dpmiller
Everything posted by dpmiller
they certainly read well, but beyond that I dunno. http://www.laileyandcoates-international.com/pd.jsp?id=21#_pp=0_477_4
surely choosing to live in an area where the air was cleaner would've been a plan, if it's an issue?
They've had those for a while, I think it's the Lailey & Coates unit, looking at the colour and controller
And we're validated. Edit: crappy link removed.
- 367 replies
- ireland
- timber frame
Roll on the arrival of the FHT stove and it's ability to shift a larger proportion of heat to the water side without compromising the burn.
@richi I used a din-rail timer that I had kicking around and true off is generally the more expensive timer variety, but something like this would do- https://www.aliexpress.com/item/Power-Off-Delay-Timer-Time-Relay-0-3-Minute-3M-ST3PF-with-socket-base-AC-220V/32607096370.html permanent feed to it and the current pump supply signals it.
you want a timer module with the function "true off delay". That's what I did anyway...
Planning application is IN. Including a five page Design and Access Statement which is frankly so well composed it made my jaw drop; thus far, hiring a PC was an extremely good choice...
- 367 replies
- ireland
- timber frame
so the red button locks the actuator Open.
Having watched a number of youtube videos of defrost cycles, I'd say that a heat cycle of 10mins is waay too long and no more than a minute or two of heating should suffice. @JSHarris have you ever watches the defrost to see how much heat is actually needed?
Working out ASHP min COP to beat lpg
dpmiller replied to johny_99's topic in Air Source Heat Pumps (ASHP)
older weather comp controllers for oil aren't much more than an Optimum Start device AFAIK. -
Does your ASHP do weather comp?
so did Kingspan change their specification over the weekend?
Budget wired network
dpmiller replied to Tennentslager's topic in Networks, AV, Security & Automation
We have an Arrow T59 insulated stapler for jobs like this. -
Grease Trap. Don't read this before meal times.
dpmiller replied to ToughButterCup's topic in Waste & Sewerage
these guys do small underground *and* freestanding units https://www.ebay.co.uk/itm/HYDRA-ST3-70L-Grease-Trap-Low-Commercial-Use-470mm-L-x-470mm-B-x-475m-H-/272715158658- 35 replies
- sewage
- grey water
0.5mm 2-core flex ought to do it nicely, or whatever you have. Cat 5 even. The resistance of the NTC sensor will be massive compared to whatever you use and there's practically no current flowing...
As long as there's no massive step-change in daily weather, the normal adaptive turn-on based on historic rate-of-rise should be plenty to look after the seasonal changes for the average system. Likewise approaching setpoint ther's plenty of fuzzylogic/ PID controllers around. In fact, I wonder if anyone has ever attempted to use a standard DIN panelmount controller for room or whole-house control; they generally have a pretty smart Autotune PID system that will sort the parameters during the first heatup and overshoot cycle...
need to force the hysteresis then of that accelerator resistor in the old mechanical stats. Could you put a small resistor across the OP to cheat some heat into the 'stat? Another option for those that don't have great control of the flow temp might be one of the cheapo Chinese touchscreen stats w/ floor sensor- set the floor limit low and it'll override the room setpoint once the heat is into the slab.
@Nickfromwales try looking inside the 'stat and see if you can move the accelerator resistor (heater) closer to the bi-metal...
there's two types- the coarse thread is for sheet metal, but there's a fine thread especially for thick mild steel: http://www.ebay.co.uk/itm/100-5-5-x-100mm-TEK-CORRUGATED-ROOFING-SCREW-HEAVY-STEEL-SELF-DRILLING/221102445632?hash=item337abb9440:m:mi53nBNcz4ub73afwYgp3Zg
OWL start charging a subscription
dpmiller replied to ProDave's topic in General Self Build & DIY Discussion
I acquired a Brita tap a couple of years back, to supply filtered water to the bean-to-cup. It came without any Brita gubbins- which suited fine as I didn't want tied into a specific cartridge. Our water here (and in most of NI) is pretty soft but does drop a clayish particulate out forming a thin hard scale in autoclaves and blocking the sediment filters in the lab RO systems for example. So I'm running through a 5u PP sediment filter and a CTO which cleans it up without making it too "pure". -
just done the update. It's been slowly improving over the last year or so, to me. I'll be interested to see how this goes but it certainly looks "cleaner" on the outside.
Best not to use silicone spray on door seals, it can dry out the foamed rubber used. The right stuff is the wonderful Gummi-Pfledge.
Heartiest congratulations! It looks super, I'm *very* jealous.
/ missed your links up above dave, sorry.
