Careful measurements. You will need to know the exact floor finish, what this floor finish is fixed down with etc etc, you then mark FFL on the wall and fit doors to match that. Easier to do if your tiling as you can alter adhesive under tiles a little bit. Also better to be low with the screed as it’s easy to bring the screed up 3-4mm with a floor leveller than it is if you are too high. So I would side with caution and go 4-5mm low and allow for a few mm of wiggle room.
I thought of this a couple of years ago and Jeremy Harris ran some numbers and said it wasn’t a problem, as the ground the piles are in isn’t actually that cold as it’s all under the eps and the piles are surrounded in soil. Its a bit like why does your water main not freeze underground, it’s actually not cold down there, it’s cold bridges coming from above ground that are more a problem.
Just think if you don’t use a raft you are definitely piling anyway. So might as well start looking into them.
Have you chosen your windows yet, I would look at some pdf files of the windows to look at the section on drainage and cill installation.
you can pile under an insulated raft. Theres a few on here who have done it.
Now you just need to move that bloody heavy door.
@WWilts I think the confusion is your drawing wasn’t clear, it looks like you have just drawn orange lines and not stopped at the walls. If you mark it up with rodding eyes on the end then that looks like a much better idea. Has your architect done you drawings with layers that that can be removed, that way you can have a drainage plan without all the other junk clouding peoples view.
Gabion Basket Recommendation
Russell griffiths replied to Triassic's topic in Landscaping, Decking & Patios
That’s good, they won’t be cheap. -
I don’t think quality and price are two things you can associate with each other. -
Wait for someone to ask before you throw yourself under the bus.
- 5 replies
- wac
- planning permission
How to pick a toilet remotely?
Russell griffiths replied to Adsibob's topic in Bathrooms, Ensuites & Wetrooms
@Adsibob it was pointed out to me that you need to look at frame height in relation to the push plate in relation to tile height. So it would be wrong to have half height tiles in a bathroom and the flush plate was half on and half of the tiles. More things to think about. -
UFH under 150mm screed with mesh reinforcement.
Russell griffiths replied to Matt60's topic in Underfloor Heating
Not fitted the tiles yet, but lots of American garages have them, I’m definitely looking at the tough polypropylene type not the foam ones. -
Drop the thickness to 100mm of c35 concrete on the mesh he suggests. Unless you are going to park a boeing 747 in there. This is standard spec for an insulated raft for the main house, obviously thicker at the edges to take wall loads, but thicker than 100 is not needed to park a car on. You are maintaining a drop in height from house to garage I presume. Just done mine, 100mm concrete with mesh, self levelling compound, interlocking plastic/ rubber floor tiles, no ufh. You need to forget screed and think concrete. -
Help with abutment gutter
Russell griffiths replied to James94's topic in General Self Build & DIY Discussion
Yes like this, have it all folded up neatly then take it to get it welded. If it’s too much agro to get somebody out. -
Hello! Renovation & extension project - scary!
Russell griffiths replied to LizG Cambridge's topic in Introduce Yourself
I like the wooden box they made to hide the pipework.- 2 replies
- self-build
- extension
Who did the stepped flashing, that bloke should know the answer it looks nice and tidy. I think that junction will be impossible without a bit of welding. I take it your osb box box will be extending up under the slates. -
Ok cool, just check it comes under new build and not renovation or conversion.
@Tim2021 I’m a bit confused as to why you are wanting to involve building control, and what your thoughts are with the vat. Why would building control be interested in a garden wall, unless it is on the boundary and likely to fall on a passing pedestrian. If you are trying to get building control involved to get the vat back then what vat do you think you can claim. If your build is a renovation then I believe your vat is rated at 5% I could well be wrong, in which case your talking £50 on a £1000 wall. Is this worth the agro of involving bc. ?♂️
Project: Bin the Conservatory
Russell griffiths replied to PeterTweeter's topic in Introduce Yourself
No I meant with a camera ?? -
Pictures. -
So @PeterW what’s been the problem with the silo stuff.
What’s all the problems the mass builders are having with mortar joints all falling out. Was it just a bad batch or are they specifically getting weaker mix to save money.
Seamed metal roofing or catnic SSR2 advice required
Russell griffiths replied to ruggers's topic in Roofing, Tiling & Slating
@Dunny1234, you need to stick to your roof manufacturers approved method if you want a warranty. As to which is best, that’s up to you to decide. You need to do your own research and pick which you think is best. Every manufacturer will say his is the best. -
Help needed!!!
Russell griffiths replied to Mulberry View's topic in General Self Build & DIY Discussion
Apart from design costs I think build cost difference will be so small it’s not worth worrying about. I would build the second option, but I would also do the same with the other corner that is indented. -
We do method B.
