Mr Punter
I think there is a rule of thumb that the cantilever length should be less than 1/3 of the supported section.
Beam and Block and DPM and floating floor
Mr Punter replied to SillyBilly's topic in Floor Structures
You should have a polythene vapour control layer on top of the insulation. The reason for this is because there is a risk that warm moist air from the house could get through the gaps between the insulation and condense on the beam and block. Quite unlikely but ho-hum. -
1. You should use the same batten to join the 2 boards. You may find that 25 x 75 give you a bit more meat. If you use separate you may get cracking between the sheets. 2. The settlement tends to be in the floor zones, as timber shrinks a lot across the grain. Not so bad with engineered joists but there is still often a 38mm locating plate and top plate, so could be 8mm shrinkage. If it is only 2 storey you could just go straight over. 3. With the windows, run 25 x 50 batten round the perimeter. Cut the vertical battens for the renderboard short of the opening by 100mm top and bottom so there is no dead zone for ventilation. There are no gaps in the board. The ventilation should be from the bottom and out through the top. Mesh at the bottom and the top, unless it join into the roof vent void. You should fix a fire stop between storeys but this would need to be intumescent so as not to interfere with the ventilation on the rainscreen. Expensive and it often does not get installed on site. As it is not Grenfell you don't have too much to worry about.
All house prices have risen around here. There are more buyers than sellers and most of what is on the market is either crap or sells straight away.
The meter is normally very close to the incoming service head. Moving the service head is expensive and needs to be done by the DNO. You may be able to change the meter to a standard tariff one F.O.C. If you are certain you want the kit in a new location and it won't get in the way during the works you may as well get it done now. A new consumer unit should be safer and will be easier to reset.
Agree 100%. Only a serious accident, death or being reported by someone will prompt a visit. Even then, as long as they have not been stupid or expected others to take avoidable risks they should not have any issues.
Planning extension or 'commencing' the works ?
Mr Punter replied to Cookiecutter's topic in Planning Permission
I meant put in the foundations that do not need a Party Wall Award, like for the new end wall.- 10 replies
- planning permission
- party wall
(and 2 more)
https://resources.hse.gov.uk/convictions-history/case/case_list.asp?PN=1&ST=C&SN=S&SF=IS&SV=2&SO=ADN Mostly these are investigated following an accident, fatality or report from a worker or the public.
You are legally obliged to comply with and assist HSE and fully answer any questions they have. If they pay you a visit just be as helpful as possible and immediately implement any recommendations. If they choose to prosecute they have a very high conviction rate, and the majority will plead guilty to the breach (when they realise that the penalty will be more severe if found guilty in court).
I think a fresh planning application may be the way I am afraid. I don't think there is any mechanism for extending the period. Another option could be reduce dig the footprint and to dig and pour the footing at the end. You may need to cast in some rebar to connect up later to the footings which require the PWA.- 10 replies
- party wall
(and 2 more)
3 but all are FD30 weight.
I think your chances of success depends on what was quoted for and agreed. If you only asked for a wear layer of tarmac you may not fair so well. If you asked them to excavate to a decent subgrade removing all vegetation, lay 150mm sub base, 50mm binder layer and 25mm wear layer then you are in with a very good shout.
How to get my stair design to comply with regs?
Mr Punter replied to Adam2's topic in Building Regulations
They will if they work as bricklayers!
House is overheating
Mr Punter replied to Savage87's topic in Mechanical Ventilation with Heat Recovery (MVHR)
It is not ideal and may be noisy in the rooms below. The outside unit spits out hot air via fan, compressor and condenser. You may need the loft to be extra ventilated. -
How to find a roof leak that has gone away?
Mr Punter replied to ProDave's topic in Stoves, Fires & Fireplaces
Is that a blues song? -
Well you smelled a rat and you were right. Time to find a new team. Is there much work to do? Maybe your job can be fitted in by another firm? Does your bricklayer know anyone? Can you get any recommendations?
Sadly bricklayers don't see it as their job to install insulation correctly.
Standard, I am afraid. If they were reliable, eye for detail, professional and well organised they would not be working on a building site. Fixed price may be better. They may be more incentivised if they are earning well.
Is it worth paying £9000 more for better U value
Mr Punter replied to Happy Valley's topic in Windows & Glazing
This will help a bit if they are south facing, but not 100% Here is one we did with an 1800mm overhang, south facing picture at 13:15 on 20 April and the sun is still halfway up the windows: -
You need checked reveal cavity closers. These come without the flange on the brick side. You normally need to run a DPC down behind the brickwork.
Definitely no and I think you should get at least 2 more quotes. If there is a difference of £9000, what were the actual quotes? I have found that overheating is a bigger deal in a new house than heat loss. Look at reducing the glazed areas if possible, especially in bedrooms.
