Griggs timber Gloucestershire. I went back and fourth altering things and it was never a problem. My joists where too long for a ridged truck so neede an artic, I told them I could not get an artic on site, so they borrowed a longer ridged and delivered them. Perfect service.
Your dimensions of steel will be in the BAR BENDING SCHEDULE this is produced by the engineer, you send it to the steel stockholders and they produce a quote for you. £7-9 grand I would just pay it, the time you pay for all the separate elements you will be lucky to save £1500 for weeks of agro. Foundations is not a place for you for you to try and make savings. Fitting plasterboard, door linings doors, skirting and painting are the things you can do unless you have done it before. now im all for everyone having a go, I did all my own steel work and ringbeam and saved £5000 but I’ve been involved in the building game for nearly 40 years. What about drainage, do you have drainage going under the raft?
Look at the YouTube vids of it. But make sure you are happy your roof is vented correctly.
But how do you take the blender out if you have a full pipe. I think I would fit a 40mm full bore gate valve so I could fully isolate the vertical run.
Gap between fence and house
Russell griffiths replied to arvid309109's topic in New House & Self Build Design
1m gap 5m house 1m gap. Does it have planning. -
Sensible question now. If your poo soup is rising vertically, do you have a one way valve or something just after the poo blender. If the poo blender suddenly stopped, would you not have a 2.5m high pipe full of poo soup so you cannot disconnect the blender.
Sitting here bored tonight I thought I would do some research for you @pocster after a couple of hours of thought I think I have sorted out your problem. I did consult @Nickfromwales on his views but he was a bit drunk, so not much help. Hope this is of help, if not pease contact customer service on 1-800 couldn’t give a shit dot com. Your welcome.
Griggs timber, Gloucestershire.
I haven’t used them but I did get a quote of pasquil and it was 25% dearer than the company I used.
ICF Opening Spans Achievable
Russell griffiths replied to Brian Ireland's topic in Insulated Concrete Formwork (ICF)
I don’t think the width is as important as the depth, it’s the depth of a beam that provides most of the strength. I have a steel beam holding up my roof roof that is something like 147mm wide but 450mm deep. -
Taping Kingspan K103 insulation floor boards?
Russell griffiths replied to revelation's topic in Heat Insulation
1200gauge, what’s that for ? have you got a dpm under the insulation? the membrane that goes on top is just very thin polythene it’s not a dpm buy the thinnest clear polythene, then you can see your kingspan as you staple it, avoids trying to put a staple in a join and them pulling out. As @ADLIan said what does it say on kingspan site. I would try try to do two layers not one then you can stagger joins. -
My personal opinion is you have no chance whatsoever. Of getting that at the back. Why not build the workshop at the side, two beds above it and kitchen diner around the back. Its a fairly standard thing, so planners are familiar with it, ask for something rather unconventional and you make them twitch and start looking at reasons to refuse. Has anybody done this rear rear extension near you.
Are you putting a thin membrane over the top to stop screed getting in the gaps. Is it liquid screed or traditional ? -
What’s wrong with two storey at the side and a single at the back. Its called a wrap around, it’s a good solution as it replaces over half of your previous external walls with new better constructed walls. Large open plan kitchen diner at the back, couple of rooflights in it, will bring it kicking and screaming into 2021.
How many times can you alter things before they get the hump, I want some done to look at my cladding design, but I want two or three versions.
Who is fitting the rockwool? having just worked on a house with rockwool fitted between the rafters I would safely say it is the nastiest building product you will come across. I would look at alternatives. I brought a few different manufacturers insulation just to test fit and found Knauf omnifit to be the nicest to use.
I doubt you will get a double storey rear extension. Show us a couple of pics, we will soon have 367 different opinions, but you did ask.
Sorry, another realistic build costs post!
Russell griffiths replied to dawsonhousehold's topic in Costing & Estimating
Probably going to sound rude, but it’s not meant like that. £425,000 is south of Birmingham prices, for that price up there it must be a cracking plot in a cracking area. So probably demands a super house built on it. 5 beds 3 baths, downstairs cloak and shower, home office, utility room, 3 car garage. So you are probably under developing it. If this is the case then you can forget the standard figures. You need to build it for you not for anybody else. Alternatively you need to build the better house but think of it as long term investment. Finish off all in for £875,000 but you have a million pound house. When the kids sod off sell up and build a smaller one. I have a friend building a huge mansion of a place, just as his kids are off to university, but he’s doing it to sell on in ten years time. -
German fancy kitchens
Russell griffiths replied to Russell griffiths's topic in Kitchen Units & Worktops
It baffles me how my Howdens bills have an 80% discount from catalogue price. -
No it’s a service batten to run pipes and cables through.
Start breaking it down in your head, we used to pay £600 a day for traffic management for lights and signage for a single lane closure.
You still need insulation on the inside to mitigate against the cold bridges through the studs, just fitting 140 between studs does not make a good wall build up.
Plastic eaves support tray is 2-3mm thick not 25mm. As I believe you said no vents on top of facia.
Foul drainage across root protection zone
Russell griffiths replied to WWilts's topic in Waste & Sewerage
As gus said, do you have an arborists doing a method statement for you on how this should be done, or are the council not aware you are going down this route.
