dpmiller
    4
Everything posted by dpmiller
  1. As things chug along slowly, I think it's time to move house. previously... We're still working our way through the mire that is purchase (Jebus, could Land Registry make it any harder to work out who all has rights over a sight line?) but at least now I've risked getting the planning consultant on-board. No red flags on the Property Certificate, which is great news. I've got some quotes in for the TF already, but it's surprising how many won't quote until Planning is approved. Likewise prices are in for the Shed. So some stuff I've worked out, some I haven't. I can handle the electrical design (RCBOs all round), but I suspect @Nickfromwales will be leaned on for the heating and foul aspects. But firstoff- and yes I'll be asking the same Qs of the PC- what is acceptable to do on-site prior to full approval? The site has had Outline then Reserved Matters, the planning retained on footings which were confirmed inspected by the BCO. Is it likely that we could go ahead with erection of the shed/ garage so as to utilise it for storage and break accommodation during the build?
  2. might want to wait for the FHT stove to enter sale as it's be a handier linkup.
  3. are you within the same exchange- do you want to transfer the number?
  4. the drip bead needs to be exposed I believe.
  5. My el cheapo DMM has a built in non-contact detector with a couple of LEDS. Very useful. Even more useful that the LEDS still work with the meter powered off, and also with either probe live.
  6. clever dog.
  7. Put on the big boy pants today and wrote cheques for the planning consultant and council. Hopefully ony a few weeks from completing on the site now so I'm taking the risk. Plans attached, if anyone fancies a look-see. dorm093-350-Miller-R2-pdf.pdf
  8. Dunno if it's any use, but Virgin Money were happy to remortgage our current house for the purpose of building the new one. Not the same site admittedly, but they're happy with a full drawdown for *any* purpose. Ther were a couple of other lenders my broker tried (I'm self-employed which limits options a bit), the Nationwide were perfectly happy to lend *until* we confirmed the purpose, at which time they reduced the offer by about 20%...
  9. My folks had a bonded bead system(from Shell IIRC?) fitted in the early eighties. Suffice it that the glue *didn't*.
  10. Seen them offered for boats.
  11. You could ring Brett Martin in Mallusk http://www.brettmartin.com/en-gb/plumbing-and-drainage/products/rainwater-systems/anthracite-grey.aspx or Down PVC (great to deal with) http://www.downpvc.co.uk/rainwater.html or online try https://www.directplastics.com/guttering-downpipes/anthracite-grey-gutter
  12. where are your listening positions?
  13. Trying to decide between Tapco and IKO myself. Tending towards IKO based on their larger presence and easier availability. The IKO rep did point out that whilst Tapco might work out a touch cheaper per slate they would be able to help with other aspects of the roof as a package if necessary. I've seen a job with the Tapco and it looks superb. One point of note tho- the documentation for the Tapco makes reference to slight curling when hot/wet, but no such remark for the IKO. Have you observed this @JSHarris?
  14. I've a trade acc at the local factors (and do work for them too, which likely helps), certainly keeps car costs down.
  15. why not just pop into the local motor factors?
  16. Another vote for hot wire here. In a past life I installed and service fume cupboards and BSCs. Recirc (carbon filtered) FCs run at a very low airflow and it's pretty critical for containment. So we needed accuracy and repeatability down to and under 0.3m/s. Rotary vane anemometers with suitable spec came from Airflow Developments (4" rotor) and were pricey but back then (25 years back now) hot wires were ten times the price. Now? what FC work I still do, I use a Testo 405 like @JSHarris has. They were a real game changer when introduced. Heartily recommended!
  17. Same experience here buying the suite that's in our current bathroom. One tap hole or two, mate? Clink there you go.
  18. I'm thinking of going the other way with this- manifold in the GF plantroom with risers to the FF circuits (bathrooms only), bottle air traps on the top of the risers to ensure the loops stay full..
  19. If anyone ever needs to cut loads of nice round holes in thin-ish metals (ducting, trunking, cladding) try an impact hole saw. We've to bring cabling into car paint rooms quite often and the thin panels are a b*gger to put a hole saw through. On a whim I tried one of the Dewalt impact bits and was astonished. Fast, cold cutting with neat edges. Even my wee Makita pencil impact screwdriver (another stunning piece of kit, the TD021) will pop a 32mm hole smartish.
  20. I thought @Onoff meant putting the assy into the bender?
  21. I doubt you'd get the bend close enough to the backplate to squeeze it into a stud wall.
  22. Nick, I've got the bigger version of that window in the current attic. (clambers up stairs) First position on the stay opens it 30mm but there aint much overlap so blown rain would be an issue.
  23. looked at this or similar in B&Q a while back and was quite impressed.
  24. I think Tegral do the same product?
  25. From my reading of the HMRC blurb, VAT can be claimed back on the build of a garage associated with the new residence, as long as it's on the plans. In our case I'm looking at a simple insulated steel-clad shed (to try and fit in with the agricultural vernacular). Would anyone see a problem with supply and erect of such a structure being claimed for or zero rated at purchase?
