Just use the steel it’s such an easy thing to do. Bolt the timber in while on the ground and just lift it up and build it in.
What do I need to know before buying aggregates?
Russell griffiths replied to oldkettle's topic in Building Materials
Thought that block paving would not stand up too well, the pressure the front wheels on those trucks exert is something to be seen. -
Just had 10 tonne of type 1 for £190. It looks like the washed gravel I was having was £26 a tonne. Should have checked I’ve been chucking the good gravel around jus5 to stop a bit of mud. -
Pipe is cheap, 100m max preferred, I have a couple at 108m adding 1-2 ports on the manifold will only increase the cost by £20-£30 add in a couple more actuators another £30. Your fighting with the correct design to save £ 150. Get wunda to do you a proper design it costs £50 if you buy there pipe.
Is that driveway coming out after your build, the first 18 wheel truck you take up that will turn that block paving into an obstacle course. Why not get your finished drive marked out now and get it dug out then fill it with crushed concrete. Limestone will compact nicely but will leave white smeary marks down the road when it rains. I buy direct from the quarry for everything, but the smallest load available is 10 tonnes, I pay £26 per tonne plus vat for nearly everything they sell. Find a local quarry and open open an account under self builder, try and find a large quarry that does ready mix as well. -
I think your bigger problem will be cost, and finding somebody to do them to your timescale. You want to design a floor where all the metal struts are inline throughout the floor, if not it plays hell with getting services through.
Early thermal cracking in newly poured external concrete slab
Russell griffiths replied to kxi's topic in Concrete
You have two choices break it out and re do it, or leave it alone, there is nothing remedial you can do. As said above, cover with wet hessian next time or polythene sheet. -
Large Garage/Workshop plans
Russell griffiths replied to WestcountryWonderer's topic in Garages & Workshops
Insurance wise you are talking about two different things. Standard construction satisfies the property insurance, for example the built structure and how it stands up. Contents insurance is totally different, try to get insurance on an outbuilding not connected to your house, I have found previously it very hard to get cover over £2000, and almost impossible to get cover for a non brick construction. -
I would build it on an insulated raft and use icf blocks for the walls. I wouldn’t entertain a wooden structure if your thinking of welding and grinding. Sips panels will also be very poor at keeping any noise you make inside. -
Have you looked at tool insurance, I know that many insurers will not insure tools over £2000 value unless in a brick built building. -
Toughened, and laminated if it is to stop you falling. Toughened only if it is to stop you getting cut.
concrete oversite under block and beam floor?
Russell griffiths replied to Moonshine's topic in Foundations
Crushed concrete, compacted with the digger. -
You need to get your terminology correct, I believe that if you use the insulated In fill panels then you need a structural concrete topping. This is not screed, screed has very little strength. Refer to the floor manufacturers guidelines.
Yes, it’s a bit of a pain and one reason I didn’t do it, because I’m building in icf I needed to screw lots of props into the floor to support the walls which I was unhappy doing with the ufh pipes there. However another forum member did it and used boards on top of his concrete to screw his braces into. If you go timberframe the erection team need to know that they cannot screw anything into the floor. One lad on here had a very nasty surprise when his team drilled multiple holes in his floor.
Door sizes disabled regs.
Russell griffiths replied to Russell griffiths's topic in General Self Build & DIY Discussion
perfect, what else did you expect. ?? -
Nope.beams, infilled with insulated blocks, insulation board, mesh, ufh pipes, concrete topping , not screed. I would have done this but but it was a couple of grand dearer, being that insulation was dear and blocks cheap. Funny how its changed.
Castellated panels will likely 'breath'
Russell griffiths replied to MortarThePoint's topic in Underfloor Heating
Spot on, mine was 80mm. -
So if you had clipped your pipes into rails you wouldn’t be wasting your time thinking of this. ?? Are you sure on your weight calculation for the screed, mine weighed something like 144kg per m. -
So bc came today, I fired a load of questions at him. He stated 770mm clear opening is what he is after. -
Can you not sark the roof Scottish style, 100x25 all over with 3mm gaps between boards. Fitting jack rafters between trusses is just insane. You might as well take the whole roof off and move the trusses along and buy a couple of extras. 3-4 packs of 100x25 and a nail gun, be all on in a couple of days.
I did that but the door supplier thinks clear opening can be 775mm. Bco here today so I will ask him and report back. Wish me luck, drain inspection today. -
Is that not very expensive.
UFH manifold cabinet - any point?
No, what for. Build another cupboard for Henry. -
Sliding door aperture is 8mm too high
Russell griffiths replied to Adsibob's topic in Doors & Door Frames
You do worry about some little things, chill out Rodney. I bet you any money you like the bottom brick/ concrete or whatever is not level, the fitters will put the door up on packers to get it level. You just need to mark the exact height you want it and tell them to lift it to that height. TBH your opening is not big enough, should be more clearance above to allow for deflection. -
That’s cool then, my 900 doors are coming down to 812 clear openings. I will double check with bco.
