Russell griffiths
    65
  1. I’ve got 200mm of knauf omni fit in between my rafters and 70mm pir under for 0.14 far easier to fit than cutting all that pir.
  2. You will pay double to do that small area instead of letting the guys that do the rest of the house add it on and do it at the same time. Why do you need to screed it to just make it a temporary office if you have block n beam floor what’s wrong with that for a while longer. And why no underfloor heating, this cold room of yours you will come to regret, get it to the same spec as the main house or it will be an unpleasant place bolted on to a nice house.
  3. First thoughts are that your garage is a bit short, 6m is fairly normal as far as I’m concerned 5.5 is a squeeze. Unless your into tiny Italian sports cars.
  4. What sort of wall are you putting on a 300mm wide footing, that’s very skinny
  5. On the phone again 40 mins this time. Im hoping it’s going through, fingers crossed.
  6. I personally think he’s talking rubbish, but I like to know some facts before I tell someone they are. I cannot find anything about a combustible surface, he’s probably mixing things up with flues from boilers and other regs. Like daves problem previously i could I could solve it with smaller bottles. How could i work out how long a 19kg cylinder would last running just a gas hob.
  7. Spray foam installed is very expensive, with other types of insulation you can install yourself so save on the labour. Look at a deeper frame so you can use more of a cheaper form of insulation. Start building as soon as you can you will never save enough to match rising costs.
  8. Why put it in the bottom, it will always be under water, fitting it at the high water mark keeps it up out of the water a lot of the time.
  9. Take some tablets to keep calm. They are the worst organisation I have dealt with.
  10. Starting this back up. I have a couple of issues raised this morning when the gas man turned up to look at sticking in my lpg pipework. The first one is the distance vertically to a combustible material, my house is a bungalow and he was concerned about the height from the top of cylinders to the soffit and facia board, my soffit is timber, I cannot find any drawings that say anything about the actual fabric of the building is more about openings. Please see pic. Any thoughts @ProDave
  11. Morning does anybody know a number to contact bt connections dept on, we are trying to get a line connected and have had the job cancelled 3 times. Every time I ring up I have to go through all the different departments to get to talk to someone, so far I have been on hold for over 5hours with 3 different phone calls. Getting pissed off does not even come close.
  12. You don’t need to increase the size of the roof joists you counter batten on the inside to provide more depth. Look up ISOVER. Insulation for some ideas. Are you happy the roof roof is in good shape before you do this.
  13. What part of London. If you get that built for under £400,000 I will be very surprised.
  14. Why should a contractor take ANY risk, it’s your project, all he wants to do is earn a wage and go home. You want to build your dream but let somebody else take the risk. He could do it another work out how many days and put 25% on top for risk, then put 20% on top of all materials. This is what I would do. Price it as as high as I could get away with, he probably is doing you a favour.
  15. How high has your brickwork been taken, the shallower the facia the more bricks on show, have they come up high enough. Your facia needs to project up the correct amount to provide seating for the first row of slates.
  16. Have you sized the unit, when you first said 3-4 circuits I thought that’s doable, but then you spoilt it by saying 500mm cupboard. Get the drawings for the manifold, but make sure you have all the blending valve measurements as well. I personally would look for a better solution. It will certainly be a hot cupboard.
  17. Reading Jeremy’s thoughts on his Tesla confirms it won’t be on my shopping list.
  18. That sounds like a silly way to do it. Why would the speaker wires not run in the wall and come up under the window board, through a rubber gromit and into the speaker, I see no reason to drill the window at all. In my last sat place I had 4 high level speakers mounted in book shelves, all wires hidden behind the shelving and the speakers looked like a wide book.
  19. Keep quite. Just get it done, if asked just act innocent.
  20. But you have 136m 113m is definitely not spacious.
  21. Did you get the hint. ?
  22. 113m is small, retirement home, not family home. Depends what you want. We have 180m internally, 3 beds nothing is overly large.
  23. What is the ceiling height? How much height can you afford to lose ?
  24. Look at some posts by @SeanDean he’s been looking at doing the same sort of thing and upgraded his drawings massively from his first design.
  25. Going to double board walls and ceiling with pink. Sod the money I’ve got used to eating beans on toast every night ?
