dpmiller
Currently
Viewing Topic: Floor tiling on suspended chipboard floor - do I do same again...........
Everything posted by dpmiller
Macerator pipe run
could you pipe from the loo- boxed in- accross to directly under your soil and then go straight up? Saniflow might need dug into the screed a bit to get a fall to it.
Automated lighting and lamps
As I was using Klik ceiling roses, I've used Klik wallplates for the remote-switched lighting .
Can anyone help me :)
PiR and service void on the inside.
5mm acrylic lucite vs steel for baths
Aren't all acrylic baths backed with glassfibre? Our 20yo cleapy corner bath does. Another vote for Trojan here, I paid the few quid extra for the Trojancast upgrade and it makes for a very solid-feeling bath.
Transport planner won't object to increase in traffic despite saying the road is dangerous
it's a cul-de-sac so a dead end with no through traffic, how busy could it be?
Bricklaying prices
...but they've got a "trade" John. Guys like you and me that do mission-critical, life critical stuff? meh, *anyone* could do that, dont ya know...
- Timber Frame Supply - Recommendations
10 hour working day
You get all sorts. the guy that did our groundworks works consistently 8-3. Works like a trojan, god help you if you get in his way. The Eastern European fellas that did our insulation worked two jobs, 8am-9pm every day. I do about 5h the average day (plus paperwork), but some days will be on the go for 17-18h, mostly driving but all chargeable.
Triple Glazing
your battery's a bit low...
Two breather membranes on roof?
I think they're saying the roof is ready to be battened and to get a move on as there's nothing much holding the felt down?
German fancy kitchens
I resemble that comment.
Finished yet?
When will be moving in? "last year".
Preparation for UFH
they do have wifi as well...
Electricity connection - your experiences
what provider? Some *really* don't like internal meters.
Tilt and Turn Blinds
I must admit I'm drawn to the Day-and-Night striped roller blinds (as SWMBO detests venetians) and they'd be pretty handy in Perfect Fit form for the french doors.
UFH - Multiple Floors - Single Manifold & Pump?
I've one upstairs loop running from the GF manifold. I've a Tee at FF level on both flow and return with an autobleeder a few feet above on each. Flows fine, bleeds fine.
Consumer Unit Arrangement
how is earthing dealt with?
- Qubev. EV Charger
Washing machine raised units
^ the downside of modern Big Door machines
Heating, Hot water, ASHP, and Sunamp Design Needed
A self-installed sub £1k unit would seem like a no-brainer to me.
and down off it every time the engineer calls?
Rules on LPG cylinder positioning?
Yellow Calor butane cylinders are still very popular round these parts
regulator size is one issue, but flow rate at low temps with Butane is a known problem. Not so much Butane used any more tho...
When do G3 regulations apply? Buffer tanks?
250 bar litres, IIRC.
I'd have to say no, not G3 *but* still requires a safety valve as it's still a stored-volume pressure vessel even if the supply temperature is controlled externally and failsafe. /just like a radiator on a sealed system. The pressure/volume may make it a "pressure vessel" but the rest of the system has redundant controls for temperature and the safety valve is the failsafe for the expansion vessel's pressure control.
