You don’t generally hire needles you make them out of as Peter said short bits of rsj or buy some steel box section and cut it to length.
All ours are top hung, due to size and. Weight. I like them, glad we didn’t go tilt n turn
- 1 reply
There’s another topic knocking about regarding timber flooring, but it didn’t specifically cover ufh. Can anybody recommend a flooring that is lasting well and has ufh under it.
What sort of prices have you been quoted for the trespa.
Engineered wood flooring, Yay or Nay?
Russell griffiths replied to Grian's topic in Wood & Laminate Flooring
How many of you lot who are happy with your floors have UFH under it. -
Grab lorry get it gone, unless you smash it into 50mm pieces it is no good under a slab. Ok for a shed base. Or a path, but not the house.
Warm Roof to Cold UNVENTILATED Roof Detail Junction
Russell griffiths replied to BartW's topic in Roofing, Tiling & Slating
Your drawings don’t mention a vapour control layer, you need to prevent moisture entering the roof structure. -
@Grian, I think your problem might be to change your cleaning routine, the word mop needs chucking out and you need to look at cleaning practices and products suitable for the flooring you choose. I laid a floor for a friend and it failed terrible, we had the rep out to try and find what had gone wrong, my mates wife had been cleaning it with a mop and water, splashing it everywhere, unaware that she was meant to use a certain non wet product and a micro fibre duster thing on a pole. Operator error, she thought as it was allowed in kitchens and bathrooms that it was fully waterproof. -
All the hanger manufacturers make screws now, just don’t use standard wood screws.
Depends how many you need to put in, I hired a positive placement nailer for a week, about £100 all in but I had a few hundred joist hangers plus triple grips for the roof in total over 2000 nails, so it was a no brainier
If this is your final home then you need to build it right, 150mm frame with frametherm is not decent,this will need pir board on the inside to meet regs. If you build a wider frame you can use cheaper insulation but more of it, any form of pir board is wicked money. Forget pir on the floor and go eps insulation, you will need more of it 200mm, but as it’s new build you just adjust your floor build up now.
Two-storey side extension on end of terrace
Russell griffiths replied to Bob77's topic in House Extensions & Conservatories
Have you thought of moving, if you added £100,000 to your current house price what could you buy, could you go a rung up the ladder, semidetached better road. You will spend £100,000 in the blink of an eye doing that work. -
You cut the blocks to fit whatever you want. A bloke by me designed his house to fit block sizes, all windows exactly block sizes, no cutting and no wastage. sounds easy but a bit restrictive.
You can certainly use them with a porous bedding under them but not on those plastic things. ??????✊✊??
Is there an echo in here.
Oh god just stop. Put them on Facebook and get the right thing, by the time you’ve faffed about ( I changed my original wording to save @PeterW having to ) you will have cost yourself more than you saved. Just dont FFS.
I think this all needs a rethink, if you are restricted on height you need a concrete slab type foundation to get it low.
- 9 replies
- foundation
- ground level
(and 2 more)
Fixing a wall plate
Russell griffiths replied to Arnold9801's topic in General Self Build & DIY Discussion
You should really have the hold down straps specified in your roof design, it should show length of strap and distance apart, it would also detail any restraint straps for other roofing members. Should be on the roof drawing that went to building control. -
Cheap Way To Raise Internal Floor Height By 150mm
Russell griffiths replied to Johnny Jekyll's topic in Heat Insulation
So I would look at this differently and do the lot in EPS buy it in bulk and save a fortune on PIR prices. Sell the pir or use it in the roof. Go to an eps manufacturer dont buy it from a re seller, they will cut it to any thickness you want so you can tweak your finished floor height. -
Concrete is cheap blocks good on full load dont buy reinforcement in those small sheets, more cost effective in larger sheets dont buy 150mm kingspan, use two sheets of 75mm, 150mm is a pain in the arse to cut and fit with 75mm you can stagger the joins and do a better job. 75mm sheets are about £22.
Your paving is already too high, it should be 150mm below the damp proof course. You need to keep the gravel to lesson water bounce going above the dpc. Don’t fill it in with cement.
Concrete in some metal rings so you can strap down the mobile home to stop it blowing over.
