dpmiller
Everything posted by dpmiller
Cat 6 cable. Spare pairs to pinch for leds ?
dpmiller replied to Nickfromwales's topic in Electrics - Kitchen & Bathroom
CPC's cheap RJ45s are great too, never had a problem with them. http://cpc.farnell.com/pro-power/sh-8-007/plug-5e-pack-10/dp/CN11343 -
NO! they're 3-32v dc input. You need the 240v variety http://www.ebay.co.uk/itm/AC-AC-70-280V-240-280V-10A-4-Screw-Terminal-One-Phase-SSR-Solid-State-Relay/121749029973?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649 or similar
Earth to Earth - when not to connect earths together.
dpmiller replied to MikeSharp01's topic in Electrics - Other
nah, keep it connected and keep banging it in until the trip goes ..but best not hold onto it to start with...- 40 replies
- equipotential zone
- earth rod
"all site equipment will be running on transformers" Umm, no, can't guarantee that.- 40 replies
- earth rod
do you really need 16A? Oh, and do you only need one of these? I think some of the MVHR brands have multiple-in interface boxes.
Not a con, but I'm not personally convinced it's *just* as good as it seems.
If you want remote control, the Integra Solar needs no wiring whereas Keylite's electric option is like the "basic" Integra needing mains power.
Never mind the G3 side of things what about looking at is purely as a pressure vessel? Domestic is different to industrial but still...
MVHR pipework camera?
dpmiller replied to readiescards's topic in Mechanical Ventilation with Heat Recovery (MVHR)
you can get chinesium USB endoscopes with long cables. like this: http://www.ebay.co.uk/itm/5-5-8mm-Android-USB-TYPE-C-Endoscope-Borescope-Snake-Inspection-Camera-Scope-/192192521364?var=&hash=item2cbf912494:m:mI6D1kClCUQM7YGrLnf-IIQ -
Try replacing the nut but I'd reckon you'll need to replace the complete hose. When a nut goes off-square like that the threads are buggered.
An expansion vessel is NOT equivalent to a safety valve. What happens when the bladder fails? Me, I'd be removing that brass bung and getting at least a safety valve but better a T&PRV in there.
You'll want a "Loftbox" and here's a really good price: http://www.ebay.co.uk/itm/Hellermanntyton-8-Way-Loft-box-Home-Distribution-Unit-New-/162679742488?
If you really must have an electric, we've had a Mira Advance for some years now which replaced a basic Redring non-thermostatic. I'd heartily recommend the thermostatic option any day of the week, the Mira is rock steady on temp regardless of what happens elsewhere in the house and automatically steps down in power consumption based on your flow and temp requirements vs. CW temp, when it can.
- 17 replies
- 2
- electric shower
- mira
If you're 1.5 storey are you sure it'll be attic trusses? Or are you just room-in-roof? Ours is a true 1.5 and will use a combo of collar and tophat+ cut sections.
what is your mains pressure/ flow like?
- 17 replies
- electric shower
- mira
Have you tried anyone this side of the Irish Sea? Most if not all undertake projects on the Mainland. I've been comparing systems and quotes and for us there's one supplier in particular I like the look of- the frame spec is a match for the best, but their wall buildup is 0.15u factory closed panel and the pricing very attractive. http://www.leadontimberframe.com/
Wavin don't have a problem with compression onto Hep2o. There is a preference for copper olives and you must of course use an insert but it's all discussed in their Installer Guide.
- 57 replies
- ufh
- dhw preheat
(and 2 more)
you shouldn't be using the TRVs for balance, just the lockshields and if they're not shutting down that certainly needs attending to firstoff.
Vacuum cleaner recommendations?
dpmiller replied to Jeremy Harris's topic in Kitchen & Household Appliances
really none, or just hidden inside where you can't see them without dismantling none?- 81 replies
- vacuum cleaner
- hoover
@dogmanDon't think so. They alluded to something with a more standard format, coming at the end of the month?
there's a high-spec inverter ASHP imminent too.
Recommendations for a good structural engineer.
dpmiller replied to Dee J's topic in General Self Build & DIY Discussion
I used a chap from Southampton direction some years back when we were doing our attic- specifically modifying trusses- he used to pop up on some of the forums. Easy to work with and seemed to specialise in small stuff. Recommended, if he's still around:- Andrew Cartilige http://www.rivergate.co.uk/- 12 replies
- design
- specifications
(and 2 more)
At least Kirby machines are solid... it always amazes me that no-one has yet sued the pants off Dyson about that "no filter" thing?- 81 replies
- vacuum cleaner
- hoover
I'm covering all bases sink- wise with a double sink, double drainer. https://www.manomano.co.uk/double-bowl-sink/double-bowl-20-stainless-steel-inset-kitchen-sink-2-drainers-1500-x-480-f01-2256786
