Mr Punter
    27
  1. Have you had a quote for this? Might be cheaper to have natural slate.
  2. CARRERA PAINTED Lamproom Grey Classic White quartz 30mm Worktop and upstand Yes, designed and ordered by me Units £2,900 + VAT Worktop £2,900 + VAT
  3. +1 but could be fine for the bondage den
  4. Some pics of the DIY kitchens on our current development - still some bits of snagging remaining but they seem fine.
  5. Fibre cement shiplap may be worth looking at
  6. If the garage is detached and less than 30sq metres you don't need building regs
  7. I am often surprised at what is requested from BC and warranty provider. I have an instance of warranty provider doing a "structural appraisal" six months after the foundations and structure were complete, asking for calcs for piling, concrete cube tests etc. Also have expected drains test from BC only to be told that en email from the plumber confirming that they tested and all was well would suffice!
  8. A Genie lift comes to mind...
  9. Have a chat to someone at SIGA slate and they will advise on what will / should be acceptable and may be able to provide evidence that their solution has / will stand up in Court.
  10. I have never heard of it. Maybe they didn't proof read?
  11. Typo? Could be "for"
  12. All you need for HSE is an F10 form completed, with a copy on display in the site office, as well as a copy of your Insurance and the HSE poster. It is unlikely that they will visit unless there is a notifiable accident on site or someone reports obviously dangerous working. As a minimum, get workers to supply risk assessments / method statements - especially if they are higher risk. Also get copies of insurances and evidence that they have attended H & S training. Also get them to sign in. Give a site induction to all new starters and get them to sign that they received it.
  13. The figures of £2,100 per m2 for the current build was based on gross internal area - just measuring from the inner face of the external walls. It includes internal walls, stairwell etc. , excludes party walls, includes all fees, ex. VAT, some small tools. Excludes balconies and terraces. WRT detached garages, I would tend to exclude these from both area and cost but include if they are fully integrated. Ours was high because we had 25m piled foundations, extensive river wall works, contamination remediation / reports and high quality finishes. @newhome building for £750 per m2 seems astounding outside of a Third World country. Fifteen years ago I think we did some for about £900. We are in the South East though and any trade wants at least £130 per day, many over £200.
  14. Would @lizzie and @Hecateh like to say how much their projects have come in at per metre, inc fees and services? We are just completing a project which will cost about £2,100 per metre. Obviously as with the rest here I am sorry you had such a bad experience and I really hope you will see things in a more positive light a while down the road.
  15. I am keen on photinia. You could also look at eleagnus gilt edge, ceanothus, viburnum and a taller hebe. A bit of a mix can look good.
  16. Are you familiar with the insulated raft type foundation that many on here have opted for? Would it work for @Dreadnaught?
  17. Also check what the fire service requirements are. They sometimes insist on being able to turn around on the site, but are not always consulted at the planning stage.
  18. http://www.strongtie.co.uk/products/detail/safety-fast-hanger-for-i-joist/402 These go over the blockwork, so give lateral restraint.
  19. Yes, get the design and budget sorted. Get plenty of quotes. If within budget, refine, finalise and go ahead, if not, revise spec.
  20. Fine for building regs. Out through the wall and into a stub stack with a long radius bend at the base.
  21. We have DECT with a main and 2 others. I will check out reception range. Do I need a phone signal for this to work? With the cable, I need one with 2 plugs to go in the wardrobe, to plug into the BT and the RJ45. Some of the cables say they are crossover. Does this make any difference?
  22. I have got some CAT 5 cabling in most rooms, running back to a central location. Both ends are terminated with RJ45 sockets - faceplates in the rooms and a patch panel in the central location. In the central location is the main BT socket and internet hub but I don't want a phone there as it is in a wardrobe. There is the normal OpenReach master socket which then splits to internet and phone sockets. I would like to be able to connect the phone side into the patch panel and connect the corresponding wall outlet in another room to a phone. Any ideas what connecting cables I need to buy and where from?
  23. This is not the case in England.
