Everything posted by ProDave
When the UFH was fitted, how much and of what type of insulation was fitted under the floor? What is the floor construction? UFH will never be cheaper to run than radiators. One member on here calculated that even with a very very well insulated floor system and running his UFH at a very low temperature, something in the order of 8% of the heat he put in was lost to the ground. But in his case that was 8% of a very small number.
Combi, Storage Combi or electric shower?
ProDave replied to Rachieble's topic in Boilers & Hot Water Tanks
I find it unfathomable that a house big enough for 3 bathrooms does not have a cupboard or a loft space that will fit a hot water tank. You can NOT do 3 electric showers (unless you have 3 phase supply) even 2 is pushing it. -
None of the above. System boiler with decent size unvented hot water cylinder. -
I had already tried and failed searching screweys for Union, coupler and barrel and failed.
Yep that's it. Thank you. So it's a "socket" As always it's a case of knowing the correct name.
Will someone please give me the correct name so I can identify a plumbing fitting i need. I have two fittings each with a 1/4" BSP MALE thread. I want to join them together. I thought what I wanted was called a coupler, but searching for that does not find it. I don't mind if it's brass or iron.
Vent Axia internal humidity
ProDave replied to Pocster's topic in Mechanical Ventilation with Heat Recovery (MVHR)
We just use a manual timed boost, anything from half an hour to 2 hours, depending how late you shower (don't want it on boost speed at bed time) -
Slate support problem at hip rafter. See photos.
ProDave replied to epsilonGreedy's topic in Roofing, Tiling & Slating
Like I say, I am not a roofer, but the few slate roofs I have seen have all been nailed at the top, just like you do with concrete tiles. Every day is a learning day. -
No you need to take the liners out of the wall and start again. 826+42+42 =910 so it will just fit with the liners tight to the frame with no spacers, and that hopes the frame is square and true. When I fitted mine, i made a gauge just by cutting a spare bit of wood to 826mm long and ensured that fitted between the two sides of the door liner.
Help me to understand GSHP performance
ProDave replied to Benguela's topic in Ground Source Heat Pumps (GSHP)
The big issue with a non inverter heat pump is the high start up current, the DNO's get worried about them, causing your lights to dip when a large direct start compressor starts. -
What choice HW tank for cottage renovation?
ProDave replied to Caddy's topic in Boilers & Hot Water Tanks
No, 22mm or possibly 28mm copper, with a set number of bends and a defined discharge position. I did this myself and the plumber who connected and comissioned the tank was happy, but this was a plumber I knew and with his prior agreement. -
You can buy a Telford stainless UVC for about £1000 Are you really saying your plumber is going to charge £1800 to fit it? That would be 6 days labour at £300 per day to do what is probably no more than 2 days job. Try a different plumber. -
I have never done a slate roof, but I question why the tops of your slates only just reach a little onto their respective battens? I would have thought the top of the slate would go all the way to the top of the batten with the nail hole positioned to put the nails in the middle of the batten? And could the wobbly slate not just have an extra bit of batten fitted lower down to support it's top edge? -
I have never seen ceiling plasterboard fixed just with adhesive. It is usually screwed in place, but in the old days would have been nailed in place.
Decent air tightness is not expensive, it just requires everyone working on the build to understand what they are doing. The issue with dot and dab if not done properly is the void between the PB and the wall can become the famous "plasterboard tent" if the top and bottom are not fully sealed to prevent them venting to a cold loft or under floor space. THAT is where you should be talking to your builder. As this is a conventional block build, I would suggest you plaster straight onto the blocks. Very little to go wrong with that. The main reason dot and dab plasterboard is used is to prevent the need for a plaster skim and it is just taped and filled at the joints.
Tumble dryer question
ProDave replied to iansr's topic in Mechanical Ventilation with Heat Recovery (MVHR)
My thoughts on tumble dryers are well known. They exist to make towels and socks "fluffy" to the satisfaction of SWMBO, and that does NOT mean they have to come out dry. Final drying and drying of stuff that does not have the "fluffy" requirement is done on the airer in the utility room with an mvhr exhaust vent above it. Ours is a condensing tumble dryer and using that breaks my heartslightly less as it's heat stays in the room, compared to one that just blows 2kW of heat straight out of a hole in the wall. Spend the money and get a new dryer, small money in the house building scheme, and re evaluate what it is actually needed for. -
Selecting DHW cylinder for ASHP + solar thermal
ProDave replied to muhrix's topic in Introduce Yourself
I have my hot water in the tank at 48 degrees. That is plenty. That temperature was found by experiment, if i run a kitchen sink full of water using just the hot tap, I can just, and only for a short period, immerse my hands in it. There is no point having washing up water hotter than you can put your hands in. Occasionally if I want to soak something pre wash, e.g. a baking tray with something baked on then that is a case for some really hot water (as you won't be putting your hands in it) for that I run some water from the boiling water tap. I think the Mixergy tank concept is something that all tanks pretty much do anyway. I am happy with my Telford heat pump tank, and I would have thought the twin coil one linked above would do, but go for at least 300 litres.- 25 replies
- ashp
- solar thermal
(and 2 more)
Why do you think you need 3 phase? nice to get if you can but not essential for that size of property. I would go in with 36kVA 3 phase, that would easily do all you want and loads more. If the DNO cough at that, ask them what they can provide. In other words pass the buck back to them.
That statement and the rest of this thread would not encourage me to buy an unservicable unit like this.
Just out of interest how do you change these. They are full of "magic potion" not water. Does it just work in the principle you only change the heater when it is cold and the potion is in the solid state so it just stays put when you unscrew the heater?
Wooden flooring compatibility with UFH pipes
ProDave replied to Adsibob's topic in Wood & Laminate Flooring
Is that flooring "structural"? I very much doubt it at that thickness, so it will expect a firm flat stable base to be laid on. The UFH system does not fit that description on it's own so well need something like ply to provide that base. Our own Oak flooring was bought specifically as a structural floor board and is a lot thicker about 22mm iirc and being suitable to lay directly on the UFH and be a structural board to span the 400mm centre joists was a requirement given to the supplier. -
You want old school heaters, NOT this LOT20 rubbish. An old fashioned storage heater that is nothing but a heating element a thermostat and a pile of bricks would work but almost impossible to buy those new now. For simple panel heaters, a bit less hard to find non LOT20 heaters. The simple plug in ones (that can be wall mounted but not very pretty) are still widely available https://www.ebay.co.uk/itm/334170215917?epid=8033159787&hash=item4dce18d5ed:g:2V8AAOSwjVthWyiX These are available in any number of places e.g are on sale in our local hardware shop etc. I paid about £20 each for our ones.
After 7 years ; moving in ….
ProDave replied to Pocster's topic in General Self Build & DIY Discussion
Well at least you did it in manageable byte sized work packages. And glad to know I am not the slowest builder on the forum. -
I have my (home made) PV diverted connected to a 700W convector heater as an additional load, mainly for when the surplus PV is more than the immersion heater can sink on it's own. It does not come on at this time of year, what little surplus there is easily gets absorbed by the immersion heater. But it is useful mainly in the spring when it is still cold enough to need heating but the solar PV is usually doing well.
