dpmiller
Everything posted by dpmiller
I'd heard too many negatives about Munster and just went round the local upvc options.
fancy windows or ordinary? I couldn't justify more than ordinary, and Turkingtons looked after us well.
Passing flue through wall / roof
dpmiller replied to markocosic's topic in Stoves, Fires & Fireplaces
I used Ignis Protect on our build and it's a pretty handy way of filling a hole in the frame. -
Recessed thermostatic shower valve stupidity
dpmiller replied to Pocster's topic in General Plumbing
/there's a reason I went with cheap bar mixers... -
Confused by Triple Glazing Justification
dpmiller replied to MortarThePoint's topic in Windows & Glazing
upvc works fine for me too. Isn't it tru tho that a poorly- designed 3g unit can be bettered by the best of the 2g options? Without going to "fancy" frame options (aluclad etc) there's only so much depth to work in and filling the 2g's airgap with another sheet of glass doesn't leave much space... Other than the asthetic of the more expensive frame options, are we not into the realm of diminishing returns as with other insulation thicknesses? -
throw them in the back of someone elses car then and go to the nearest garage (or whatever) and drop them off. there's generally a set price for cylinder returns.
isn't most double sided tho? Ridges/ grooves?
Is that inlet sitting above a flat roof? I'd be even more worried than normal about wind effects...
Well I've not ordered any stoves yet but will most likely be going with a Woodfire Passiv as the primary unit; at the other end of the house it'll probably be something LPG. We're lucky in that both chimneys are on outside walls, it was easy to core through into the starter chamber at the bottom of the stack at the requisite height for the supply pipe.
As much as we're not using too much hot water yet, I'm definitely glad to have two immersions in the tank and on the diverter. Top element is halfway up and is satisfied by lunchtime these days, the bottom element destratifying the tank after that. / but like @ProDave if I was doing it again I'd have another pocket right down at the bottom.
Architect has done a wonderful scheme but-
dpmiller replied to DragsterDriver's topic in Surveyors & Architects
did he accidentally put your name on someone-else's plans? -
Find someone locally that does bar and hotel work, that kinda thing is their bread and butter...
A thought to kick-start the week.
dpmiller replied to ToughButterCup's topic in Other Heating Systems
doesn't the synchroinverter just imply grid-tied tho? Surely then the more reliance there is on inverter-based generation, the *more* stable the frequency becomes as inverters are current sources and would fight to hold-up the speed of any remaining rotational gennies. Swich off all the rotating devices and tie the all required DC-AC machines to a single centrally-located stable frequency source. -
Bpc upgrades - would you recommend?
dpmiller replied to eandg's topic in Mechanical Ventilation with Heat Recovery (MVHR)
does the unit have a humidistat? You might need a means to put it into boost mode after a shower or a serious toilet episode. -
the expensive ducting is slightly more flexible Do you need a controller or is your unit going to be easily-accessible? Do you require manual boost-request switches? -
Conservation Area Glazing Bars on Velux Triple Glazed
dpmiller replied to ashthekid's topic in Windows & Glazing
I'm pretty sure the conservation glazing bars indeed *are* stuck on? They certainly are on the VLT access window at our current house... -
Aren't pipes in slab just a different name for a storage heater tho. -
GSHP, Buffer tank and UFH
dpmiller replied to Fraser Lamont's topic in Ground Source Heat Pumps (GSHP)
is that the flow or return temp? -
Are there no thermo mixers on the manifolds? -
Switchable power to every room?
dpmiller replied to puntloos's topic in Networks, AV, Security & Automation
@ProDave how do you look after a lollipop on the EIC? Just ignore the "stick" and pretend it's a normal ring final? -
Are palm nailers not frowned upon now because of the vibration?
Proposed garage (car maintenance) in the field opposite my house
dpmiller replied to newhome's topic in Planning Permission
recovery services with government contracts certainly do need secure storage. -
Quick and easy Q. for the gurus- does anyone know of a flipper panel that is less than 300mm? Ideally 150 or 200. Not picky on thickness as I haven't ordered the main panel yet. I want to chicane a walk-in entrance to the "corner" of a 1400x900 tray and 300+ 600 feels a bit tight...
