dpmiller
    4
Everything posted by dpmiller
  1. A "normal" internal stud wall has no diagonal bracing (plasterboard doesn't count) but adding a layer of OSB braces all the studs together.
  2. electric rotavator.
  3. Can't find any MIs for the Willis, but looking at the label on this example implies horizontal fitment http://www.pdplumbingsupplies.com/products/rohs-external-immersion-heater-also-known-as-a-willis.html
  4. Another option, which offers some extra control options: https://www.advanceappliances.co.uk/product/151-plug-n-glow/
  5. Look at the region between 18 and 21 as an axample, the bead looks like it's just sittng ON the surface. Not hot enough to melt the base metal. You want to see a smooth transition for base to filler, possibly even wth a narrow dip where the base has melted. Have a look at the other side, and if it looks anything like that, whack the plate with a lump hammer and see if the paint cracks over the welds.
  6. what's the other side of the plate like? The penetration looks dangerously poor on that side.
  7. dishwashers use the incoming cold water as a condenser during the drying phase so expect wet dishes if the supply is too warm. Likewise if it's a washer/dryer, but at least in that case there tends to be a specific condenser water supply valve so you *could* pipe cold direct to it.
  8. In truth I'd already picked the kit and never given any thought to E7. But in trawling PowerNI's site recently looking for new connection info realised the standing charge was low enough to make it worth thinking about.
  9. I've got a similar conundrum. I'm happy enough to go for the PV, but can't quite decide whether mains supply needs to be on E7 or not. PowerNI's rates aren't bad- 15.56 day 7.92 night and a standing charge of 7.7 (that's before any discounts that I'd likely be under the threshold for) vs a best 24hr rate of 14.59 I'm thinking an early morning recharge of the TS- either by immersion or ASHP- would be pretty good value on the E7...
  10. There's a Yardmaster at the end of my Dad's garden that we built- with no battery tools, slowly- thirty five years ago. Still in near-perfect condition and rock-solid. Conversely, I put up one of the cheap Canadian Arrow steel sheds that Argos sell six or seven years back and I'd say in another year the roof will be porous. Absolute rubbish in comparison.
  11. Bought a used paslode 350 when doing the attic, runs well on cheapo ebay gas and Hitachi plain nails, Recently tripped over a Dewalt second-fix gun (for the old batteries, matches the rest of my stuff) seems OK so far.
  12. a tone generator and sniffer is useful for this. Like- http://cpc.farnell.com/extech-instruments/tg20/wire-tracer-tone-generator/dp/IN07182?st=tone generator
  13. Ask Kingsspan? Do you have all the other necessary install bits? If not this pricey option might not me such bad value- https://www.ebay.co.uk/itm/KINGSPAN-AEROMAX-12KW-AIR-SOURCE-HEAT-PUMP-INSTALLATION-PACK-KHP0030-ONLINE-778/162942848059?hash=item25f0268c3b:g:3ZEAAOSw~e5ZPr8X Bud I think someone opined that 22mm was plenty for loadsa kWs so maybe just reduce that 1 1/4" down to suit a more standard part.
  14. waterless trap? Might not survive the temp of an actual failure discharge but it might be a price worth paying.
  15. watching the promo video, would a single big isolator for the whole house not be handier than turning all the other stuff off?
  16. Got a price from a local assessor to do as-built from my design figures, and carry out the blowerdoor test, all for less than £300. Filed away for the future...
  17. Aye, and I totally misread the OP. Thinking about FD30s...
  18. try (gently) popping the rocker off the front, likely the screws are underneath it. /edit yes, looks like that's it. comparing the ebay image of the rear to an image of the socket version of the series, there are two screws diagonally, each where there's a circle inside a square on the back of the backbox.
  19. There's got to be a batching plant closer to you that offers the service. I think we have four or five within a five mile radius here.
  20. Dragging paint PCs out from behind spray booths in bodyshops, I'm probably the winner in terms of pure dust. House dust OTOH can be a lot more greasy and fluffy in my experience.
  21. compressed air is your friend.
  22. dpmiller
    Radon
    don't think DPC or radon barrier is certified for a tanking application tho.
  23. Went through the same process using LoopCAD. Looks like around 6.5kW for us for -2c/20c.
