Oz07
Everything posted by Oz07
I doubt it because most mixes are factory produced. I had a look into it last night interesting topic. It seems to be manufactured mortars aren't meeting designed standards. Some suppliers replacing cement with ash (power station stuff) at a much higher rate than reccomended. I think everyone will be safe buying off builders who mix their own!
Or is it reaction to additives in readymix?
Wonder why this is so widespread. Perhaps it is the cement as said. I can get Quinn cement from a local merchants cheaper than anywhere else but don't touch it. May have used on the odd fence post but nothing critical. Can't remember seeing a BS mark on the bag. Sure it complies and I'm sure companies don't set up cement plants producing sub standard product but I'd rather stick with a better known brand. What a consumer I am!
Insulation between suspended timber floor renovation.
Oz07 replied to Oz07's topic in Heat Insulation
I guess most modern roofing felts are vapour permeable? If marketed as breathable that is? Don't like the idea of a dpm/vcl over top of joists. Seems overkill and makes life more difficult. Is a u value of .25 really likely to pose a condensation risk with a mineral wool type insulation? -
As per title I know i've seen this covered on here before. Whats the best way to detail the mineral wool between suspended timber floor joists. Looking to improve u value to .25. Can roofing felt be used, stapled between joists to form a sort of cradle flush with bottom of joists then insert mineral wool then re deck floor? This way bottom of joists still receiving ventilation.
Dunlop was recommended on the job im on. Has still cracked although only has wall paint on atm. Perhaps the oil based will fill these cracks and stay good?!
The tale of the sale of our old house
Oz07 replied to Jeremy Harris's topic in General Self Build & DIY Discussion
I've always found mortgaged buyers easier than cash. Especially FTB they are the best. The problem with cash cash buyers is what they spend on the sundries involved in the purchase is a small portion of their money so they never feel locked in. Meanwhile a thousand pounds could be a big chunk to a 10% depo buyer. As well as that the mortgage process seems to keep the conceyancing wheels well greased. -
Looks great. Not sure about front door though!
Is there no national outline of what is notifiable work and what isn't?
Traditional construction with no special attention to detail i.e. Barriers or tape I reckon you will be hitting 3-5. Below 3 you're supposed to have forced ventilation? Keep in mind the passive lot here will have far better scores!
How do you know which works are notifiable with regards to building regs and keeping everything above board? Looking at a renovation where some works seem obvious to need sign off, others less so. Ie lifting timber suspended floors, insulating below knocking out solid, but non load bearing walls. Opening up load bearing walls with new lintels. Rewire etc I am thinking at the start of the project you just submit a building notice then just show them everything you're doing presumably can't go wrong then? Be keen to hear what others have done. @Onoff @Ferdinand
Pb will rely on a skimmer or filler doing a good job.
- 47 comments
- roof lights
- upstands
Wondered why I always end up with hardwood!
never seen anyone coat a wall plate joint with preservative, rarely see tantalised timber used either (trusses generally not preserved).
Floor Joists: Open Web Engineered VS. I-Joists VS. Traditional Timber
Oz07 replied to Patrick's topic in Timber Frame
Can a 4"/5" hole go in an I joist if placed correctly? -
Never knew that. As in if tennon is 12mm thick then mortise not to be 60mm deep or are you on about length of mortice?
Where do you learn what components are nessecary? I.e. Expansion every so often etc etc?
The main story was on at 0730 if anyone wants to listen back. Seems mainly down to poor workmanship
I agree the pieces of paper are worthless just highlighting the fact they come up as a sticking point in conveyancing so often. Is it possible to obtain a warranty on diy installation if your can prove competency?
Anyone listening to radio 4 this morning. Something tells me in future solicitors will want to see a warranty or some kind of building control approval
Seriously though is it an issue when selling on?
Do future buyers look for any kind of warranty with EWI?
Yes trench with router after cutting with chop saw
Yes most timber sizes are quoted stock. Usually lose quarter of an inch to get it planed up. 4" becomes 94mm 2" becomes 45mm etc etc
