted for. Excuse me if i'm being stupid it just occurred to me every house seems to be 6" above ground, even when no local risk of flooding.
My god how bad are the walls you lot are fixing to! I've got some acrow props you can use between walls if they're that bad
Photos be nice!
Maybe planning consultant rather than architect in first instance. Should be able to get free consultation with a few and look at strategies from there
Will it not have weathered more consistently in a year or two?
Sorry to be of no help. How much meterage was this 34k?!
From my experience the thinner liquid screed performed better in terms of resisting cracking than the thicker concrete. I don't know the science behind it thought perhaps someone else does? Flexibility perhaps?
Was suprised at just how strong these screeds are. The flow is superb aswell. I usually use agilia which is good no nonsense stuff however susceptible to cracking if movement joints not in asap. Lafarge do one of these thin screeds when I worked on a job with it was tuff stuff. Only 50mm thick you'd think it would crack everywhere but very strong.
2017 What worked and what didn't
Oz07 replied to SteamyTea's topic in General Self Build & DIY Discussion
Didn't work - appendix worked - having it removed! 17 been crap in health and business but few irons in the fire already for next year and feeling good. -
Land liability, the world truly has gone mad! enjoying watching vikings and observing a more survival of the fittest approach to civilisation!
Not ideal for new builds but perfect for older tenanted properties as @Ferdinand says
Is it not designed to push air out of trickle vents?
Is the floor a click or glue system? Presume it's floating of underlay been mentioned
January Sales - Bargains to be had?
Oz07 replied to Barney12's topic in General Self Build & DIY Discussion
Apparently new cars as 2017 been a slow year - sorry that doesn't help your cause! Howdens October sale, but like you say not really sure it's much cheaper -
New Build Warranty ...recommendations? / warnings?
Oz07 replied to Ed_MK's topic in New House & Structural Warranties
I literally have the CML extract on my computer listing the lenders who accept PCC. Who told you most lenders don't accept it? Did you do any of your own research or just accept that persons word for it? Sold a couple of new with PCC, both mortgaged, both times wasn't an issue. -
Unreal that isn't it! -
Does make it harder to paint afterwards though! @jamiehamy started reading your blog earlier quite interesting project!
The point is that majority of lenders accept pcc. Fair enough if you can justify inflated cost of a warranty by avoiding a cil payment. As @JSHarris questions though I am also sceptical. I would think there are other ways to prove self build than taking out a product which is specifically designed to aid selling the property! I've always gone pcc for the fact I'd be prepared to tell any future buyer to switch lenders. Others may not be so assertive? -
Hopefully job isn't under too much pressure. Seen many a job get bodged and rushed at the end due to tight deadlines. Just think of it as an adventure you will be laughing about it next christmas!
They will usually supply some rigid duct. As for getting in touch with them it requires some serious googling
- 58 replies
- pumping station
- sewage
(and 3 more)
Get spec from them beforehand and they should be fine. Nowt worse than putting a unperforated duct in and gas board turning up and asking for perforated! Ask me how I know. Also diameter of duct is important
- 58 replies
- pumping station
- sewage
(and 3 more)
Can we stop perpetuating the myth that you NEED a warranty. I've got a CML list on my computer of all the different lenders requirements. I would estimate 80% accept Professional Consultants Cert, some wanting this also to be supervised by RIBA architect. The remaining want warranties but mostly LABC or NHBC. The lenders which will accept warranties by companies other than these are surprisingly few and therefore makes you question the value of getting a warranty over the usually cheaper PCC if not using the 'big two'!
