dpmiller
Everything posted by dpmiller
Is this the chance to buy some new tools?
dpmiller replied to MikeSharp01's topic in Plastering & Rendering
I got a 14.4v Makita recently for pretty cheap with a broken battery contact in the handle, charger and two reasonable batteries. Not a hard fix for now (loadsa solder), but I should really hunt down a replacement socket. Anybody have a Makita tool with a duff motor going spare? -
Thermal Solar Panel V LPG Boiler To Heat Water Costings
dpmiller replied to s2sap's topic in Boilers & Hot Water Tanks
I've a small ST system currently- my own copy of a Solartwin- and while it will heat the top of the tank enough for the odd handwash from perhaps April-Oct yes, there's no way it's going to heat the whole tank in other than high summer. My guess is that if you size the system for enough early and late in the year you're going to be dumping boiling water in the summer. It would be nice to do something with that extra, and to have good efficiency under cloud. I'm going PV in our build. -
I'll put a vote in for a submain up the stairs.
Copper versus Stainless Steel Cylinders
dpmiller replied to Triassic's topic in Boilers & Hot Water Tanks
It's an interesting document, and for a couple of reasons. AFAIK UOU Jordanstown has their own energy research centre so it makes me think that the report is more Copper Industries than theirs. Yet CI don't seem to have it on their website and their opposition- McDonalds- do? -
Discount Offers of the Week
dpmiller replied to Ferdinand's topic in General Self Build & DIY Discussion
Dunno if anyone local needs 'em, but I snagged a rather nice wallmount thermostatic bath/shower filler in Lidl Newtownards for a ten pound note and there's a few more left at that price. Score! -
dpmiller replied to Onoff's topic in Bathrooms, Ensuites & Wetrooms
electrofusion? -
No, it would attempt to shuttle at 50Hz and make a horrendeous noise. Contactors, solenoid valves and the like "stick" either because the laminations form a complete coil when closed or there's a "shading ring" acting as a second coil of sorts. Two diodes give you that 25Hz pulse and the diaphragms damp it sufficiently that it isn't clattering off endstops.
I think it'd still work if damp, but your RCD wouldn't like it. IIRC those pumps have some kind of safety contact that breaks if there's a problem with the diaphragm or springs; best check that out with the DMM too when you're probing the coils.
what would a TTRO do then?
Never went ham myself, but did a fair bit of CB in the early eighties. My teenage years had me in the local TV and video repair outfit on Saturdays, and we were also one of the better "legal" outlets for 27MHz stuff. Two of the three Directors of the firm were heavily into the Amateur end tho.
- 18 replies
- surveying
- topographical
what about the more "lightweight" towers from the likes of BPS? http://www.laddersandscaffoldtowers.co.uk/acatalog/DIY-Scaffold-Towers.html
- 13 replies
- lift
- work platform
(and 3 more)
No shed in the existing RMs unfortunately, Dave. PC is busy next couple of weeks but we'll get a site visit organised after that and see what direction he goes in.
- 367 replies
- ireland
- timber frame
Is there a problem with the picture (stitched?), or do the last three posijoists in the bottom pic have a break in them towards the middle of the image?
Do you really need all that heat and consumtion tho- would binning them for LEDs not be a better call?
what are your ground conditions like wrt water table?
can you extend the air inlet to some kind of upstand? The Solido I'm looking at come with just such a thing.
rinse with distilled water before drying completely.
They were, but for a different design.
- 367 replies
- ireland
- timber frame
here's the site with a bit of context
- 367 replies
- ireland
- timber frame
@Declan52 yes, Bing and Google (plus historic views on google earth) show the timeline of the lane construction etc. I found the image above as a hidden layer on the Rivers Agency "watercourse management" mapping. Nice. @Dudda Yes the house design is from Irish House Plans and is pretty much bespoke based on my view of the site and it's surroundings- view, overlooks etc. I'm also using many of the cues noted in PPS21 to make it fit with the vernacular as well as considering the normal planning notes on outbuildings re. sitting behind the frontage and away from boundaries ref height. Hence the position of the garage- a green steel clad shed to fit with the farm sheds around it and hinting at an enclosed yard. Best views are NNW and due South and there's a farm shed behind a stand of trees roughly W.
- 367 replies
- ireland
- timber frame
We're going for a Consent to Discharge into the field drain, and the boundary is taken to be the middle of said drain. The southern boundary also has a shallow drain on our side of the hedge. Our test holes show the site sitting on a mudstone shale layer about four feet down so other than the topsoil it's pretty free draining and looks like a good base for the footings too. Next door built prior to the new legislation so have a septic tank with the drain field on the other side of the shared lane Covenanted to them. I'll be letting the supplier of the Packaged Plant deal with the Consent, and will be having a site meeting with him as soon as we complete.
- 367 replies
- ireland
- timber frame
So this is the site, with a quick sketch of where I'd like the buildings on it. It's an interesting image as it's the only one I've found of when the vendor was doing some level changes... It's a smidge over a half acre. The boundary running SW-NE is a field drain about 5ft deep which runs into a watercourse. Lekky transformer at bottom right of pic.
- 367 replies
- ireland
- timber frame
I was actually considering an extension lead from the neighbour's shed, but that's not without merit...
- 367 replies
- ireland
- timber frame
I'll be gong with a large-ish prefab steel shed, Nick. Somewhere around the 6x10m and insulated. Remote? Yes and no. A kilometre of shared lane so invisible from the road but the site bounds another occupied (recent) build on one side and there's another house a stone's throw from another side, across a lane. Water is on-site (lots of 32mm the whole way down the side of the lane) and there's a phone line alongside it to the other new house (5-pair I believe). Lekky is *on* the site- the supply poles are "my" side of the boundary and the transformer is on the next pole on the other side of the other neighbour's lane. So about 5m from the boundary. It was re-sized during works to that property, and has apparently got capacity for another house.
- 367 replies
- ireland
- timber frame
