Mr Punter
I would rather just sell up and move than have one. If you have a basement, look at a small pump station which can handle solids. Quieter and more reliable, but need to be sunk down.
Reducing The Potential for Error
Mr Punter replied to ToughButterCup's topic in Project & Site Management
I would stop work on the building and ask MBC to come up with proposals to remedy this. If you leave it it will impact on loads of things further down the line - furniture, stairs, plasterboard, tiling etc. You have a new house, not a Tudor cottage. Make sure you have their insurance details as you may need to put them on notice. -
The timber frame soleplate MUST go in completely level, packing under if required. Generally packing up to 20mm is OK and after this you would need an engineer to show that it is acceptable. Gaps under the sole plate should be filled with non-shrink grout. Packing between floor zones is a no-no. So is 30mm in 4m. Is it out of square on plan or just elevation? Pretty crap either way. -
Maybe different gas - krypton or xenon may perform better.
Looks fantastic. Can you get rid of the kids toys or have them sprayed grey (the toys, not the kids)?
PP for outbuilding - Grade II listed cottage
Mr Punter replied to Simon's topic in Planning Permission
I am not sure if this applies to a listed building but it is possible to construct a number of outbuildings as permitted development, up to half the footprint of the house, giving you the storage you want. If you later wanted to consolidate these the planners may be amenable. You need to be outside a conservation area for this to apply.- 12 replies
- grade ii
- planning permission
(and 4 more)
Concrete slab on top of dwarf wall or adjacent to...
Mr Punter replied to Carrerahill's topic in General Structural Issues
Would beam and block be better here? -
I have used their full fill masonry insulation product CF5000 which I think is the same stuff (glass fibre layers & textured alu foil) but 450 x 1200 sheets and profiled edges. I think anything 5000 is the same basic stuff.
FR5000 and RS5000 are identical. The RS5000 is marketed for rainscreen cladding and has been "tested to meet the performance criteria set out in BR 135 for rainscreen clading systems." Both have better fire resistance than the standard PIR. They also have thicker texture aluminium facings.
Both RS5000 and FR5000 are PIR and seem to have identical properties. Both claim " Class O fire performance". I suspect they are identical.
Come in at the side of a 5 inlet chamber and use an 11deg or adjustable to make up the difference
A lot of the premium slates need less sorting and have less wastage. Those from a reputable supplier with a long guarantee will be more expensive but better. You will need to try v. hard to find anything that will fail within 30 years. Lots will last 100+.
Copper or Aluminium nails for slate?
Mr Punter replied to Construction Channel's topic in Roofing, Tiling & Slating
Copper nails or stainless hooks -
I would reapply for the lapsed scheme. When (if) this is granted, go in with your new multi unit scheme.
Self build is normally detached houses which is less than 2% of homes in London. I doubt any plot would be less than £850,000. First time buyer in London = 1 bed flat or studio.
- 16 replies
- london
- furst time buyers
(and 2 more)
MVHR. Will really help with your SAP calcs too and far better air quality than trickle vents.
Lifting and Lowering (useful "rule of thumb")
Mr Punter replied to B52s's topic in Project & Site Management
Where we are the tackers are just finishing installing 1000 sheets of Soundshield plus on the walls @ 37kg a sheet. -
Tata Urban Colorcoat Metal Seam Roofing
Mr Punter replied to Barney12's topic in Roofing, Tiling & Slating
I think the 50mm is sensible and allows for insulation being uneven and the roof nails not penetrating the outer airtight membrane. Why not batten the tile section an extra 25mm? -
UFH with existing Radiators and system boiler
Mr Punter replied to Silage's topic in Underfloor Heating
I would concentrate on improving the cottage. Insulate and improve airtightness. Control ventilation maybe with MVHR. In many ways this is much more of a challenge than new build.- 36 replies
Give the ICF firm a call and ask them the best (quickest / cheapest) way to get over slightly uneven foundations. They will be most amenable. 50mm is well within tolerances for foundation concrete.
LED strip?
We paid £20 per metre for single skin blockwork, £65 for cavity wall with facing brickwork. Lintols and padstones £16.50. I would have thought that you can get blockwork done for between £15 and £30 per metre labour only. Get a price instead of day rate, even if it just a price per meter or block, so that you can measure when he wants paying.
Do you know which ones are threaded half way? Screwfix tend to show the same pic for all lengths and mostly the shorter ones are fully threaded.
We are fixing some 18mm ply down onto 22mm chipboard in bathrooms so we can finish with 2.5mm Luxury Vinyl Tile and the finished level will match the oak floor on the adjacent landing. I was thinking of screwing this down, but we can't get many fixings into the underlying joists, so I would like to just screw into the chipboard using 38mm screws. Can I get these threaded half way, so the ply does not get jacked up by the screw? I will be needing a fair few.
Installing a concrete lintel, reassurance please
Mr Punter replied to 8ball's topic in RSJs, Lintels & Steelwork
You can get a lintel 100 x 140 x 1200 like http://www.builderdepot.co.uk/concrete-lintel-textured-pre-stressed-100mm-x-140mm-x-1200mm.html which may be sensible for supporting the floor above. Engineering bricks are http://www.builderdepot.co.uk/class-b-engineering-brick-smooth-red-b101.html
