Oz07
Everything posted by Oz07
Intumiscent strips and intumiscent paint is the usual solution for this isn't it? What's the regs 20mins on loft conversion?
Where abouts are you roz?
What about just some handy work @nod
Don't understand why everyone has so many problems perhaps I've just been lucky. Let topsoil settle for 3 months or so before turning with good quality turf. Areated de thatched overseeded and fertilized each year jobs a goodun. Last lawn was quite heavily shaded too
Give someone a decent house, and they break it.
Oz07 replied to ProDave's topic in General Self Build & DIY Discussion
Dave I think you underestimate how well educated these forum members are. It fries my brain trying to understand the heating/cooling/hot water set ups some of you lot have! -
Have you got founds low enough down to replace bottom row of icf with normal blocks/bricks. If you come up one course you could trim conc blocks and get it out
All good advice above. Personally I'd mothball after founds but my appetite for risk is low. Brexit definitely having an effect. Stuff is still moving but maybe higher end of market a bit sticky?
New build energy efficiency "must haves"
Oz07 replied to Olly P's topic in New House & Self Build Design
@joe90 stainless wall ties or composite out of interest? -
Interesting thanks. So pipes/ducts covered in insulation then lagged where they come up to meet the unit. Do you have to insulate the unit in any way? What about the ducts which bring in fresh air and expel air?
- 367 replies
- ireland
- timber frame
Air tightness strategy with trussed roof.
Oz07 replied to Oz07's topic in Energy Efficient & Sustainable Design Concepts
No chance of warm roof unfortunately. The wall plate is higher than usual so yes I have room to bring ceiling level up to around 200mm below trusses and still have 8ft ceilings -
Dispute with Mortgage Lender over project?
Oz07 replied to John Cain's topic in Self Build Mortgages
What's your ltv? Hope it's not high -
Makes sense doesn't it. Partial split level works on sloping ground but id prefer to be building upwards all off the same base.
The footprint is tight but am trying to do my best with it. Were talking 900sq ft here and ideally wanting 2 bed, study, 1 bath and separate wc so space at a premium. May be able to fit a tight ish plant cupboard in 1200x750 mm ish if can get boiler and mhvr in here? I did Google and seems to be a bit of can of worms putting mhvr in cold roof but don't mind taking time with detailing if it can be done -
When mixing remember it's easier to add more water. Don't be tempted to put too much in until mixed through. Surprising how little water can take a mix from semi dry to wet
Is your mvhr unit in cold space or heated envelope? Been looking into it lately
- 367 replies
- ireland
- timber frame
Whats the options for dealing with airtightness to MVHR levels when using a fink trussed roof? Single storey property. The loft space wont be useable and will perhaps have 1 access point for any maintenance required. Building is blockwork so trusses will sit on top of a wall plate. MVHR unit to be in 'loft' area My initial thoughts are from trusses down, Smart ply or some kind of airtight ply. Tape around perimeter over wall plate onto blockwork. Parge coat on blockwork to overlap tape. 2 layers of 2x2 conterbattened below ply on trusses to create a void for services so electrical/plumbing doesn't enter loft space and can achieve airtightness at first fix stage without having to worry about subbies penetrating. Tape around loft access point. Tape/seal around MVHR points. Would airtighness board be recommended or is a membrane over the trusses/thin standard ply/osb a better way to go? Are decent air tight loft access points readily available off the peg or is it a case of knocking own up with copies amount of draught excluder as per normal? Would it be easy to seal around MVHR plenium penetrations through air tight? Cheers
Strong small buckets for a pedestrian brickie.
Oz07 replied to epsilonGreedy's topic in Tools & Equipment
I get half a bag cement into a belle drum. Put it in your chosen bucket see where it comes to. Ie top or 3" down etc then just fill bucket up that high with sand. You develop technique of throwing the sand into the drum so not actually that close. As opposed to tipping it in. -
Don't think so. Usually 50mm vent gap for condensation. Boffins will know more than me
Do you mean 8.9 m or are you feeding the 5000?!
Saving Stamp Duty on Derelict Properties
Oz07 commented on Ferdinand's blog entry in God is in the Details
Can we have a summary of why the property was classed as non resi @Ferdinand- 10 comments
- sdlt
- non-residential sdlt
- (and 3 more)
It's not the rates surely it's to do with HRAD on additional properties. I guess it's not applicable to non resi purchases?- 10 comments
- sdlt
- (and 3 more)
I think you could build all in f2 without dpc. Why not put some solid engineerings in if your worried about breaking bond with plastic dpc. At least this would stop rising salts/efflouressense in future
Is smart ply the airtight variety? Are joints glued or t&g or all taped?
Looks smart
