Did you send a drawing .? if not then you will need to put it in the pile with the drive on glass.
Do your own research. Im currently working on 3 icf houses, they all have their faults. Some issues are bigger than others. Cold bridging at reveals, poor airtightness, inaccurate blocks, hard to cut. The list goes on and on, you need to decide what items are ok and what needs major remedies to make a better system. And do not listen to the salesman, you want a rep who doesn’t care if you buy his blocks or not, he gets a sale by the product not his fast talking.
Why have you gone for a 762 door, far too small in my opinion. I would also say your rough opening is tight, doesn’t allow a lot for packing out the door lining.
Remember to buy your osb so you know what size it is, if it’s imperial it will be 1220mm wide not 1200. You should use a full sheet on the corners.
Is This An Acceptable Job
Russell griffiths replied to taggs101's topic in Roofing, Tiling & Slating
That’s standard, your roof has sagged, but the section over the party wall hasn’t. You would need a roofing carpenter to strip all your rafters to take that bow out, adding thousands to the job. -
@Nick Laslett windows detailing, rubbed down, filled all gaps with PU sealant and a finger, two coats of TT gas proof membrane, this allows lots of other products to stick to the paint, I found it very hard to get anything to stick to the eps. Then windows fitted, masking tape applied around windows allowing a 5mm bit of frame to show,then gaps filled with illbruck foam,Foam cut and trimmed back, then illbruck air sealing paste, squirt on and smooth with a brush. Buy 20, 1 inch paint brushes and chuck them every other window.
Amount of tape required for window install?
Russell griffiths replied to kxi's topic in Windows & Glazing
If your a bit handy do it yourself, at the end of the day it’s peeling the back off some tape and sticking it on. I would even trust the wife to do it. £3000 buys you a third of a kitchen or a nice bathroom. I had the sega rep come to my job he came in a van with every conceivable tape they made in it, he cut off lots of different types and did a demo with them all to show how to apply them. I will hazard a guess that I spent £350 on materials to seal mine up. -
Various, I had a 25 ltr tin of gas tight paint left over so I used two coats of that, also blower proof paint.
Fast drying screed V traditional
Russell griffiths replied to Robert Clark's topic in General Flooring
1 day liquid screed 3-7 for traditional if they have used a retarder to stop it drying to quick. -
I went a bit ott with mine but I got a good airtest the other day. Every gap and joint squirted with some form of sealant and then painted over with an airtight paint.
65 days unless he’s using a modified cement product to mix it with. -
Roof Construction For A Vaulted Ceiling
Russell griffiths replied to Jimmy_k's topic in House Extensions & Conservatories
I would say you would need 120mm on top of timbers, but you need someone to crunch the numbers for you. You don’t have insulation between the timbers on a warm roof, in between and on top or underneath is a bit of a hybrid, my extra insulation is underneath, Dave’s is on top, many ways to skin a cat, you need it to work in your situation with the height you have to play with. -
Due to the lack of height you might need to change your thinking on the warm roof. Lets say for arguments sake you end up with 200mm rafters then 120mm of insulation on top, then a counter batten then a roof batten. You will be up 370mm from internal ceiling height. You could go 200mm rafters with 200mm rockwool type stuff In between the rafters and 70mm pir insulation under the rafters. The easiest way to work it out is to get a long piece of roof batten and some chalk, go outside and draw your walls onto the house, then lay the roof batten against the house at the pitch you think will fit, use an angle finder on the batten to work out the pitch and give you a bit of an idea what you are looking at. An architect should be able to do this on his cad program. -
Blowing my own trumpet
Russell griffiths replied to Russell griffiths's topic in General Self Build & DIY Discussion
I wish. -
I do wonder if all this is a box ticking thing, as in if you present the council with a big pile of paper saying everything is cool then do they bother to question it. My treatment plant will discharge into a pond I have constructed, which sits right slap bang in the middle of my site, which the whole site is a SSSI. So work that out. I did pay a big chunk of cash to a company that design water infrastructure to do a flood risk assessment and rainwater run off calculations. We also have 3 other septic tanks between myself and my neighbour all discharging onto land within a SSSI
It’s the one building regs want, not the one MBC do their test to. The company I used do the testing for MBC. -
No the bloody dog had it by the time I came back in ?? -
Air test today, had one done on the unfinished house to get an idea if anything was wrong before I start plaster boarding. Final test figure 0.28. Which I think is rather spiffing. I would like to thank my team. The wife for support and finance ralf and woody the wonder dogs,for guard duties and @Nickfromwales for the cakes and singing. .
- 13 replies
- 15
Membrane (applied early) and Eaves detail SIPS
Russell griffiths replied to SuperJohnG's topic in Roofing, Tiling & Slating
Lift the membrane up, the last thing you want is a join in that area, this is the area any pooling water will collect. -
I dug a big hole and buried mine. Probably 100 tonne of it. Spread the soil that came out on top and you wouldn’t now it had ever been done.
I would look at a thick mastic and a foam damp proof course i would squirt the mastic on in two thick lines then bed in the foam filler then two more lines of mastic, this will take out any undulations. Get the frame up and secure down with straps once it has gone off, a few packers here and there to keep it from sagging.
Italian 10mm. Brand, god knows.
What sort of prices should I be looking at for floor tiles. Currently looking at 1200x600 porcelain at £39 a metre, with a 15% discount for the quantity I need. Anybody found any deals. Not interested in out of square Chinese rubbish. But would like to find if there’s any deals to be had.
Starting to look at floor tiles. Porcelain 1200x600. What sort of discrepancy should I look for over the length of the tile, I want to make sure I pick a good one and not a load that turn up like bananas. Should they be mm perfect over the 1200 distance. Most im looking at are from Italy, is that a good starting point. Ta very mucho.
Hot return circuit, how to control it.
Russell griffiths replied to Russell griffiths's topic in General Plumbing
@Nickfromwales made me spill my tea mate ?? it was only a cheap cup, you need to let this go.
