Dave Jones
Everything posted by Dave Jones
green paint/artifical turf.
get some boning rods as well to complete the set!
spend your money on battery and inverter, no moving parts to go wrong and you can make it pay for itself by using a time of day electricity tariff (I use one for my powerwall). If you have solar pv as well this is a bonus. If you work from home you can claim the cost back against tax as well. https://www.solarguide.co.uk/solar-batteries/tesla-powerwall-2-0-vs-powervault-g200-which-is-the-best-solar-battery#/
hosepipe! Get enough hosepipe to reach then a meter of clear pipe to shove in the ends to allow you to mark a level with a pencil.
Battening for Vertical Timber Cladding - Tips, Hints and FAQs
Dave Jones replied to Thorfun's topic in General Joinery
windows would look a lot better pulled forward rather than recessed deep into the house. -
i have the Hive system from british gas, its very easy to install. The rad trv's are excellent as they allow you to manage heat in different rooms much easier.
in that case you have an airflow problem, can air circulate under the ridge or is it blocked off with a ridge beam ? Some tile vents at the top can help to create a draft over it.
Well that's a poke in the eye with a pointed stick
Dave Jones commented on LSB's blog entry in Little Stud Barn
my money is on trees being the issue as even 1.5m would be overkill on clay in the absence of trees, piling would be cheaper. -
you can do without BR drawings but you have to know what your doing to anticipate issues. For self builders its too much of a risk as you will have umpteen other problems due to lack of knowledge and experience so anything that reduces the risk and unforeseen costs the better. You wont feel confident enough to push back on some of the more extreme nonesense BC will try to push on you thats costs £££ where as a builder will as he knows the score.
remember its not sweating the dew layer is being pulled inside the insulation. You have a cold roof so make sure there is a LOT of ventilation all over the roof, open eaves or vented fascia and open ridge (dry).
https://www.stainlessdirectuk.com/product/zen10-1100-options/
it may help you to run a string line to get the edge straight, also work out the cut at the end first as it looks better with an equal cut at both ends.
Novice Selfbuilders in Northern Ireland - Build Cost
Dave Jones replied to HillsideNewBuild's topic in Costing & Estimating
min £1500m2 for basic, complicated and nice fittings more like £2000m2. Best bet is to get your plans drawn up and have them QS'd then you will know to the penny what it will cost, its cheap to do as well. https://www.estimators-online.com/ -
Council tax on a rebuild?
Dave Jones replied to Andeh's topic in General Self Build & DIY Discussion
it will be the completion cert that triggers the tax droids. Delay that as long as possible.... -
think id be inclined to tuck it under the neighbouring tiles to make a smart job if it similar to whats been posted above.
maybe a case for helicoil screw piles. wont save you much cost wise but speed and mess wise they are a breeze. Find a good local builder and ask them what SE they use. Yours might be one of the un-better ones. -
what ventilation do you have above that ? Needs to be open at eaves and ridge.
looks really good, shame about the render though. A nice brick with a plinth would have looked stunning.
- 63 replies
- cladding
- open joints
pretty poor finish really, no attempt at doing the corners properly. Accrediuted EDPM installers can offer firestone backed 10 year warranty, id insist on it before paying. What is the build up of the roof, what vapour barrier was used ?
not like you wanted it laid to a fall ......
they are carbon neutral. Much better than a gas or electric fire.
minefield of regs, whoever you are getting to sign it off needs to spec it.
Struggling to get Site Insurance for End of Job
Dave Jones replied to Ralph's topic in Self Build Insurance
block it with blocks. -
block up the blacony opening ? -
you have built too close to next door ?
