Dave Jones
Everything posted by Dave Jones
yup that will make it worse.
What do you want from an architect?
Dave Jones replied to CharlieKLP's topic in Surveyors & Architects
wouldnt worry about your PI, most high street lenders wont accept an architect cert now on a new build they want a proper warranty. If I was in your shoes I'd specialise on planning and how to get it, write your own cheques one you make a name for yourself doing that. -
Average number of trench concrete blocks per day
Dave Jones replied to iMCaan's topic in Bricklaying, Blockwork & Mortar
day rate lol. another lamb to the slaughter. -
https://www.ebay.co.uk/itm/293584144331?_trkparms=ispr%3D5&hash=item445afa87cb:g:rGkAAOSw5xpgwK0V&amdata=enc%3AAQAGAAACcPYe5NmHp%2B2JMhMi7yxGiTJkPrKr5t53CooMSQt2orsS%2Fwocn770hnih0B3mVHNZ5FiX2AyaOyBUypmk%2BwrN1UGU1ayniuKhoGfplg7QD61T4NWZUskXoR%2BwR7rIvPGGo8o9MNuCuO6BxaD6AiQqPFTiL1sC0%2BFVQT1MCM2RBS8xjXR3XFaD2FE2Ab3RwqMNT7VWsJ4xNrMoHI7ikyKfKUIyLS6aw2tXTGTVOhbiMqOPMlyGrZND1VN5EREK4miKe5c3REJ%2BjuIVeChp5qkCk5Q1qzvUB7XPMl5Rj1TrfETG3Sr5uqngXLsDBPUiqjy0XGxdnln%2FEvjywEOv6fW5KixLrX38hvDmRyw7ZYIGRnB2TeSoRWv5AtGTAbge7HVZM8EKIgJKcm5kTuPehPDmHZ0emXrMhgIL2DrSgLCPq5iEZdG%2F5glMDMrdc1VeoS%2FCp65YstXPvxdeYAb8%2Ba2sKcKlcc%2BvQFwgFg0kGwCaj8idCwstgjYQP2cW3nuskDW4Nt5ijavnL7aa2rKkJ0gv17AnUxo8ti6d%2Bc0GqnbDxAtMIMh0I1CMuY%2Bs7hLrlzE1jqq3T3oHMKq5hjcADJMagrmaSCVOGGT3wCKjzUT9yu7xceLrHIU7IPXwOvp%2BF8cIK2MP1%2BEilrOBEHfQpBmiGcH6a1PNByAqxBpdmCZLIDhqaem76sSQItePw8kcwa3VAqCODTFLrkPzVfKKHIlP3B%2BYUwYsrJSZS54oyAcoK0ybOH7qceEH%2F0CV5ok9SKBVXbkeIHWGjXUvchMihXFCDlV3m1E0oEynFyj9p%2BqxR07El7UnSnAEMIVNH7cT58W%2Blw%3D%3D|clp%3A2334524|tkp%3ABlBMUKjQtKrMXw
water turbine all day long.
not in floor. walls/stud/ceilings.
looks a really bad job, big lumps all over and not flat. As your not going to rip it all out negotiate some price reduction before they get on there horses and rise off.
Insulating a Cathedral Roof - Mould and Condensation
Dave Jones replied to LeRouret's topic in Heat Insulation
taping anything isnt a vapour barrier and is a le bodge. What you have is an unsealed warm roof, the cold is 'coming through' the insulation until it hits its dew point and water forms inside, it cant dry out easily and so gravity takes over and down it comes. Pitting a VCL over the top wont help at all, the cold will still go through and a dew point will still form inside the insulation only now it has zero chance of getting out. You need to make this a cold roof, massive ventilation. Take all the muck off the ridge and make sure its vented, make sure the eaves are all open and vented . you need as much aiorflow over the insulation as possible. put as much insulation in as you can and still have at least a 50mm gap between it and the tyvec membrane (which you need to fit). -
professionals do a full mist coat to walls and ceilings as its very fast and gives a consistent finish.
its all a matter of taste really. I'd prefer a pantile roof with GSE modules personally. Seen a lot of rip off plots on graven hill, what was your plot cost and m2 spend on build costs if you dont mind sharing ?
other manufacturers do the flush sash/casement style as well. They do look much better than bog standard upvc clones.
good, it looks like shed it needs to go.
could be a trick of the photo but the window above porch doesn't look central over it ? amtico flooring karndean clone a lot cheaper. shame you didn't opt for 2600 ceilings would have looked great, one of my bug bears the roof touching the top of windows.
Does an ASHP stack up financially?
Dave Jones replied to SBMS's topic in Air Source Heat Pumps (ASHP)
you have no good options here. Obviously gas is the best and cheapest option but you cant get it so thats out. You know the score with heat pumps by the sounds and they are a crap compromise but probably your best worst option. Add lots of solar as they are eye watering expensive to run when it gets cold and they stop working efficiently. Not to mention find somewhere to put a bunch of tanks so you don't run out of hot water, they cant heat and make hot water at the same time... You will want underfloor heating everywhere to make use of the tepid water they create. Cost wise, gas boiler 1k ashp 10k so no they will never pay themselves back. -
Warm Flat Roof - Airtightness and Drainage Channel/Costs
Dave Jones replied to AliG's topic in Flat Roofs
essentially yes. The Alutrix needs to cover the whole roof and lap 150mm onto the walls. Insulation then goes on top. You want zero holes in the alutrix. -
have a look at kingspan thermataper, this allows you to have a flat buildup from the joists. Your build up needs to be Joist OSB decking Alutrix VCL brought up sides of walls. You are watertight at this point. Insulation Final weather cover EDPM etc This buildup gives you zero penetrations into the buildup as its outside the build envelope. -
your in fantasy land mate.
ground floor isn't an issue bring up sewer where its needed, first floor you need to lose them in the stud (unless you want council house style boxing in)which means that stud wall will be wider than normal to accommodate 110mm pipe. Lose the pipe in the elevator shaft and run to it through pozi joists.
do a sanity check Your purchase costs to date = X Your projected build costs at £2000 m2 = Y Does X+ Y = what the new build be worth ?
Advice on structural warrant provider
Dave Jones replied to Zak S's topic in New House & Structural Warranties
wonder why you cant obtain a mortgage without a warranty ?? High street lenders even turn down architect certs. Not rocket science is it.- 22 replies
- warranties
- selfbuild
No use to the OP but better method is bring the pipe through/under the footing ducted in 110mm sewer pipe then carry the duct up to the finished floor.
depending on the scale of your rebuild, 1 room or whole house etc then it will be worth your time investing in a QS. Expect to pay £1500 - £2000 m2, with the lower assuming you do the labour. If your planning to spend 6 figures or more you would be mad not to get plans and costed. How is a builder supposed to quote without detailed plans ? https://www.estimators-online.com/
not really. They are for the mortgage company to claim against in the event of a structural failure resulting in an un-mortgageable property. Otherwise buildings would be built cheap like in india/pakistan/middle east like cow sheds.- 22 replies
- warranties
- selfbuild
