dpmiller
    4
Everything posted by dpmiller
  1. if it's a signal-level circuit, I'd not be doing questionable crimps...
  2. Wire the dimmer through the switch so using the lights forces the fan?
  3. concrete's cheaper than tarmac, according to local tarmac guy...
  4. looks like the blue pallet is an extra. The ASHPs come in a bespoke ply crate
  5. but knowing B&Q they've found a way to cheapen those batteries. 5Ah maybe, but crappy cells that will only power smaller devices perhaps...
  6. there's another (slightly risky) option- take a mallet to the top of the tank and drop it an inch...
  7. is the power supply built into the back bit?
  8. Yep, but the flexible stuff used in the radial systems is smooth bore too...
  9. ^ wot they all said. Hi from Ards...
  10. Anything will do, it's going into a thermopocket and there are no response or max temp considerations.
  11. what 18mm system is it? 16mm is more common...
  12. the end-point is adjustable, to set what depth the nail head stops at, but the power (the dose of gas) is fixed on the 350, not sure about the latest one.
  13. Our screed installers had a fancy foam strip with a self-adhesive foot, easy to notch over pipes etc.
  14. I've used some of their products and they're good.
  15. Was this particular AroTHERM split or monobloc? Anything with an indoor Hydrobox is going to take more space, and some units may be less reliant on a buffer tank, depending on your particular system design, temperatures, and volume.
  16. I'd close the cavity with PIR/ compacfoam then use straightish brackets onto the edge of the inner leaf.
  17. tray or wetroom former?
  18. FCUs, like 13A plug tops, don't like running continuously at 13A...
  19. He's having a laugh. He looks like he's comparing to one of them rotary jobbies with the motor in the sh*te, but even at that... Air blower units only use about 50W, and the blower often doesn't run 24/7
  20. Inside the outdoor unit?
  21. surely in the grand scheme of things the design and commissioning of some ductwork (and the VAT on it) is an almost-irrelevant cost? And you could commission it yourself if you wanted to, as well...
  22. Hang on, is your patio a RoW, or is there laneway/back entry/street behind it?
  23. Cordless drill, length of stud iron, bits of timber etc, you can do it if you need to
  24. Our Howdens order had neither missings nor odds.
