Mr Punter
    27
  1. Were those basalt wall ties expensive?
  2. Outside looks straightforward if you just bring the paving level up adjacent to the door and have an ACO type channel level with the top of the cill.
  3. You will need to do some maths here to find the sweet spot between internal area, cost of footings, cost of wall ties and cost of insulation. A 150mm cavity gets a passable u value with platinum blown beads. Use thermally broken cills and lintels. Use Marmox or Foamglas course at the base of the internal blockwork.
  4. Is there any way you could post a sketch of the section through the threshold? Do you need to adjust both inside and outside levels? If this is not actually going to be used for wheelchair access you could just bodge a transition ramp that is later removed.
  5. The inner leaf masonry where the door is connected runs into your house with no breaks. That explains the front door noise. The top hat should be resilient bar. The stair may be fixed to the masonry.
  6. I have used blocks to make up levels. It is quite time consuming as you need to lay them flat and butt them up as tight as you can. You will need some MOT to finish it. If you just scatter the rubble you will end up twisting your ankle or falling over on it.
  7. I have had some measured by OS mapping.
  8. It is worth contacting either a concrete pump firm or a nearby concrete plant to see if they have someone to recommend?
  9. I agree that with Velfac the Compriband is easier with bigger gaps you can get your fingers in, or dry fit the frame, remove, apply tape, chuck back in the hole but on a hot day with a heavy window it can be tricky. I have used a wide blade scraper to help.
  10. Ask him where it says that in the regs or what standard he is working to. BS EN 752 only refers to minimum gradients as do all the warranty providers. The only time steep gradients are an issue is with systems with slotted pipe to allow infiltration to the ground and systems where you need to control the velocity before entering a treatment plant.
  11. It just gets silted up if on clay
  12. But I think the OP wants line, not level.
  13. Depends on the soil type. You don't want the pipe clogging up and I guess the graded thing should stop this. Depends on soil type. In heavy clay, most land drains fail over time because they clog up. I have seen lots of examples of old pipes completely blocked with clay. Regarding fall, as long as the pipe does not get silted up it is fine to lay level if it is sited low enough and has a gravity outfall.
  14. As a more simple but slightly bodged solution, fit a drainage channel in the gap with a downpipe going through upper bit of the wall with the decking on it and dropping down by the bins. Make sure it is set slightly lower (5-10mm) than the driveway paving and seal the paving and channel with decent mastic. If the gap is not wide enough you may need to cut down the paviours or rotate them.
  15. If you had a French drain against the outside of the wall and a route for the water to go it would improve things. You would need to remove the course of charcoal paviours and dig down to the garage floor level. While there you could apply some external tanking. You would need a pipe so that the water could be directed to a drainage point where the bins are? Does it properly flood or is it just the bit of seepage?
  16. Maybe crushed concrete, Leca, EPS? Work out the area and the required finish and see if it would work within your budget.
  17. Plenty of big contractors have their own SEs and will get them to value engineer the design to remove the unnecessary bits. If we have got to the on site stage and something comes up we would approach the engineer with our suggested design and ask if would be acceptable. Normally I try to do this at the design stage, before I have paid their invoice! I recently got some ground floor slab mesh changed from 2 layers of A393 to a single layer of A142. The ground is hard chalk. The site is really restricted and I didn't fancy hefting heavy mesh about that was not required. They also removed at our request a lot of steelwork from an earlier design that would have made demolition / temporary works very awkward. I do agree it is not sensible to just ignore what has been designed.
  18. You could remove the suspended timber floor and install a new fully insulated solid floor.
  19. I only ever see water bar in a basement. I often see SEs wasting client's money on pointless items or impractical details that end up being adjusted or omitted on site.
  20. Please tell me you don't need to go back to planning with the changes?
  21. Absolutely no idea why there is a water bar specified. A complete waste of money and resources.
  22. Can you drive in a stake nice and upright either end then use them as a sight line for the intermediates?
  23. Why not just submit plans to discharge the condition that show the existing driveway being retained as is?
  24. If the chamber is outside it is a matter disconnect mains, open the lid, pull out the pump, which will be attached to a chain or rail, disconnect waste pipe and cable, connect pipe to new pump and cable to mains, drop it back in and switch on mains again. You may like to take a shower after, or at least give your hands a quick rinse, before you go out to dinner with that nubile secretary from accounts.
