Is there a universal law of screw sizing?
Russell griffiths replied to epsilonGreedy's topic in General Joinery
2x38mm timber needs a longer screw than 50mm i would go 60 or 70 screw one on with your 50mm and see how easy it is to pry it of with a short bar. Always try the destruction test. -
Window provider U-values a bit crap?
Russell griffiths replied to Moonshine's topic in Heat Insulation
solid aluminium will be cold to the touch, I used to have ally in a previous place, always a cold feel to the window. I would go ally clad timber if you want better performance, you won’t achieve it with just aluminium. -
Extending existing footings for larger footprint SIPS
Russell griffiths replied to SIPslidingaway's topic in Foundations
Pull it all out and put an insulated raft in. fixes all the cold bridge issues in one go. -
Is the NSBRC worth a visit
Russell griffiths replied to Chanmenie's topic in General Self Build & DIY Discussion
Stay overnight in the hotel, you are better having 5 hours there and then a night off and return in the morning to take a look at all the things that you think need further investigation. -
Which services cannot be built over?
Russell griffiths replied to Ferdinand's topic in General Self Build & DIY Discussion
High pressure gas line. But you probably don’t need that do you. -
Grand designs - new series 2021
Russell griffiths replied to Moonshine's topic in Property TV Programmes
Well I liked it. -
Legit to shorten a galvanized roofing strap?
Russell griffiths replied to epsilonGreedy's topic in Roofing, Tiling & Slating
They will out live you, if nervous get a can of cold galv and spray the ends. -
Yes they do, if you hang a pipe from hangers and go back in 10 years they look like a banana put a piece of pipe in a rack for 6 months and go and get it out, again it will look like a banana.
Bed and haunch in lean mix concrete, full bed, never bed on just pads and don’t hang from hangers unless visible, as it will droop leaving sags in the pipe.
Cables under insulation (above slab)
Russell griffiths replied to WWilts's topic in General Construction Issues
Duct under the slab, how would you pull a new cable in if you surround it in insulation and screed over it. Unless you duct it there as well, don’t underestimate how many cable ducts you will have coming in and out. I think I have something like 5 electrical ducts up to my plant cupboard. 1 in and 4 out to feed things in the garden.- 1 reply
Why not cut the barbs off,if that’s all you can get
Building Regulations
Russell griffiths replied to Dutch's topic in General Self Build & DIY Discussion
All I will say is re think the durisol part. -
Normal floor eps is only 70kpa, so yours is fine.
- 6 replies
- xps
- insulation
(and 2 more)
WC / Shower Room on Ground Floor vs Building Regs
Russell griffiths replied to BartW's topic in New House & Self Build Design
Ok then mr Nick @Nickfromwales, what regs say you have to have a bath. I hadn’t planned on putting a bath in, but at the last minute did, so if the house didn’t have a bath, what then. -
A wise man on a building site
Russell griffiths replied to Pocster's topic in General Self Build & DIY Discussion
Did I mention any names ?? -
We all ponder the same question. But you are fairly amusing, so carry on. At least your posts don’t go on for ever and ever and ever like a certain bloke we know. -
If you don’t fix it now it will mess everything up the further down the line, fix it now before it’s too late.
Was £5.50 LM when I brought mine. I have another project that I need ?? Will need to keep my 12 year old truck another year or two.
Ask the roof designer. You should have a truss layout sheet with all the connections listed on it. All hold down details and uplift straps should be on the same drawing.
If you put something cheap and nasty under that open gable, you will regret it. Needs to be something a bit tasty.
The cedar was eye wateringly expensive, and the oil also, add the two together and it’s getting up with the price of those aluminium panels.
Cedar here, if you think it’s expensive to buy, wait until you oil it. I don’t know where the prices come from ?? would be cheaper to buy my own forest.
Part E - solutions for existing floors
Russell griffiths replied to Sjp1's topic in Building Regulations
Can you not do it below with a false ceiling.
