Mr Punter
This should be sealed on the outside with Compriband or mastic.
When you submit the rest of the stuff for the final inspection (air tests, elec and gas certs etc) you also submit a statement confirming that "Water consumption is less than 125 litres/person/day using fittings approach". You no longer need to do the calculator.
If you want a grass roof it will be fairly heavy and the grass can dry and become a fire hazard unless watered. Probably OK for a shed.
The Lacomet stuff? I think someone here has used it. Lead, installed correctly, is fairly inexpensive and very long lasting.
Diameter of house mains electric supply cable
Mr Punter replied to Pete's topic in Electrics - Other
The actual conductor diameter is less than 7mm, which always seems quite small to feed a 100 amp supply, but I guess the DNO have played this game before... -
It is more likely 35mm2 cable that being the area of the conductor. Your ducting is fine. The cable diameter is about 15mm including the sheathing. -
Really poor when a big firm does not give clear fixing instructions including, size, type, location and spacing of fixings. Get in touch with their technical dept as it is their job. I think it was owned by a different firm when we used it and I think I remember them having a fixing spec.
Go for 15mm.
Try Knauf Soundshield Plus as it is also tougher / harder and holds fixings better. They recommend it for schools etc. Out dryliners used it so I don't suppose they paid over the odds v. normal DB board.
What do you think?
Mr Punter replied to canalsiderenovation's topic in New House & Self Build Design
With the balcony, look carefully at floor levels as you will need insulation and this will probably need to be a warm roof construction, so a step up onto the balcony. Also as others have said, look at making the balcony 2.6m deep and give the 900mm to the bedroom. It is not much of a technical challenge. I really liked the roof lights to the balcony in your inspiration house. Any chance if you post more plans you can upload pdfs? It is quite hard to see otherwise. -
But well done for soldiering on. Follow what SIG say to the letter. If you are not sure what is specified, bat it back to them.
That is good as the rubber membrane looked fine, just the detailing and drainage. I imagine that just removing the build up as you have will halt the water ingress.
It is looking better with each iteration. I would lose the back door and have this in the living area - maybe bifolds or sliding. Extend the worktop and return a short 900mm deep peninsula so you can still have the breakfast bar. The kitchen units backing onto the internal wall are likely to be tall - fridge / oven / larder type. Perhaps make the dining area slightly bigger.
How far have you taken this down? Is the membrane under the stuff we can see?
Are they doing it on purpose!!!
Mr Punter commented on recoveringbuilder's blog entry in Recoveringbuilder
Take note @Onoff! -
Greenbelt PD and Special Circumstances
Mr Punter replied to CADjockey's topic in Planning Permission
Perhaps you can do an application showing the extent of the existing building plus PD dotted overlaying the replacement dwelling scheme, so it can be seen that the replacement is a similar scale, massing etc.- 3 replies
- special circumstances
- pd
The upstairs rooms will look mean unless they are 4.0m wide. What is the upstairs corridor for? Family bathroom looks wrong. Can you show adjacent ground level on elevations and sections? Lose the extra furniture in the bedrooms as it is distracting (beds, bedside cabinets and built-in cupboards only).
Siniat Bluclad has standard installation details and BBA cert with Weber renders. I have used it with the Weber but we just used Weber LAC - mesh coat and top coat - sponge finished then masonry paint. No cracks or customer complaints after 8 years.
Cold bridges - suggestions on ways to deal with them?
Mr Punter replied to Digmixfill's topic in Brick & Block
If you want to keep the brickwork exposed there is not much you can do. If not you could use insulated plasterboard. -
*rant* pre-application timescales *rant*
Mr Punter replied to Moonshine's topic in Planning Permission
Most planning depts are understaffed and underfunded. Round here they charge for pre app opinions. I can really understand your frustration. An outline application will probably take the same time to determine as full. Also, in some instances, they will only entertain a full application. -
WARNING. ICF AND AIR BRICKS
Mr Punter replied to Russell griffiths's topic in General Self Build & DIY Discussion
Four days work? What was the risk? You can have a ground bearing slab with no airflow at all, so what is going to happen with B & B with a slightly restricted flow? -
If there is still a gap and you have air bricks on all sides I would not worry. They should still be fairly OK at the ends, just narrow in the middle. If you had to do this again, what would you do? -
OK. Make sure you specify the max deflection must not exceed 8mm or 0.002 x span. The standard is 12mm which can feel a bit bouncy. 2 stairs?
I am helping from afar by focusing all my thoughts on its death.
At least you wont get people trying to wheel shopping trolleys along there.
