Mr Punter
    27
  1. You need to be pretty handy with the tin snips for cutting Lindab and fitting outlets. Saw or grinder is a no-no as the rough edges rust where a clean cut has less surface area and will heal with galv.
  2. A risky request...
  3. I thought this was just the frame underneath, not enamel applied to the glass. If enamel was applied to the top surface of the glass I agree that it should have been shown on the plan view.
  4. I am not sure what you mean @craig. The sections look fairly clear and they show upstands, the metal frame, the single pane inside the upstands, an air gap, and the larger laminated glass pane that fits right up to the edge of the frame. The plan view shows the laminated glass shaded and I think that had it also showed the frame underneath it may have caused confusion. Perhaps an additional plan from the underside would have been sensible. I would have liked some annotation on the drawing and some titles and I am not clear on what "B.U" stands for. I am not clear if this drawing was the extent of the information sent out.
  5. Mr Punter
    Getting slated
    Reclaimed slate? If so do you have enough for the whole roof?
  6. I must say that the woman doing the presentation in @scottishjohn's video was rather captivating!
  7. I think this is a grey area and just gives an example of when this is standard rated, not when it MAY be zero rated. For me it makes no difference as we run this as a business and can reclaim the VAT in any case, but we have always been charged VAT for SIs. I have spoken to HMRC before re: zero or reduced rating and their take is that it is up to the supplier to apply the lowest applicable rate.
  8. VAT charged 20% on ours.
  9. Give him a chase - email then phone.
  10. I have a friend who does a fair bit of student lets and rarely has issues. They are jointly and severally liable for damage and repairs and in some instances also for the rent. In any case, parents are obliged to act as guarantor. The sort of behaviour by @pocster's tenants would be more in line with an emergency housing / hostel setup.
  11. With the Velfac system the outward opening ali sash is the same size as the fixed internal timber frame, so if you rendered up to the window you would not be able to open it and nor would it drain correctly. Their detail is to render the returns first, then the window size is the render-to-render size minus 12mm per side and top, and 20mm for the bottom. The window is then fitted with a 15mm cill packer at the bottom and fitted in the opening. The gap is sealed with foam on the inside and Compriband externally. Double check all the measurements as it is easy to mess up.
  12. To be fair to her she did well. She has a better aim than me!
  13. Make sure that in the event of a blocked outlet the water will flow down the stairs, not through the doors.
  14. The rigid full fill boards are a bitch to install and the chances are the brickie will lash them in however they can - upside down, wider cavity, gaps or whatever.
  15. A bit of a change in the weather from setting out to pouring the slab!
  16. If that is the finished value you will need to be very careful that your total costs do not exceed this. There are lots of areas where savings could be made but I think you may need a bit of a redesign. There is currently a lot of wall, window, roof (and scaffold etc) in relation to floor area.
  17. How does the render work with the ICF? You could do the top bit in timber frame with an aluminium coping.
  18. Mr Punter
    Stairs
    First fix one day for 2 chippies. Would take me 2 weeks. Would take @Onoff 6 months.
  19. Done correctly it will have a door either at the top or the bottom of the new staircase and will have an escape window Velux or dormer. If it is not intended as a habitable room and is only classed as storage or hobby space, building regs are not required. If it is a bedroom they will need to have a completion certificate and failing that they must not advertise it as a bedroom.
  20. And I assume there are bifolds running the length? If so, there is not much you can do. Put lots wherever else and make sure there is lots of ventilation through any cross walls. Oh and I don't know what system you are using but @Russell griffiths had some real issues on an ICF with the concrete squashing the telescopic vents.
  21. No I have recently done a development with lots of external doors, full length windows and windposts and the number of place we could put vents was very limited.
  22. Brighton introduced an article 4 direction for certain areas that they thought were overrun with students, so you need planning consent for HMOs https://www.brighton-hove.gov.uk/content/planning/planning-applications/planning-permission-houses-multiple-occupation
  23. Is this a shared house, where the tenants know each other and are jointly and severally liable, an Airbnb, or what? How much is the rent? In nearby Brighton you cannot do HMOs without planning consent (which they rarely grant).
  24. I read recently about their new Pilingmaster - can go 14m and 600 dia!!
