Seamed metal roofing or catnic SSR2 advice required
Russell griffiths replied to ruggers's topic in Roofing, Tiling & Slating
The different types of buildup will have a major effect on other aspects of the build, having 150mm plus of insulation on top of your rafters will make finished heights higher. So needs thinking about quickly. -
Foul drainage across root protection zone
Russell griffiths replied to WWilts's topic in Waste & Sewerage
Can you not go around it, if it’s a pumped system it’s not relying on gravity so making the run longer shouldn’t be a problem. -
Bit late now, you can sit your soffit on top of your last course of bricks, this saves you having to cut soffit and creates a nice edge. I would do a bit of mocking up, grab half a dozen metre lengths of batten and batten out the first 4-5 rows of slates. Allowing for any detail courses at the eaves, you will soon see how high the facia needs to be buy the way the slates sit, then get a gutter bracket and some soffit, after two hours of messing you will have a better idea.
ICF Opening Spans Achievable
Russell griffiths replied to Brian Ireland's topic in Insulated Concrete Formwork (ICF)
if you look at the three windows up high, when I asked the engineer to design the steel for this I told him I hadn’t made my mind up on window sizes, so the columns between the windows might change, so he designed it so that no columns where actually needed. So in-effect all three of those windows could be one, which would put the opening at something like 5.8m. -
I have been very impressed with our icf system and how it allowed me to make cantilevered sections. -
I have a few big openings, 5.3m all done in icf with reinforcement in the concrete, I suggested to my engineer about installing a rsj into the core of the icf, he really didn’t like that idea and said you cannot get good consolidation of the concrete around the steel especially in the web. So you would need to make sure the steel is doing the job on its without the concrete assisting it. All mine where 12 and 16mm bars with links every 150mm, very fiddly to tie up as you needed hands like a 5 year old to get in between all the steel. -
Alarm system
Russell griffiths replied to Russell griffiths's topic in Networks, AV, Security & Automation
It depends if they find the body. -
Trusses against brick wall
Russell griffiths replied to MortarThePoint's topic in Roofing, Tiling & Slating
Can anybody recommend an alarm system. Looking for something that will ring a mobile number as well as make a load of noise, I have very good neighbours that would come over to have a look. Hopefully with a gun over his shoulder.
You generally fit them with an angle grinder instead of drilling out the mortar. Get the hangers that also have flanges on the sides to take bolts. Draw a straight line across the wall and do a series of deep grooves the thickness of the cutter blade, you will find the flange on the hanger is about the same thickness 2-3mm, hammer in the hanger with a club hammer, when all plumb and lovely add a bolt to each side flange. -
Large Vaulted Ceiling Insulation Thickness?
Russell griffiths replied to ashthekid's topic in Heat Insulation
Definitely no sunken spot lights, there is no need with the amount of flat led lights available. 25-40mm service batten and you will get a multitude of lights to fit in that. -
Out door kitchen sounds fun. Get Dutch oven and you will be able to burn all the old pallets and off cuts.
Church Conversion Novices.....help!
Russell griffiths replied to ClaireJonny's topic in Introduce Yourself
Looks fairly solid, will you have to deal with archeology surveys and stuff. -
Frame compression in settlement - what to expect
Russell griffiths replied to Haku's topic in Timber Frame
If you are doing a lot of the work yourself, many problems will go away naturally as you will have an increased length of time between jobs. So between frame up and internal plasterboarding could be 6 months to a year, this will allow stuff to settle and dry. A lot of problems occur because follow on trades are rushing to get their bit done. -
Not really understanding the problem, is it not a case of a longer screw 130mm x 6 mm through the battens, through the insulation, into the i joists.
Our window company would not supply a large door unless I allowed 30mm clearance above the door as they are having problems with large openings in timberframe construction. Even though I didn’t build in timber they said they would not warranty any door without this clearance. -
Rain noise on steel sheet roofing
Russell griffiths replied to albert's topic in Roofing, Tiling & Slating
It’s just a gap, MBC timberframe set their roof joists apart with a gap between two timbers, look at some of their specs, Jeremy doesn’t come on here anymore. -
Metal roof - standing seam quotes
Russell griffiths replied to DC5's topic in Roofing, Tiling & Slating
Have you had any samples @DC5 @GraemeHM of the coma stuff, I didn’t like it, it felt flimsy and dented very easily. -
I have 70mm under mine, 25 is inadequate in my opinion. Dont forget vapour control layer, and don’t penetrate it with downlighting. -
Different base structures, bad idea?
Russell griffiths replied to syne's topic in Insulated Concrete Formwork (ICF)
For such a small area why are you bothering ? also have you looked into getting a structural engineer to sign this raft off, icf walls are heavy and I would be concerned about uneven loading on a raft as I presume being an extension that it will not have a load on all 4 sides, I would also be concerned with differential movement between strip and a raft. For a small area you would be better just strip footing and build your icf up from there. A lot of reasons people use insulated raft is to remove the cold bridge when using a timber frame, however you don’t get the same cold bridging with icf.
