Oz07
    6
Everything posted by Oz07
  1. I thought these had already been done by someone or is this an innovation? The integrated units don't look bad anyway. How serviceable and easy to install will these be?
  2. Who's bothered about how much damage the fire brigade do, that's what insurance is for!
  3. 1:60 is fine with good workmanship on 110mm. I've just gone 1:80 on a job to keep it low as you say. I've never used solvent weld underground so couldn't comment. If you did ever have a leak though don't forget they repair them from inside the pipe this day and age!
  4. If you're going to test do it in stages. Don't want to put all your drains in and not know where a leak is. I normally just put a Bing in at start and put a bend on where I want to test to. Fill with water. Think you're actually allowed a not insignificant amount of leakage depending on surface area of run. I've never really seen the level drop on PVC systems
  5. Suppose low expansion would be key to it working well. Wouldn't want to come back to a wall for all the boards to be 10mm out at the top! when doing a ribbon bead I genuinely find that the gear fills up the space
  6. Yeh look up egger p5 online OP. Looks like it has been used with right glue aswell. There are 2 types 1 with film as said above but both are waterproof. Give it a good scrape down now. Run your planer or sand any joints which you feel are protruding excessively. I'd of thought it will be ok.
  7. Looks like egger protect to me? your flooring isn't sagging it's your joints swelling. Sand back before carpeting if worried about feeling thru. This egger is garunteed weather proof for about 4 weeks
  8. how do you get foam in heads if you're boarding upto ceiling?
  9. Any ptfe tape or paste? I'm hopeless with plumbing even with that mdpe and those easy fittings which are like mecano
  10. I've seen them closer to new values in good nick. The trick is buying second hand. Have moved mine about 3 times now myself. I suppose this is where I'm seeing the value
  11. Are you kidding the expandastore hold really good money as transport can be diy. I got mine pretty cheap but you try finding a secondhand one. Let alone at a big discount from new
  12. Why are 2 professionals asking the customer how to achieve the customers goal?!
  13. the kitchen in my house has 6"pir, cross bonded and installed reasonably well. Why does the tiled surface feel cold. I know its something to do with relativity BUT I wonder if it would feel cooler with only 4", or 2" of PIR?! I know the science says it shouldn't, but I can't comprehend.
  14. Has anyone seen the door undercut thread on GBF? Just highlights the point Sensus was making
  15. Not something you want to hear at that stage it's going to mess your floor makeup up as ideally you want insulation and screed above this.
  16. Yeh it's called recession. Mate currently building out a site bought around 2010 for less than 10%gdv
  17. I got that loft condensation in a house I built. Exactly like you say customer wasn't happy about their 3tonne of possessions up there getting wet. Was just forming on the north elevation underside of breathable roofing felt and trusses. it was ventilated both sides at eaves level but we went back and put 3/4 vent tiles up high on the cold side and it managed to sort it.
  18. I try to go for dpc just makes life easier for seeing where the building will sit in relation to ground sometimes if far enough away you can leave I'm and measure off when you come to landscape. I suppose that string method sounds fine. Whatever works for you I often check the diagonals once I've got 4 square lines up anyway. As has been said 10mm in 10-20metres will be fine. Could be slack in the tape
  19. Elec tape on strings is your friend when using pythagorous or 345 to check square
  20. Looks a lot better than before. Better overhangs now. Not sure central pillar is nessecary as looks to be ridge board not ridge beam. Won't do any harm though. Usually use straps which span 3 rafters on newbuild. You should probably just add some solid noggins behind those straps to be 100% although doubt it will go anywhere now.
  21. Dug up a lead main at about 400mm in the week. Sure insulation down to 750 be ok
  22. Drop is about 2.7 metres plus 300mm along ceiling if you would like to tell me difference between 15mm and 22mm
  23. These pipes come thru ceiling of an entry, down an external wall, and back into the house at close to ground level. Yes hot and cold to downstairs wc This pipe work will be external and down an external wall but in a entry between 2 properties. No other route for various reasons. Intetesting comment re 22mm pipe. I'm thinking belt n braces for the small cost of 6m of trace kit as electrician has work to do anyway may be just better off using this. No problems re clipping pipe then
  24. Thanks. Like others have have said would show the partition in build control drawings
