Mr Punter
@lizzie can you still use the ovens etc when you have 4 seated?
Often privacy issues relate to back gardens. Is there anywhere in their back garden that any window overlooks? A block plan and an elevation of your house may help.
Can you run a vent to a wall that does not face the road, or duct through the roof space and out through a soffit on the other side?
EPC helped by loft conversion?
Mr Punter replied to Ferdinand's topic in Energy Efficient & Sustainable Design Concepts
I didn't know it has to be a C by 2030. I suppose there will be exemptions if the improvements would cost too much. New boiler and controls will make quite a big difference to the score. If the increased rent return covers the conversion of the loft it is probably worth doing. -
It is worth going straight through with the centre drill bit then drilling the last bit from the outside to make a neat job, unless you are a plumber so you can just smack a hole through and leave it to someone else to make good.
Biggest unknown will be asbestos and you MUST have an asbestos demolition survey carried out before you do any work.
I have used a silane / silixone type cream on an old building to help prevent brickwork saturation. I think the insulation claims may stand up for porous brickwork solid wall construction.
Unless the cost is more than 15% of the total build cost, get a mains connection. The borehole nearly finished off @JSHarris and he is one of the most resourceful members here.
I understand that different LAs take different stances on this, where some are willing to accept a completed shell, others completed foundations and some may even ask for it to be completed and occupied for a period of time. I suggest that @JamesHopeful has a chat to the LA explaining what he wants to achieve and see what they suggest. There is no point in imagining that they will not enforce as this seems to be one area that is not so subject to budget restrictions.
Sounds like overkill. I have only used these on the floor and we laid them in tile adhesive. Adhesive plus screws may be best, but 150 centres is intense. Not so bad if you are fixing down onto a timber sub floor but too much for a wall.
Hi Josh As others have suggested, the glazing will probably lead to overheating. There are solutions such as SageGlass, brise soleil and external shutters but they are expensive and best considered early on. The plans look like traditional blockwork walls, so you might want to look at fully filled rigid insulation or if you increase the cavity, polystyrene beads. Traditional render and set internally is best for airtightness. I don't think the cars will fit the garage. Maybe 2 doors or one much wider? A lovely big house.
Maybe you could just have 8 around the edge and 2 in the middle.
With those washers I would just drill a 6mm hole through the board for red plugs and 50mm x 4mm stainless screw and plug through the board. They give you 100 washers, so 10 per board. 1 in each corner and the other 6 spaced around the edges. You could squirt a bit of ct1 in the holes if you want.
It is not going to happen as the first floor walls are built off it.
If the soil conditions are suitable I would look at building the whole thing on stilts using screw piles as suggested by @JSHarris.
If you are able to rule out UFH and tiles, you could get some insulation on top of the floor, then finish it with an overlay board and LVT (Amtico, Karndean etc) and heat with radiators. If you can live with the floor being 60mm higher, you could use 40mm thick pir type insulation (Kingspan, Celotex, Xtratherm etc) at a cost of about £7/m2, but the insulation improvement will be OK but not great. The fitting, overlay boards and finishes will likely bring the cost up to £70/m2. If you are feeling flush, you could use Kingspan Optim-R 40mm thick which will be four times better at insulating but will cost an extra £130/m2 or so.
Sometimes they use a tool to create a slot in the screed while it is still green
- 11 replies
- sand and cement screed
- screed
(and 2 more)
I think the issue that makes this difficult to rectify is that the first floor walls will be built up off the offending 18mm chipboard, which is probably glued to the floor joists, so the chipboard cannot come up without taking out the roof and walls. Overboarding is the only option. I am keen on 22mm Egger Protect, glued all edges and to the 18mm and screwed. Perhaps get them to compensate for the required door adjustments.
Any structural engineer experienced in steel framed buildings would be able to design this for you. You could contact a firm who do agricultural buildings and see if they could recommend someone.
It looks like one of your runs starts outside your plot boundary. Also you may need to be careful with scaffold and eaves overhang with the neighbours. Roof area looks about 50m2
Ideal Ceiling, Hall, Stairs and Landing Dimensions
Mr Punter replied to Dan F's topic in New House & Self Build Design
You cannot use the combination of rise and going. 2r+g must be between 550 and 700 Reduce the rise and add another tread or two. 2400 for first floor ceilings is a bit mean. -
Full Planning Granted - Non material amendment for a basement?
Mr Punter replied to Ceefer's topic in Planning Permission
Basements are fairly high risk and you need to consider ground conditions, safe excavation, ventilation, daylighting, retaining walls and waterproofing. Given the FRA I am not sure why you would bother. You would need a minor material amendment application for this. You could only use the basement for non-habitable purposes - cinema, gym , store etc. -
Shower Tray in Finished Concrete Floor
Mr Punter replied to Visti's topic in General Construction Issues
You can get a tray like that which is only 30mm deep and sit it on the concrete. You just need to box out the bit for the waste. You not notice the 30mm step. Get one that is slip resistant and easy clean. -
For timber , concrete and steel beams or joists on a residential project, 4m spans are fairly economical. Much more and it is worth looking at additional midway support.
