Mr Punter
    27
  1. It depends a bit on your joist depth. You could consider fixing battens to the sides of the joists at the bottom to support the insulation. You would do better with a polythene sheet on top of the insulation as a vapour barrier because the tape may not want to stick properly.
  2. This is only an external deck so BC will not get involved. As @markc says, you can get special screws for hangers but they are pricey.
  3. Use a slightly thicker bed and a course of bricks. You can use multiple lintels to get the width.
  4. Unless you can have a gap of at least 500mm it is better to build up to their wall. There should be no need for a cavity wall. You could build it in 140mm blockwork. Gives you a bit more space.
  5. But that is not what happened. Both went up and both should come down.
  6. Looking at the drawing the bungalow looks more like about 85m2 rather than the 150m2 you mentioned in your first post. This will reduce the cost a great deal and you may well be able to achieve this within your proposed £200k budget.
  7. The short answer is no, the budget will not be enough. You will need at least £300k.
  8. You can get monopitch ridge tiles.
  9. The Ancon stainless ones are expensive but decent spec. They seem to work by making them easy for the SE to specify and the builder to install. They have slots for wall ties and different top connection options. Once they are built in they act in tandem with the masonry. We have lots where there are just skinny piers between openings that would otherwise fail.
  10. By the time someone has broken through toughened laminated glass they will have made a terrific amount of noise. I recently had to assist a neighbour gain forced entry through a triple glazed window by breaking it. Took a while and was quite a racket.
  11. I cannot see why this would not be acceptable a little larger. Make the floors the same size and get rid of the step in the roof and the kink in the flank walls. It will be simpler and better thermally. I would make the footprint 400mm shallower and 400mm wider and have a normal pitched roof. It will help mitigate the increased ridge height. Don't sink it down to the extent that you may have drainage / damp / flood issues.
  12. British Standard BS8621 Dead Locks have a thumb turn. If you are not replacing the door or the lock I don't see why it would apply to you. The front doors we fit on new build either have thumb turn or just door handle to open. It is also an NHBC requirement.
  13. A friend of mine does access control including automatic gates. He likes to use FAAC gear for the gates and Videx for the intercoms. There is a lot to go wrong and a lot of rubbish out there and he does not want callbacks.
  14. The stairs do look very good. Could you figure where the wires could go to make them acceptable? They may have been better under the on the inner face of the string on the left hand side as you go up.
  15. I think you need to approach the manufacturer and installer. Something is not right.
  16. I like 2 x 1 battens fixed with long screws and plugs through 60mm PIR insulation. Finish with 15mm plasterboard. Gives a service void for cables pipes and sockets. Either foil tape the joins or cover with polythene.
  17. That gives you 1 in 50 which should be OK.
  18. A bit like buying a printer cheap and getting shafted on the toner. LPG is massively expensive. We once had LPG and it was cheaper to switch the heating off and go out to the pub.
  19. Sewer pipe is smooth plastic with no obstructions and laid to a consistent fall on a firm bed of shingle. Flat roof are built with timber joists and OSB sheets, which can twist and sag, supported on walls that can settle, with complicated junctions, upstands, verges and outlets. Often there are trims or leadwork added at the point where the water should run off. There are a couple of flat roof puddle threads on this site at the moment.
  20. The point is that people change flooring throughout the life of a building and on the bottom step 13mm will not matter. A thick carpet and underlay or some wood flooring can be over 20mm. All you will do is piss off the builder.
  21. Make sure you have firrings to give a fall of at least 1:40. Not much will bond to expanding foam, but as the gap is only 12mm it won't matter. Dress the vapour barrier up the parapet a bit.
  22. On an early project I bought a bungalow with consent to replace with 3 houses. A friend and I stripped out all the timber. We got someone to strip the roof tiles free. They were only concrete plain tiles so I am not sure why they bothered. We burned all the timber in the garden. The trick was to get the fire burning very hot. Not acceptable now, so I guess it just goes to landfill.
  23. 10mm is normally tolerated but they are very unlikely to pick up on this. It is better on the bottom riser than, say, mid flight. If you were to carpet the stairs and have vinyl on the bottom landing there would be no difference in rise anyway.
  24. It makes little difference where you are if you are in England the building regs are the same. Maybe get quotes from people based somewhere less affluent, although I am not sure where that would be. Mansfield, County Durham?
  25. The upstand is fair enough. Neither GRP or felt look very good. As per @SteamyTea I would have thought felt on top of the GRP. I assume you re the GRP and your neighbour is the felt?
