dpmiller
Currently
Viewing Topic: Floor tiling on suspended chipboard floor - do I do same again...........
Everything posted by dpmiller
Down the big long lane...
a few days in and the screed is pushing out a shedload of water again, MVHR has gone into humidity override. Consumption is about 40kWh/day, slab at 22c/ GF 19c/ unheated FF bedrooms 17c. I'm currently running in series/buffer mode, so heatpump flow is going through the TS before heading to the UFH mixer, I've got the heating/buffer sensor strapped to the return pipe after the UFH and bypass, and the ASHP is controlling on that. Flow and TS are both 37c at a setpoint of 30c
Bang/loud click from Radiator
Is the radiator clamped tightly in it's mounting brackets? If it is, try loosening a couple a touch.
Salus Auto Balancing Actuators - Problems!.
what wiring centre do you have?
- Down the big long lane...
- Samsung ASHP Gen 6. Antifreeze cycle
SAP fail mainly due to walls
IIRC the GSE trays are not much over £30 each, the hold-downs and tekscrews a couple of quid each, and the flashing is worked out per perimeter. And a panel is about 1.5m2... The only other thing you need is some 4x1 to screw down onto in the right zones.
fitting is easy, especially if you don't need to extend the 5m pre-wired sensors and controller. I did run into one slight problem, the inverter has shown the RCD out at the meter box to be dodgy. it's a 100mA type-S but was tripping out when the compressor was started. I rechecked it with the multifunction tester and while the circuit's RCBO is tripping correctly at 30mA and holding in fine, the type-S is going at under 80mA so something aint right with it. I've linked it out for now... Software seems simple enough, there are a couple of fan and pump modes I want clarification about, and I didn't have any hassle getting into the hidden installer menu. Performance? So far... 4c ambient yesterday, thermal store raised from under 30c to 55c in about an hour and a half, which confirms it's 7kW+ in these conditions. I've left it on overnight at a setpoint of 26c for the slab, and my chinesium wifi stat is telling me that the hall is now at 14c and rising, from the 9c it started off at yesterday
Mastic wall hung toilet
yep, it's used for removing bonded car windscreens too.
the TF guys did the walls and round the openings, I did all the ceilings and slopes... OK so I'm doing something a wee bit odd for the CH/DHW. I'm using a 270l manual-fill thermalstore, direct to the boiler stove and indirect to the ASHP etc. Makes the boiler stove a useful member of society and means I can heat the whole house during a power failure just by running a couple of CH pumps. And yes, outages aren't that unusual round here apparently. Also means I can use the bottom quarter of the tank as a buffer.
- Connecting hot to WC
No, just a wee battery powered low current valve, switched by a motion sensor. this kinda thng, but I'm looking for one with adjustable timing. Most do two short pulses, some are variable https://www.aliexpress.com/item/32848350151.html?spm=a2g0o.productlist.0.0.4fe43820q2WQ3f&algo_pvid=1cbe2c9a-6d06-4c72-850b-1f700474f92a&algo_expid=1cbe2c9a-6d06-4c72-850b-1f700474f92a-46&btsid=2100bdd816117404856013770e9c73&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_
Extension- Last Stuff.
I'm of that mind that if you don't let it run CONTINUOUSLY for about three days you don't actually know what it's doing. Cost and noise be darned, at least you could say you'd done it then.
