Mr Punter
Stud Walls - and Floor Structure
Mr Punter replied to Big Neil's topic in General Construction Issues
18mm ply is acceptable at 600 joist ctrs. -
It is safer to have the floor in as a working platform. If you later need extensive access it will be from the ceiling below. -
12.5mm or I like 15mm which gives (I think) the same protection as 12.5 Fireline. I have recently used Knauf Soundshield Plus which is tougher than normal board and good for fixings. I imagine the dry lining firm got a good deal on it, as our spec was just for 15mm acoustic.
Does the installer have insurance?
The DIY Kitchens I have bought for seven houses averaged at £205 per kitchen unit / £2,690 per kitchen.
Perhaps apply to get the wording changed to "shall be covered using slate matching that quarried from a source within the National Park" What was the stated reason for the condition?
You need to find something to match and base your application around this. If you cannot find it you will have to go with the local stone.
Can you arrange collection?
You can apply online for variation or removal of a planning condition. It may be worth seeing what the alternatives are to see if you can source something similar from, say Spain and discuss with the conservation officer. Can you check the planning register to see if the condition is applied throughout? Also if your building is very focal or near a listed building or otherwise important area you will be on more sticky ground.
I asked for WiFi recommendations a few months ago and five members recommended Unifi. I put in 2 AC Lites and the whole of my 4 storey house is covered seamlessly. Pretty simple to set up and works very well.
I would ask the stone slip company what board, adhesive and fitting is covered on their BBA certificate (if they have one) because otherwise, if anything goes wrong, they will have a get-out. There are lots of boards on the market, like BluClad, which can be used outside. Building boards are sometimes called Calcium Silicate, Magnesium Oxide, Backer Boards and various others but you really need a spec from the slip system manufacturer.
Are the roof windows top hung? They may do well to increase the fire detection to 1 in each habitable room, corridor and staircase, mains fed and interlinked.
Building regs implications on planning / external house design
Mr Punter replied to Moonshine's topic in Building Regulations
B and K -
Financing Self Build In Parents Garden
Mr Punter replied to Johnny Jekyll's topic in Self Build Mortgages
Hear, hear. -
Sometimes it takes the stain better if you leave it for a year or two. It is fine left exposed if it is Western Red Cedar. After two years you will probably just get used to it!
Timber Frame with Knauf Render System mortgage issues
Mr Punter replied to Rusty's topic in Timber Frame
I think you should be fine with the battened cavity, and the system is BBA approved. The render systems that have been more troublesome are those with no cavity, incorrectly applied. As the house is completed there is no need to mention self build and don't offer detail that is not required, so when they ask for what the building is constructed of you can say rendered walls and tiled pitched roof.- 12 replies
- render
- timberframe
- (and 7 more)
I noticed the other day that Screwfix seem to have changed from Flexovit to Norton.
How to stretch 6 m to 15m
Mr Punter replied to Russell griffiths's topic in General Self Build & DIY Discussion
Sounds awkward but I am no expert. The beams are quite sharp so chains would be best but you will need to see how to attach the chains to the telehandler. We have slung beams with chains for crane lifts. You would need to have the forks quite high to account for the chains and you don't want to be driving round with the forks extended and a load on them. -
It will mellow / fade fairly quickly. Are you going to do the edges too?
Get the material powder coated to the same colour as the cill. Maybe cut it into 200mm lengths and space at 220mm centres to leave drainage gaps.
I cannot see an issue with this draining onto the patio.
@Hecateh How did the other guy know about where you live and who you had chosen to lay the flooring?
Party Wall Act and Utilities
Mr Punter replied to Temp's topic in General Self Build & DIY Discussion
I can't see how the PWA would apply because the water company are not an owner and I assume the land owner has no right to refuse the work being carried out. -
If this is excavation within 3 metres of and deeper than the bottom of the foundation of the adjacent building it could apply, but I doubt it as the water company are not an owner. The adjacent owner would need to take out an injunction to stop the work, which would be very expensive.
