dpmiller
Everything posted by dpmiller
Timber frame kit or bespoke build?
dpmiller replied to Jdyer's topic in New House & Self Build Design
We trawled the many "book plans" sites over here and when we found one that we quite liked, the designing Architect modified it (quite radically, an almost complete redraw) to our brief. Various TF companies then quoted against that. -
How to deal with a noisy sewerage treatment plant
dpmiller replied to joe90's topic in General Self Build & DIY Discussion
Soft foam everywhere. Set the pump on foam, line the housing, sleeve the airhoses if they're near/touching anything. -
and just to confuse further, "inverter" HPs are internally 3PH but at variable frequency.
Humidity and MVHR
dpmiller replied to lizzie's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Rather than a steamer (high power consumption) try an ultrasonic unit. Maplin used to do them for fog over water features but you can get standalone too. See for example: https://www.ebay.co.uk/itm/1-3L-Ultrasonic-Humidifier-Air-Room-Diffuser-Steam-Purifier-With-7-Color-Light/142721319238?hash=item213ada8146:g:TdAAAOSwk4tapWRz https://www.ebay.co.uk/itm/DC-24V-Ultrasonic-Mist-Maker-Fogger-Humidifier-Water-Fountain-Pond-with/253483323394?epid=2076907171&hash=item3b04c89002:g:yRoAAOSwKvJapXmu -
Well my particular examples are absolutely silent, even with the driver sitting against the radio in the kitchen that is bothered by our current MR16s.
^ agree with Nick. Ordered some 6W variants to appraise and they're stunningly good. Even, glare-free light. Dunno about anyone else but as they're alloy body and steel backplate I'm happy to accept them as fire-rated too.
Does anyone have experience or opinion on these units? Smart-looking controller and the MIs read well, but are they worth a punt? VIGO 550.pdf
Traumatise the wildlife? Definitely! Well, if we want to, all the windows *are* openers...
- 367 replies
- ireland
- timber frame
So the official confirmation letter arrived yesterday. Planning conditions are few, and simple, and just as per the Officer's report: Start within five years Obscured glass for the bathrooms Landscaping following completion Access works pre-commencement (yup, like already eight years ago) No conditions re levels or ridge height is a bonus. Digger man and his mate called on Tuesday and we've a plan of attack. A couple of land drains to put in (one new, along the short E boundary with the nighbour's garden and one to culvert the long open drain on the South. Then strip and retain topsoil and put down crushed reclaim over the drive and form clean hardstanding. Still waiting a revised price for the TF...
- 367 replies
- 2
- ireland
- timber frame
MVHR - flies!
dpmiller replied to readiescards's topic in Mechanical Ventilation with Heat Recovery (MVHR)
well if you've tried adding bits of foam and stuff, it'll definitely be your fault. -
The Build - Oak framed car port
dpmiller commented on Redoctober's blog entry in Our Journey North of the Border
now that's pretty. -
Is it not more conventional to bring soil pipes up to floor level for the wastes to drop into?
- 5 replies
- passive slab
- raft
this a 2-wire 240 uninsulated, and there's nothing at the base of the poles on our land.
Dragging this one back up... We'll be on a pole transformer via an overhead, so definitely only TT. NIE's favoured position for the meter box makes for tails well in excess of 3m. What's the neatest way of protecting those tails suitably? Switchfuse then 100mA -S RCD? Or does someone know where you can get an 80A/100mA type S RCBO? And as it's in the box with the DNO's stuff, the housing can be plastic rather than AMD3?
Electric towel radiator getting too hot
dpmiller replied to joe90's topic in Bathrooms, Ensuites & Wetrooms
your body is @37 tho? -
Sewage treatment plants
dpmiller replied to Kerron Allen's topic in General Self Build & DIY Discussion
worth checking what you've got below ground, the "upright" designs might cause more of a problem if you've stone not too far down? -
China, not Germany.
Umm, self-regulating perhaps, but still getting to 65c. Might be a touch warmer than you really want? With Jeremy's option you get to choose how burny they are. -
13m distance from CU to cooker = poor design?
dpmiller replied to epsilonGreedy's topic in Consumer Units, RCDs, MCBOs
No, not you, the competent person engaged to design the scheme. -
Felt tipped pen limbo.
dpmiller replied to epsilonGreedy's topic in General Self Build & DIY Discussion
NI runs a separate system (that isn't searchable online) and our solicitor has alluded to about a year wait to receive docs back complete. -
Our solicitor likewise. And the new computerised LR system here is a bit of a nightmare apparently as the lines all "kinda" get superimposed. -
We are to be Approved! Happy Happy Happy. DMR.pdf
- 367 replies
- 3
- ireland
- timber frame
16mm tends to be cheaper than 15mm. And if required, you can get fittings to go 16-15 and 16-BSP.
dpmiller replied to Onoff's topic in Bathrooms, Ensuites & Wetrooms
that's what speed controls and dampers are for, never mind the duct losses. -
do you have UFH pipes?
