TonyT
    6
Everything posted by TonyT
  1. Megaman do good lamps
  2. Give the driver £50 to move it closer.
  3. Try Victron they have inverters/chargers/charge controller/ apps.
  4. Awesome, can I get a certificate to show my kids
  5. exactly what I have with changeover switch inside.
  6. discrimination is now selectivity. can’t have discrimination now you know!
  7. Definitely, it’s an office so got to have a back up
  8. You can make the zip 100 deg but you get pump issues, so ours are always set just below.
  9. Part of glass cutter?
  10. https://www.meteorelectrical.com/pub/media/catalog/product/file/Shower Boards_1452600737.pdf
  11. Remember he could be saying you don’t need them due to the weight in handling them. just saying…..
  12. Leave as it is, box it in, any dealings with utility company will end in unwanted stress.
  13. Why would the staircase person highlight something that he didn’t do had no input in? he’s there to fit the staircase as it was designed not offer design opinions?
  14. On site welders to cut and reeled if necessary
  15. Best to rectify then, as it will bug you forever.
  16. If you can returb to have the boiler, cylinder on the ground floor and create a small plant room/utility cupboard, it will be easier to modify pipework/cabling in future. plus one to all the other sensible suggestions!
  17. drill hole and bang these in available in different colours. https://rts.vents.co.uk/blog/product-details/rytons-retro-weep-vent-rtv250cl/
  18. I didn’t know the government were in charge of certification?
  19. Wouldn’t you want to fit as much PV as possible for example 5kW and let the inverter limit to the DNO max figure, pretty sure that’s what most people are doing these days rather than the original installations of 2010/2011 FIT where it was DNO max limit and that was that
  20. Personally I think the cavius ones are deeper so Will protrude more from the ceiling and look more obvious aico for me all the time
  21. https://www.aico.co.uk/wp-content/uploads/2021/06/Ei3024-Ei3016-Ei3014-Instructions-1-1.pdf for some good reading heat in kitchen smokes in hallways/landing. and or follow JohnMo previous post. In adding to living room etc if in doubt run 3core and earth to points and leave an unbroken loop behind the plasterboard for future use
