Everything posted by ProDave
Thought this 1960s self-build for sale might amuse
ProDave replied to SimonD's topic in General Self Build & DIY Discussion
Nothing offensive but nothing remarkable either. My first thoughts on seeing the outside picture were "it's a re clad twin unit mobile home" -
F plugs are about 10p each. Learn how to fit them to coax, it is very easy and robust and a quick way of making good patch leads just the right length. A much better connector imho that the old tv coax connector, especially the modern variants of that with a silly little tiny screw to clamp the inner connection to the pin (I much prefer the older, now hard to find ones where you soldered the inner core to the pin)
Yes standard F pugs on the splitter. But rather than use that splitter, replace your simple 1 in 1 out amplifier with a "distribution amplifier" that has 1 input and typically 4 or 8 separate outputs all individually boosted. Edit: post crossed with @joth who said much the same thing.
Loft conversion - minimum height 2.2m - why?
ProDave replied to puntloos's topic in Lofts, Dormers & Loft Conversions
If you loft is currently 2M to the apex then no. Under building regs you need 2M headroom on the stairs all the way up to the "landing" and your present 2M headroom will reduce when you reinforce the almost certainly inadequate "floor" joists there at the moment, and insulate the roof. There are sollutions that basically take the roof off and put a "box" on the roof that is higher than the original roof. They look awful and you might not even get planning permission because of that. -
Nuaire - boost control
ProDave replied to Adam2's topic in Mechanical Ventilation with Heat Recovery (MVHR)
I use this type of timer for my boost switches. https://www.tlc-direct.co.uk/Products/SMSTBT4.html They give a switched 240V output and that drives a small relay that then connects to the MVHR. The details of how to switch your particular mvhr will need to be answered by someone familliar with your unit. -
I would say address that question to your gas safe plumber. If he is willing to install and certify a second hand boiler, then I don't see a problem. All BC want is the gas safe certificate. They are not going to ask the age of the boiler unless it is obviously old and tatty perhaps.
Hi, its good to see an excellent build forum.
ProDave replied to centralLondonJOHN's topic in Introduce Yourself
Boilers and hot water tanks would be a good place https://forum.buildhub.org.uk/forum/139-boilers-hot-water-tanks/ But we won't tell you off if it's not entirley correct. -
Hi and welcome. That's quite an introduction post. Best post your individual questions as separate threads in the appropriate sections. Don't get disheartened about not being allowed to do stuff yourself, there are still plenty of things you are allowed to do, but gas is not one of them. -
Yes and very well done to you for seeing it through with a good result. What frustrates me is we have a government set on a path of slap a bit more insulation in and slap a heat pump in and that's the UK housing stock fixed and carbon neutral. I think they have totally under estimated the challenge ahead that they have portrayed as simple fix. There are going to be a lot of disappointments along that path.
Keep the battens. Fill any void with dry mix sand /cement 5:1 tamped down so it is level with the tops of the battens not above them. Then lay your engineered board fixing to the battens.
That is a lottery how it works. Pre Covid I know the local council tax assessor was visiting our site roughly monthly to have a snoop about, first to see if we had moved into the static caravan, and then later to see if we had moved into the house. That stopped with Covid. It was me that informed the council we had our completion certificate and that triggered the house being valued and us paying council tax on that from completion day. I could have just waited but we figured even if it took them a long time to realise, it would still be backdated to completion day.
Thank you for showing us what is possible. Before this thread I had never heard of enerphit. Now we just need to get the rest of the UK housing stock updated to this standard......
Well done and keep us posted. I keep saying all you need to install an ASHP is a plumber and an electrician who are capable of reading the installation manual. It is not rocket science. But so many plumbers and sparkies seem to shy away from it, and so many people seem comfortable to pay more for a "specialist" company to install it.
Cutting vitreous flue for wood burner
ProDave replied to rh2205's topic in Stoves, Fires & Fireplaces
That on line supplier I think changed the make of the system they supplied so you may not have the same fittings as me. the twin to single adaptor I have the single flue slides up inside the twin flue but there is an additional pipe inside the fitting that goes down inside the single flue, ensuring as you say any liquid runs down inside the pipe. -
Hi and welcome. I suspect that was my thread started some years ago. I caution that mine is an older version than the ones currently on sale and in particular the software and the user control panel is quite different from the current ones to what I have. If you have the newer version I may not be of so much help. Having got to the bottom of and worked around all the gremlins mine is now working just fine and heating my house and hot water nicely. Lets see if we can solve your issues?
Okay so you want to shorten the pipe by 10mm. Are you sure you cannot cut 10mm off the bottom where it goes into the top of the stove? Won't that still leave enough of the reduced section to go into the stove fitting and that would hide the cut end? Yes I cut the black single wall flue but I cut the top end that goes into the twin wall. -
More details? Pictures? where do you want to cut it? What will the cut end join to? Why did you not buy the right length etc. I cut mine with a hacksaw, and the cut end goes into the single to twin wall adaptor and the cut end is hidden inside that fitting. -
And after they have done that, you can connect the new house.......
when I lived in Oxfordshire, still days in winter were more common. In my 1930;s house this had an unwanted effect. The house had an open fireplace that I continued to use for a year or 2 before I modernised things a bit. It had no provision for an air intake, and the actual structure was quite air tight, it was just the doors and windows that leaked. So on a still day, with the fire roaring, it turned out the easiest path to draw air into the living room was in fact down the chimney into the (poorly boarded up) bedroom fireplace, down the stairs and under the living room door, filling that bedroom with smoke in the process. I soon learned to crack a window open when lighting the fire.
- 40 replies
I would agree with all that. The only thing I would add is get a stove with ducted air intake, both primary and secondary, making it a room sealed stove, so when it is not in use, it is not leaking lots of heat out of the house. And position it carefully, so the heat from it can circulate to all of the house, not just one room with nowhere else to go, otherwise you might just overheat that one room. High pressure in winter can lead to stagnant air, so best not to light it then. Most people here have a stove, but the population density is so low it does not stop the lichen growing, nor does it clog my mvhr filters which remain astoundingly clean every time i service it. Another plus point for your list is a totally non automated non electric source of heat that will keep you warm in the event of a prolonged power cut after a winter storm. We used ours for 3 days on one occasion until power was restored (no mains = oil boiler in that house did not work)
- 40 replies
Wire through wall for weather-compensation sensor
ProDave replied to Dreadnaught's topic in Air Source Heat Pumps (ASHP)
A normal UFH system has all the pipe loops connected to a manifold with a circulating pump and temperature blending valve. A standard manifold has provision for a flow meter and an actuator for each pipe loop. Typically 2 or 3 pipe loops make up each zone. If you chose not to zone it at all, all you would be saving is a £10 actuator per loop and a £15 thermostat per zone. It would not save any plumbing. A few actuators and a few thermostats is a very small price to pay for controlability. -
Put a flat screen tv behind a fireplace surround and play the log fire channel.
