Mr Punter
Fire Resistant Windows - what are the regulations?
Mr Punter replied to LeanTwo's topic in Building Regulations
If W18 and W19 are each less than 1m2 and at least 4m apart they will be acceptable. If the floor above W16 is a compartment floor and less than 1m2 it will be OK. If not, you may need special fire resistant glass (expensive).- 12 replies
- fire resistant
- window
What the appeal decision gives are the reasons for refusal. The inspector will often not take account of a number of reasons for the original refusal by the LPA, so this can give you a narrower target for a new submission. From what you have reported you will need to focus on the gaps between houses. Did your proposal close up the gap more than your neighbours? If you give a link to the planning application and appeal we can have a look.
You could build the columns out with timber and clad them in the same horizontal stuff as the house, using the metal corner trims. I have done this on some details and with the trims it looks OK.
How to deal with difficult builder?
Mr Punter replied to Adsibob's topic in Project & Site Management
Agreed. Typically shown as dashed line on plan, with member key speccing section size plus detail drawings of padstones, foundations and connections. Length and height not specified but can be worked out from architect drawings. -
Contractors insurance (requirement for)
Mr Punter replied to Hastings's topic in Self Build Insurance
As a builder / developer I get a contractors all risks policy and this covers everything. It seems to cost about £1 in £1,000 of completed cost per year, so if we do £4M GDV we are up for £4k premium. All subbies need their own policies too. -
As long as the revised plans address the reasons given for refusal you should be OK. If you have gone through an architect I am surprised they were not asked by the planners to make some changes, rather than a straight refusal.
A concrete lintel may be simplest. The height of the lintel depends on the opening width. They tend to be the equivalent of 1 or 2 bricks high. You can just sort out the arrangement of bricks to suit the height you would like the lintel to be set at.
Recommendations for powerful canopy extractor
Mr Punter replied to Coffeepotclaire's topic in Kitchen & Household Appliances
I have a fan mounted remotely which is quiet and effective. You can get weatherproof ones as well that go on the outside wall. -
You can either use a core drill with SDS or just break out a hole big enough and foam around and fill with sand cement.
You may need a bit more insulation as well. I would be wary of timber cladding on timber frame for insurance / mortgage / resale reasons. The Cedral / Hardie type stuff can be a better bet.
Zurich are a very large and well regarded insurance firm. In my experience, none of them will pay a claim happily.
Anyone good at interior design and mixing wood tones?
Mr Punter replied to Adsibob's topic in Decorating
Mahogany and Satinwood have traditionally worked well but I imagine they are not on the menu. Not sure of your budget but I have seen some fantastic reclaimed parquet type flooring. Probably well over £100 / m but it would look fine with other wood furniture. I don't think wood "clashes". -
It is sometimes a good exercise to draw in where the airtight layer will be, then consider how it will work at all the junctions. Your airtight layer could be polythene or plaster but it really needs to be contiguous. The first option looks easier to achieve for insulation and airtightness. The bottom one looks pretty flaky.
Remove the bottom row of tiles and fix a board to this. Run the roof covering up the board under the tiles. Ideally your flat roof insulation should be going on top of the rafters so you may need to strip 2 rows of tiles.
I am not clear on how it would be possible to install a cavity tray in an existing wall, other than when the wall is opened up and a cavity tray is put in above the new steel. Anyone?
Why does this ceiling need to be airtight? For sound attenuation, the walls will make no difference. It is the sound vibrations from the floor above that you are trying to minimise. You also need to avoid flanking sound through gaps between the ceiling and the wall, which is what the mastic and plaster will do.
Why don't you install an external staircase then just carry the stuff down...
Brick, Mortar and window colours
Mr Punter replied to crispy_wafer's topic in New House & Self Build Design
It is well worth getting an actual sample of the materials and looking at them together. Mostly they will send them out for free, but even if you have to pay it is worth it for the peace of mind. I find it surprising how long someone will ponder an item of clothing or a duvet cover yet go for external materials on a house they have not seen. -
No you definitely need an electric one. Like this https://www.hss.com/hire/p/htc-gl270-grinder or https://www.hirestation.co.uk/tool-hire/Building/Floor-Grinder-Hire/130040/
You could use a zipped standing seam like Kalzip or Rigidal. They do roofs for huge buildings. You can just have a big gutter at the back with, say, 3 downpipes. I have used these on a couple of projects.
Bonkers idea or a great idea?
Mr Punter replied to canalsiderenovation's topic in Landscaping, Decking & Patios
Sheet piling you could cut them in half and push them in with a digger bucket. They would be strong with the corrugation. -
Dry-ridge vs mortar roof on Victorian House
Mr Punter replied to jpcamps's topic in Roofing, Tiling & Slating
They are not different types of roof, just a different way of securing the ridge tiles along the top. The rest of the roof is exactly the same. From the ground it is difficult to tell which you have. The big difference to how the roof looks will be in the type of covering, where large format concrete tiles will look more modern than, say, clay plain tiles.
