dpmiller
Everything posted by dpmiller
If in doubt ask the manufacturer https://www.auto-roll.com/sites/default/files/pdfs/AUTOROLL_DOOR_FITTING_INSTRUCTIONS.pdf
looks like there are two controls on the motor- the blue bits- and I'd take a punt that they are the limit switches.
I've one sitting doing nothing at the moment. Something to add to the forum loan scheme?
P5 Structural deck approval & building control
dpmiller replied to bissoejosh's topic in Timber Frame
All depends on whether the floor is constructed on-site or instead as factory-built cassettes I think. With cassettes the airtightness is lapped round the outside of the floor module before being craned in? -
Modelling the "Chunk" Heating of a Passive Slab
dpmiller replied to TerryE's topic in Boffin's Corner
noted -
So if you don't use'em what'll you do with the ASHPs? -
I'll put a vote in for a Turkington boiler as I've been well impressed with ours (and they don't use a Riello burner, I hate them) and I see they have a system variant now: http://www.turco.co.uk/countrymanpros---outdoor-system-boiler
Woohoo! Consent to Discharge approved!
- 367 replies
- 2
- ireland
- timber frame
Best thing I ever did was acquire a couple of XRP lithium batteries for the Dewalts, they're very long-lasting and pretty light too. Bought both as faulty- one had a broken weld inside the pack(easy fix), the other was discharged far enough that the protection circuit "switched it off" and the normal charger would ignore it. Put a DC power source directly onto each cell for a moment and it then accepted a charge and hasn't looked back.
- 64 replies
- makita
- drill driver
/if they're done right.
When I was looking for my TD021 (7.2v mini impact driver, superb tool) the cheapest was the german site Alternate.
- 64 replies
- makita
- drill driver
Can't see why you shouldn't parallel the SSR outputs in this scenario. In power switching you wouldn't want it as the vague turn-on time would mean that ONE device was handling all the inrush before the others caught up. But in this situation it's irrelevant, the only issue might be trying to diagnose which one was short if there was a failure..
green or blue?
- 64 replies
- makita
- drill driver
or pour off what you can then leave open to air-dry?
On my quote from MBC, frame and founds are two very separate prices.
Ah yes, the AA variant. Gotcha. Still well worth pointing out how important it is to confirm the input as 3-32dc is much more common. Oh and an anecdote from me- those Fotek relays are crap. By various means I've had a number of them recently and the failure rate (either DOA or at well under rated load) is near 50%. Baseplate feels like chromed plastic, really light. Those blue labelled ones (and I've seen'em with a couple of different brands) are much more heavily built and I'm yet to have an early life failure.
racking? https://www.rackzone.ie/workbench/industrial-work-bench-1850x900x800
Build cost regional variations.
dpmiller replied to Dee J's topic in General Self Build & DIY Discussion
where's NI on the list? -
Oops, you're quite correct. Dunno where I got that from?
break into one of the sensor wires and add a pot?
- 13 replies
- ufh actutor
- ufh
I knew I'd seen it posted somewhere- this is the new all-singing offering from ESP. https://www.ebay.co.uk/itm/0-15kW-Air-Source-Heat-Pump-water-heaters-to-replace-Gas-Oil-Boilers-RRP-3-500/112543653959?hash=item1a341fe047:g:r2EAAOSwqhBZpHs1
Either will work for you but the 90deg ones are needed for Agas AFAIK
All but the very cheapest TF quotes I've got have been for 400 centres inside and out.
Bookcase Systems (ideally Oak finish) - anyone with experience?
dpmiller replied to Fallingditch's topic in General Joinery
Billy is SO much better than the old MFI bookcases of the past, really nice real veneer.
