Mr Punter
Yes, take at brick out. Could you also insulate the pipes? Wot Nick said
You can do them in shorter lengths and pack under the bits that need to be fatter with some timber.
Windows not quite as expected - distortion issue
Mr Punter replied to Adsibob's topic in Windows & Glazing
I once had some very big 2g units and the panes had touched in the middle so some of the coating came off. Had them replaced. Get the rep out to look. They will try to swerve but you will get a feel for whether it is acceptable. -
Partitions: Timbers studs Vs Metal C studs
Mr Punter replied to MortarThePoint's topic in General Construction Issues
Do you charge a higher rate to fit the Habito? We used Fermacell on some flats a while ago. Never again, but the Habito looks good. -
https://www.screwfix.com/p/turbocoach-coach-screws-yellow-zinc-plated-8-x-120mm-50-pack/52740 You can sink the heads in 10mm with a spade bit. 3 ply 45mm = 135mm. Your 90mm will not have any embedment in the 3rd timber.
I don't think there is much in it. Use whatever you have. I understand the soil pipe may be more UV resistant than the below ground.
The metal I studs are a fair bit stronger than the C studs, if you want a freestanding wall. We used it to line a tanked basement. The metal frame guys can put the stuff up very quickly. I / we can't. -
Pumped waste design for kitchen sink and dishwasher waste
Mr Punter replied to Adsibob's topic in Waste & Sewerage
I don't think the noise of the water will be an issue at all. More likely to hear the water as is goes down the sink waste, not once it is in the pipe and running steadily. -
I would run the waste right to the end of the kitchen units in 40mm. It looks like there is a void or some insulation behind anyway. Run it to a decent fall. I don't know where the drain is outside in relation to your plan. 23m is not a particularly long run. if you know the invert of the drain we can let you know if you can let gravity be your friend. -
The breather paper is normally stapled to outside of the panels so I suppose you could build panels on the ground, breather paper them and lift them into place. A bit of fiddling where they meet. I think it is most useful for weather protection before the external cladding is complete, so not really that important for you. With your inside membrane, do this as carefully as you can. Return it into windows and doors and down to the floor. If you can marry it up with floor joists, even better.
- 1 reply
- house wrap
- building paper
(and 2 more)
100% appeal. If you post up the refusal letter and anonymise it you may get some useful suggestions for the appeal. The planning officer report can also prove useful.
Sand / cement screeds (which you have) are normally 60-80mm. Liquid screeds are 40-60mm. Either one is fine with UFH. 30mm is too thin. Are the UFH pipes embedded in the screed? How are the levels at doorways etc?
- 17 replies
- screed dips
- cracks
Why not just use a buff colour mastic sealant?
Been waiting 14 pages for this and the pipe has sunk like the Titanic. Jesus what a let-down! Let us just say that @pocster may be left wanting.
Luxaflex Blinds for Tilt and Turn Windows
Mr Punter replied to canalsiderenovation's topic in Windows & Glazing
They have similar on Naked Attraction! -
Garden with overage - splitting deeds?
Mr Punter replied to Ben Weston's topic in Introduce Yourself
Overage will not impact the mortgage, especially as it is at the end of the garden. There are millions of titles with restrictions on development, whether because they are in a conservation area, listed, have planning conditions, have covenants or overage. All fine for mortgage purposes. -
Yes screw from the outside 3 each end. You can level this with packers. If you really want to you can use mortar later to fill any gap. I assumed that insulation etc did not matter as this is more like a shed / garage. Can you run them down the outside? Use stainless ones? Def need straps. If you want them inside you can use galv and fix a timber noggin to the rim board to make up the 50mm ish and fix to that.
Often a warranty is worthless.
I am not sure how this will work. Does the WC waste from the family bathroom go round a 90 bend and all the way out to the corner? Is this in the floor zone or boxed in? The rodding eye in the corner of the bath looks hard to access.
Velux install - Roofer insists all parts of kit not needed...
Mr Punter replied to LW123's topic in Skylights & Roof Windows
That is really no way to refer to sex workers! -
Yes. You would need to pack to the same as the other batten. I would either do all in 75 or all in 50. Should be but you need to get confirmed. Often you also need some insulation 30mm? under the SIP roof. Probably yes, but does not happen. I have used Envirograf in the past on 4 storey. Expensive.
The flat roof Velux installs are not the same as pitched roof, but the windows may have some components that don't get used. More info please on what window, is it on a kerb? Did you supply? Is he re-covering the whole roof? Photos. -
Help Please - Glass Window Ledge - Too Big
Definitely easier to sand down some plaster. If you accidentally gouge a bit out you can always fill it. -
Recommended foundation method for Clay soil nr trees
Mr Punter replied to JD44027's topic in Foundations
NHBC have the foundation depth tables where you have trees. https://nhbc-standards.co.uk/4-foundations/4-2-building-near-trees/4-2-13-foundation-depth-tables/ They used to have a calculator as well but not sure if they still do. Bear in mind it makes no difference the current size of the tree (unless being removed). The calculation is based on the full mature tree, so if you have a small willow or oak nearby I suggest you remove it before BC are invited to site. -
Carefully mark out the rim board and pre-drill clearance holes for the joist locations before you lift it up. Staple DPC to the bottom edge of the rim board. If the rim board lines up with the outside edge of the blockwork you will have 50mm to rest the joists. Fix the joists with some of these https://www.screwfix.com/p/turbocoach-coach-screws-yellow-zinc-plated-8-x-100mm-250-pack/8533x
