Mr Punter
    27
  1. I don't see why you can't. Is there a clear path for the airflow?
  2. I have bought a site in the past and the consented house did not fit. It was out by a fair bit. For clarity you could mark up your plan with a minimum clearance measurement to the boundary. We have done this in the past for clarity, as the neighbour claimed that we may not build to plan.
  3. Would a carbon tax on gas and a corresponding subsidy on electric persuade people? I wonder if 5p per kWh would have a significant impact? It would more than double the cost of gas, but you would save a bit on your electric.
  4. With a hole saw I made a 38mm hole in the base for the hockey stick.
  5. It depends whether what they have written inaccurately has any planning merit.
  6. Can you get a tent and get one of the kids to sleep in it?
  7. Maybe start with the worst rooms. Just single split systems will work fine if you have space outside. Don't attempt the full install yourself - as @ProDave says get an F-Gas qualified engineer to do the pipework and commissioning. They may be happy for you to supply and mount the units and do the prep work, arrange correct electrics etc. The A/C supplier may give you some contacts.
  8. Because you have a detached house, the rules now allow you to build a very large single storey extension without planning consent. One benefit of building single storey is that it won't cast such a big shadow over the garden. Would it work out to have a very large family room at the back and perhaps repurpose one or two ground floor rooms as additional (en-suite?) bedroom(s)?
  9. The work needs to be done neatly and carefully or it will look crappy. Obviously it won't match the neighbours. By the time you have arranged safe access (scaffold) are you sure it is worth it?
  10. Not sure how the prices will work out but you normally have aggregate either delivered in tonne bags via hiab or tipped - 10 or 20 tonne. I have only used a grab lorry to take away unwanted spoil. The crushed concrete is fine for a subbase but the crushed limestone type 1 MOT binds together much better and could almost be a finished surface after it has been rolled. For price, ring round a few places.
  11. I don't think you will get a meaningful amount of insulation in there. How wide is the cavity, and is it clear from obstructions?
  12. Sparky fitted an 80A fused switch in the kiosk with meter tails. He will run SWA sub main underground from the fused switch to the consumer unit location in the property and connect up when we want it to be permanent.
  13. Where we are they (UKPN) like a GRP kiosk. I got one of these https://www.ebay.co.uk/itm/192594789689 and have a CU in there for temporary site supply and it will be made into permanent later.
  14. Be warned that bamboo can be very invasive. As others have said, you may be better screening the areas locally rather than attempting a high barrier at the boundary. A well planned layout with a pergola and some focal points and trees, shrubs and paths will be lots better. It can take a while to establish though. I did this one about 25 years ago and there is a very large building all the way along the left hand side.
  15. With soleplates, steel column bases etc it is normal to get them in place then level them to the correct height with packers and then fill the voids between packers with structural grout or dry pack. I would have thought the same could have been done for the doors.
  16. The planting on the bank looks good. Are you paving in front?
  17. You would need to ask them. 50mm insulation won't quite do it for existing but it will still make a fair difference.
  18. If there is no insulation in the roof you may want thicker insulation boards but this can impact on the eaves and abutments.
  19. I have smooth Ipe hardwood decking on Iroko hardwood joists. No slipping at all. I doubt they will rot any time soon.
  20. All you need now is some cement!
  21. Slates are sitting nice and flat. What type are they?
  22. Looks absolutely bonkers and destined to disappointment.
  23. I understand it needs to be toughened and laminated as there is no independent handrail. I think the minimum thickness is 13.5mm but check with the supplier. When they do a system they normally have all the calcs to back it up.
