Everything posted by markc
Slimline water harvesting unit inside wall cavity?
markc replied to ashthekid's topic in Rainwater, Guttering & SuDS
Like many `green` ideas this sounds great in theory but the practicalities soon outweigh the benefits. All of the above points need to be considered, plus access for maintenance and inspection/cleaning/disinfection. -
No minimum, you just need to make sure the drip channel is clear of the render or cladding to allow drips to fall
Found a dead mouse in my shoe the other morning .... the D$%k Head, lazy, greedy ball of fur i live with has a death wish (P.S. this is a cat im talking about ... my GF lives in her own house).
Couldnt agree more, and yes we reckon it was a neighbor with a grudge who didnt like him parking the truck in his drive
Friend of mine who does garden and building maintenance started doing his own, council came round, stopped him, and charged him to put it back, then charged again for dropping it.
Very rarely a footing dig is prepared perfectly before a pour, quite often there are patches of loose stuff that either wasnt removed during the dig or simply falls in before the pour, not a problem with a thick mass fill but at only 200mm thick and 300mm wide these loose pockets or root pressure could easily cause the strip to break in several places. think of casting it as a plank and then only supporting it in a couple of places - jumping on it or simply putting it down a bit rough would break its back. Not a problem if the structure above is free standing like a wooden shed etc but a broken strip footing will permit a brick or block wall to crack. Either increase the footing size or put at least the recommended steel in, peace of mind is a good investment.
Why is the footing only 200mm thick? thats barely enough to support itself and i would be installing a full a full cage to hold a 300x200 strip together. Dont scrimp on the steel or you will likely see settlement cracks in the wall.
Garden Room - 4m flat roof span timber size issue
markc replied to Alex's topic in Garages & Workshops
6x2 timbers will be fine over 4m. If you want to go even thinner then 100mm zinc purlins (very light weight) will be ideal. As long as you didnt get heavy snow then 4x2 timbers could be used dependent on roof make-up and weight -
I think he is talking rubbish, unless he is looking at combustible materials above a cooker or appliance rather than the bottles
Ah, yes i see now. Temporary cover will be fine, just make sure its strong enough and restrained from shifting when knocked
@Gus Potter has nailed it from a structural and stability point of view
I must get around to getting something on paper .... screen. Ive build the subframe for the motor, coupling and Diff, bespoke drive shafts are next on the list
Guilty as charged (no punn intended), im on with converting a Lotus Esprit after too many break downs, non starting, petrol leaks, gearbox problems, clutch problems etc etc. Im looking at it being a useful toy as opposed to an unreliable, temperamental garage weight
Bricks missing & loose in loft party wall
markc replied to IndustrialWizarding's topic in General Structural Issues
a lot of old pit houses had communal loft spaces, some even had the electricity supply as two bar conductors running along a purlin with droppers to each house ..... needless to say that i saw a few instances of `jump leads` attached to the bar conductors and taken into the house before the electricity meter.- 7 replies
- loft
- structural
Far too many variables to give any meaningful answers. Post spacing depends on the materials for the walls and roof, fixing depends on the floor and post size/material and number etc etc
Thats ideal for fibreglass, if it was timber i would have gone with a flexible membrane
Welcome, High ceilings are good, old buildings with thick old stone walls (no cavity), uneven floors, no DPC under concrete floors etc etc etc. can be cold and hard work! ... but everything is do-able and someone on here will have seen it before.
How to fill large voids left from skirting board removal?
markc replied to Oxbow16's topic in Plastering & Rendering
4:1 will be fine, i would fill to almost level in one go, leave to go off and then finish to level. this will prevent sagging while wet -
What is the building construction? or at least the balcony floor? this will affect the choice of waterproofing
If you are dead against any form of skirting and finish is not important I would go for a sand/cement render mix and a a hard corner (piece of concrete lintel or steel) to prevent the exposed corner chipping off. Plaster wont stand up to the knocks from vacuums and sweeping etc. -
Are my slate vents installed upside down?
markc replied to AndyMT's topic in Roofing, Tiling & Slating
Got to agree with @BMcN -
Hello, from two Lake District Passive House wannabees
markc replied to LakeDistrictEugene's topic in Introduce Yourself
Welcome and sounds like an interesting project.
