TonyT
    6
Everything posted by TonyT
  1. For £1k Difference to get 3 phase it’s money we’ll spent. more PV Faster EV charger. no drama with any ASHP.
  2. I would leave it as is.
  3. Sounds like the problem is solved..
  4. He’s a litigator, I’m sure he can get that sorted
  5. Find a solicitor they have mugged you off 4 times already
  6. Yes, lots of people with medieval history degrees struggling at the moment..
  7. Turn off the PV inverter, turn off the batter pack, the changeover switch can be wired last into the consumer unit and will effectively bypassing everything before it just letting you feed the petrol inverter generator straight into the consumer unit inverter generators are pretty stable, mine fully loaded still does 50Hz
  8. Just turn them off at the isolator or consumer unit…
  9. If you have the battery why the need for the generator? if it’s a backup for when the battery is flat in a prolonged outage it’s not a problem. I have PV and a change over but no battery
  10. It’s like buying TV’s some like Sony, some LG etc My house has 2 Charnwood stoves, been in 20 years (ish) never had a problem
  11. Also try the reset button, top left button under the lcd. press and hold agree with Nick, boiler is pretty old so maybe worth phoning the service company who put stickers on the boiler
  12. Blown component on the PCB. check transformer, bulged capacitors etc.
  13. Find the local rag and get a story in the paper like the single mum solar panel ‘single parent refused temp certification, cold, homeless and nowhere to charge EV’
  14. The paint I’ve seen used is also water based so needs protection if it’s likely to get wet!
  15. The only 2 I’ve worked on in Scotland were both sprayed on site.
  16. having a 3kw immersion heater on a plug top is plain silly for lots of reasons. 30 years in the trade and never used a 13 amp plug on an immersion done plenty with 15amp plug and sockets! Via 20 amp double pole switches
  17. Forget about the legionella issues if you have mains water. Try 50 or just under
  18. Keep the fairy liquid for the dishes it has no place in construction
  19. Screw fix do a 10 watt floodlight with pir separate solar panel I used them on some site hoarding for 2 years and no issues
  20. It’s going to end badly if you try and do it with just you and the missus. time to call in reinforcements for Your own health and the finish of the bath, walls etc
  21. Why not tile straight down to the worktop?
  22. Serious overthinking of a problem that’s not a problem.
  23. Mcalpine q10 shallow trap?
  24. Why don’t you phone/ email the manufacturer and ask for the new version of this model? then your concerns of compatibility should be addressed if you explain the situation
  25. Thread lock would be better
