markc
    22
Everything posted by markc
  1. That looks to be a folded construction which would mean it is the same material inside and out,(this makes it easier and cheaper to produce) if marked 904 then it would be 904/904. 904/316 is made using two separate strips, harder to manufacture but slightly cheaper material for the outer layer. 316 is still marine grade and will not come into contact with flue gases so no problem
  2. He would need to apply for a working visa, explaining it will be just to work on your house and he will return at the end of the project. You will be his sponsor etc.
  3. Patio brush, basically a wire brush on a long handle.
  4. @sean1933 much clearer and i wasnt having a go (having re read my answer it didnt sound as i intended) working together is great, sadly as mentioned previously, a lot of the tradies like the site `crack` and banter with others and find it hard working on self builds. But there are those that take pride in their work and would love to be part of your project, just few and far between.
  5. Ask any tradesperson (politically correct garbage) and they will tell you their pet hate is having someone looking over their shoulder and checking/questioning everything they do. A good tradey will want to work on a price so they can get stuck in and make some money. Day rates are a sure fire route to boredom for good ones
  6. Chipping the surface crust is perfect, no need to wire brush. Gobbo will stick to most things without falling off. If you are worried, mix a little and stick it to an area. let it dry and then reassure yourself it has stuck. You are pointing some old stonework, not bonding fall arrest or structural members to the wall.
  7. Dont worry about how good compact foam is in compression. If we are putting a machine on a delicate floor we use compact foam under the outrigger pads. 400mmx400mm foam pads will support 3 tons no problem.
  8. The valves need to sit back from the surface, hence the boarding. and the arm screws into a bulkhead type fitting (not sure of the correct name for it)
  9. i would be careful to support the lower bend well because the fall will cause a hammer effect and could separate the fittings. also im not sure thats acceptable to have a vertical followed by horizontal inside the house.. someone else may be able to shed more light on the regs etc.
  10. If you are using 6x2`s 1800mm will be more than enough.
  11. The 45 degree slope and the lower one are both too steep, you risk having the solids stick in the pipe because the water will run too fast. 1:80 slope ensures the solids are carried by the water and they float along
  12. As above, you use nuts to secure the ply in pl;ace to mimic the base plate of the column. If you are still worried, put a piece of pipe insulation around each bolt between the ply and the bottom washer, when the concrete has gone off a bit take off the ply and dig out the insulation, then wiggle the bolts around a bit while the concrete is still green. This will give the necessary movement. This is how steel building are put up.
  13. If the floor was already tiled then no excuse, get him/her to put it right including the Island
  14. As the edge of the old slab is thin and has voids i would excavate under it a little way, lay the DPM under the old slab, Dill and fix shear keys (rods in resin will do fine) to prevent the slabs settling or becoming uneven, and then pour the slab so the concrete flows under the existing to support the edge.
  15. Common practice to set the units at the max height and allow a gap at the top of the kick board (allows for floor finishes to be laid without having to cut the kick board) and generally you never see this gap while using a kitchen
  16. Plywood drilled to match the bolt pattern. If you are not sure of getting it placed correctly then foam cones should be added to the bolts to give wiggle room for lining up later. the pockets are filled with grout later when the steel is fully fitted.
  17. Someone will buy it and yes the roller tracks and supports can look pretty ugly. Rollers are much neater but require more head room to install
  18. Slimline cisterns in thin walls are fine, wall hung pans and thin walls can cause wall flex ... broken tiles and mirrors etc. If the cistern+pan are close to a corner then its much easier to keep the wall stable. A couple of times ive had to double stud either side of the frame
  19. Im presuming they will be connecting into a main. If the main is within your boundary then you can excavate right upto it and just leave a metre or so spare curling up. If the main is in the street or road then you should stop your trench at your boundary and leave sufficient curling up to easily reach the main with some spare.
  20. 50mm water is no problem, yes the bend radii are larger but you will be surprised what it will go around. I dont know of any reason they cant be in the same duct
  21. +1 on the above
  22. Got to agree, the meter and billing may well be correct. Admittedly i didnt have variable rates but the APP showed i was using loads more power than i was and at very different times. But when i bill came it was correct to what i reckoned.
  23. The reduction in power station output is now being bolstered by stand alone generators housed in containers - makes no sense at all. A local company is churning these generators out as fast as they can produce them and tankers are going around constantly re-fueling them. All this waste and burning diesel just so they can say that power stations and being shut down.
  24. good morning and welcome, loads of info on here if you search the appropriate sections, failing that someone will answer most questions
