Mr Punter
What was the difference in cost between the replacement windows and the ones you are arguing about?
Built in.
Glazing defects.... How picky should I be?
Mr Punter replied to MJNewton's topic in Windows & Glazing
Just ask for replacement panels. Probably much simpler to do before installation. No sure why there should be a difference in shading. Is this low iron glass? -
Yet another superb self build. You could get some temporary downpipe -which is a clear polythene tube - and cable tie between the gutter outlets and the gulleys to keep the rain away from the building.
Tarmac.. yawn Fence.. zzz Hedge... whatever Stairs... Just beautiful!
Roofing options for bungalow with "room in roof" potential
Mr Punter replied to howplum's topic in Roofing, Tiling & Slating
This is all so dependant on the design of the ground floor walls as you will need something load bearing for a 9.4m span or steel supports. Maybe best to get the plot sorted, then a design for the house, then think about how best to build it. Dormers will be far better for your resale value or even a 1 1/2 storey. -
Extractor for Island in double height barn
Mr Punter replied to SB33570's topic in Introduce Yourself
Our extractor is noisy on full and I am now considering having the fan remotely mounted in the plant room above and just using the shell of the hood for grease filtering. I only like ducted. -
MVHR filters
Mr Punter replied to lizzie's topic in Mechanical Ventilation with Heat Recovery (MVHR)
I have only done one MVHR and it did not have any filters in the room vents or extracts - just on the main unit. Have you been having barbecues in the bathroom? -
Hi @D Walter and welcome. You are obviously a fair way into the build now. How did you hear about the ICF system? Is this your first self build? Did you use Surrey Home to do the build or just supply the ICF? It is a bit odd that I have never heard of the system before and it seems to be a one man band operating from a serviced office. Interesting to hear about the blow-out. I had similar with another ICF brand on a basement. I think my men had left out a tie. Fortunately it was on the outside and we were able to shore it between the wall and the excavation and we only lost about a metre of concrete and the bulge in the wall was hidden once back-filled.. It happens frequently but it is a bit nerve-wracking.
Title Deeds Restrictive Covenants
Mr Punter replied to Johnny Jekyll's topic in Party Wall & Property Legal Issues
When / if you sell, you may need to pay the insurance premium for the buyer. -
Latest concrete house on grand designs.
Mr Punter replied to MikeSharp01's topic in Property TV Programmes
I think if the concrete had been better detailed and executed it would have looked OK, but that is very difficult and expensive to achieve. A feature wall or corridor internally may have worked better. The ceilings looked like those at @pocster's place! The finish from the shuttering was poor. I am not sure if the formwork contractor had used the system before but I was not impressed with them. I have seen some excellent concrete work. They could have had timber plank pattern or exposed aggregate. A fail. -
Acceptable tolerances and out of spec windows
Mr Punter replied to Besidethewye's topic in Windows & Glazing
It is up to the supplier to know what size window they are able to supply. It should function correctly. If it went in with a twist it needs reinstalling. -
Yes SIG are excellent and deal with many different systems and will take full design responsibility. You can deal with accredited contractors and get a proper design by and install at reduced risk (although at a price - but at least it will work).
I think you need a proper drawing of this detail. TBH you need a proper professional design and spec for the whole roof. Don't try and design it yourself.
OK does the current approval have a condition saying something like "..the development be carried out in accordance with the approved plans.."? If so, you can do an application for variation of this condition and the fee is £34 for a householder. Just submit the revised plans with the application, showing the new roof covering and a covering letter explaining that this is the only change and the reasons it should be approved.
Those industrial pan scourers should be OK. https://www.ebay.co.uk/itm/Large-Stainless-Steel-Scourer-Tough-Wire-Cleaning-Pads-Washing-Up-Scrubbers-10pk/302825614647
Did you have a planning condition on materials samples (to be submitted and approved etc)? If the only thing changed is the roof tiles - not the solar panel type / colour profile etc - can you not resubmit the new proposed tile?
That cat from Saudi?
I would leave it a couple of weeks, provided there is no way they can chew their way out. If you still hear them it may be time for some bait.
Yes, mortar. They recommend non-shrink but really any will probably be OK. Make it fairly sloppy and gun it in with a pointing gun.
- 14 replies
- soleplate
- timber frame
(and 2 more)
Is the cavity vermin proof all round?
I am not sure I quite get you but if it is not level you will need to pack it up completely level. If you pack under the DPC you will later be able to gun in some mortar between the packers. Do this from both sides to fill any voids. If it is out of line you will either need to do a redesign on the frame or you may be able to overhang the soleplate by a small amount.
- 14 replies
- soleplate
- timber frame
(and 2 more)
You could have 15mm plasterboard, 25mm service cavity, vcl, 140mm timber frame filled with 130mm pir (90 + 40), 10mm sheathing, 50mm cavity and either render board system (15mm) or brickwork (100mm). With the render board system you may be able to reduce the 50mm cavity to 25mm, so for render board you will have 230-255mm and with brick it is 340mm. I think this gives a u-value of about .19 but sometimes it depends who does the calcs and what flavour pir. I think you can claim the service cavity as a low e gap.
Small children getting their heads between the wires is the risk.
Most of the plastic 450 chambers have inlets at 90 deg to the main channel. The outlet has to be from the main channel but you can put a 45 deg bend on it and still rod OK. You can also put a 45 on the inlets, so lots of flexibility.
