dpmiller
Everything posted by dpmiller
6 are SE, 6 SW, and one of those is shaded by a chimney which is the dip at 3pm. Plus sticky-out gables get in the way a bit too. But still, it's production the whole way from sunrise to sunset.
- 367 replies
- ireland
- timber frame
so the East-West panel split seems to be working well. With apologies for the dip around noon, I've been having problems getting the DTU to receive from all the inverters happily. But I think I've found the sweet spot now...
- 367 replies
- ireland
- timber frame
coal store/ larder or such?
gonna bring this back from the dead. Just got some guys that have done some for me previously to price a bigger amount of work- looks like about £10/m2 inc scrim and beads, I'm supplying the skim. Reasonable?
Willis (Belfast) immersion heater problem
dpmiller replied to bigfish's topic in Boilers & Hot Water Tanks
where does the bottom of the Willis connect to the tank? Looks like it's circulating in the F&E pipe instead of the tank... -
Drilling Through 11mm Thickness Steel Beam
dpmiller replied to NewToAllOfThis's topic in RSJs, Lintels & Steelwork
I'd go with Clive's hole saw option. Less material to remove... -
who owns the walls, and what height is the ground behind them?
safest not exporting the earth eh?
So, this heat pump thingy... One of the advantages of getting all the kit up and running is being able to monitor and if necessary reconsider things. And so after a couple of weeks running we came to the conclusion that the two bigger upstairs bedrooms- both North facing- did need radiators after all. Pipes were already laid in so a quick trip to Screwys for a pair of 600x1200 double convectors and... done. I raised the flow temperature from the ASHP to get meaningful heat and paradoxically this has improved economy. I'll probably need to explain that bit. So I'm trying to be all things to all men without using any fancy control strategies. Flow from the heatpump passes through the TS at all times. But when there are no demands the TS coil is gated/bypassed, to stem any convective losses. Return from the TS is available to both the UFH and rad manifolds. If neither of them demand, an autobypass ensures there's still flow. All the pumps stats and zone valves are on a separate RCBO to the ASHP so that in emergency/power outage the heating system can run off the TS- heated by the boiler stove. The ASHP controls on DHW tank temp, and also on buffer/ return temp. It has programmable hysteresis and overshoot for each. The upside of this and fitting the rads? Flow from the ASHP is naturally higher than return so more energy into the bottom of the TS. The ASHP setpoint is 32c (return) but the flow could be up to about 40c to get it there. Hence the TS now has enough energy in it to impart heat to the house. Nice. And the extra heat in the two upstairs beds means no cool air falling into the hall. Even nicer. TLDR: That extra energy means that the TS actually buffers, so the HP is running less and longer. Whole house is at an indicated 19c but the slab heat makes it feel much warmer. Almost too warm already... and that's at a consistent 10kWh/overcast day and cool night. Clear sun is already getting the top of the tank up to 75-85c on the diverter and on days like the the ASHP consumption is down at around 5kWh. And I've finally got the monitoring software set up for the PV. Yay! Took a while but we got there...
- 367 replies
- 3
- ireland
- timber frame
heat pumps need a much smaller differential across their heat exchangers than a boiler, and it takes a lot of flow to make this happen.
gotcha. Locally, Jim Lynas is pretty fair too.
Who was that @Conor?
related to the heat. there's a brownish tinge to the Live entry on the socket.
Moulded plug syndrome... seriously tho? the heater takes a fair bit of juice and there's a degree of heating and oxidising at the contacts of the fuse due to this current. This is a vicious circle- heating reduces the springiness of the contacts in the plug, makes more heat, causes higher resistance, which makes even more heat... it's why it's worth taking a look inside any plug that is on something over a kW, every now and then.
I'm sure a number of the cheaper options are just re-brands, different colours or valve handles.
Starting first Fix - Manifolds and pipe types etc
dpmiller replied to Conor's topic in General Plumbing
the 10mm works fine, as a data point we've more DHW flow at the new place at the end of 10m of 10mm @3bar, than the gravity flow down half that length if 22/15mm at the current house. -
it's the power device on the heatsink thad actually drives the motor, the trigger is for reversing and speed control.
Help with abutment gutter
dpmiller replied to James94's topic in General Self Build & DIY Discussion
https://www.leadworx.co.uk/shop/chimney-flashings/lead-back-gutter/ -
measure it up and get it made up off-site. -
diagram shows the 32 fitting inside the bit that's got a jubilee clip on?
Cleanable Waste Chute next to cutting board
dpmiller replied to puntloos's topic in Kitchen Units & Worktops
...as long as you're on mains sewage. -
hot and smelly.
Woodfire Passiv or CX8, Opus Calypso or Parkray 80B https://www.stovesonline.co.uk/direct-air-supply-stoves.html/all_fuels/all_brands/all_styles/boiler
could you pipe from the loo- boxed in- accross to directly under your soil and then go straight up? Saniflow might need dug into the screed a bit to get a fall to it.
Automated lighting and lamps
dpmiller replied to MLR1907's topic in Networks, AV, Security & Automation
As I was using Klik ceiling roses, I've used Klik wallplates for the remote-switched lighting .
