Everything posted by markc
Couple of points to bear in mind 1) It is unlikely a flashing will be tight enough to the wall to draw water up. 2)The flashing (more upstand in this case) should be sealed to the horizontal surface and act as a tank.
Looks good, and traditional, in keeping with the property. well done. I hate cleaning up after grouting
Assuming its cast in concrete or cement/stone dust then 24 hours min, but 48 hours will be ideal - just be gentle with the edges until it fully cures
I would definitely get some specialist input regarding the amount of sunlight / shadow etc. The rear wall will be a feat in itself and not cheap. Underpinning is pretty straight forward but underpinning and forming the basement wall in one requires a lot of engineering
Practical starting point - v2
markc replied to Mulberry View's topic in General Self Build & DIY Discussion
Best way to teach yourself to drive a digger is to cover up the decals showing you which function/lever movement is which - this way your brain has to react to what you see and feel rather than what you are reading. If im teaching anyone i always cover up the `instructions` -
Difficult to say as it all depends on the amount of rain and airbourne dirt that will be washed down off the glass etc.
Small developments and self builds never go as planned, there are always details that wont work, clashes between trades etc. site works are flexible and can/will adapt as needs arise. Off site / pre fab requires every detail to be thought out and checked prior to fabrication and delivery. Sips Panels and kits are a bit different in that the supplier generally designs/details and erects their own product, but at a premium of course. It all really depends what you are wanting to achieve, fast build? reduced cost? etc etc.
Agree with the above, pre fab works brilliantly for hotel builds etc. and pre fab Dormers etc are great to fit and save loads of grief on site. But for a small development the pre planning etc just isn't viable
Same here!
Where in the Country are you? Most developers are having a hard time at the moment, material and labour shortages are making many smaller projects uneconomical
A cill pushed water away from the wall and allows it to fall. Flush fit windows are simple to seal but the staining down the wall can be horrendous.
Timber, Steel and Bricks/Blocks are all rising fast. China has closed a lot of steel mills to push prices up so structures and roofing systems will increase. Copper, so tube and cable are rising rapidly. and timber is in short supply worldwide. Luckily we are fairing much better than many parts of Europe because their material costs are going sky high.
Looks like you are confusing depth with area, or are you referring to depth on plan? as opposed to vertical depth? A larger area light well will allow more light in for more hours. Light wells are complex to get right, you need to look at orientation, shadow from other buildings, trees, fences etc.
I feel like giving up on the idea.
markc replied to Big Jimbo's topic in General Construction Issues
I feel for you, i am sick of seeing generic brick boxes being thrown up everywhere while MP`s score points talking about innovation, green issues and improving housing stock. South and West yorkshire - if you are a developer building boxes or a Gypsy you can have as much land as you want, self build? forget it. Can you imagine how far electric cars would have gone if finance companies wouldnt lend on them? mortgage lenders definitely need to come into the 21st century -
Had this conversation with someone the other day, they were under the impression once all electricity was from renewables then it would all be free because we don`t pay for the wind.
Porcelin tiles are much harder than ceramics and more difficult to cut. grinder and diamond blade are the best bet. If tiles are small and fairly thin then the cutter you have should be ok
Casting window cills on-site.
markc replied to epsilonGreedy's topic in Bricklaying, Blockwork & Mortar
istead of allowing the water to cling to the underside of soffit area and then into the wall -
No specific size for a drip groove, just needs to form drips -
When you say an old concrete slab, how old? is it insulated? UFH and old floors are not a good combination.
Tell us something we didn't know ...
markc replied to BotusBuild's topic in General Self Build & DIY Discussion
I would say thats a pretty fair report. Time to re open the steel mills, chemical plants etc and start making the stuff we need again. -
Pallet truck on a smooth concrete floor is fine, rough concrete, hardcore or even trackway and you have no chance
I was thinking the same as it seems only logical reason but you would think the plumber would have checked before or while replacing parts.
Im wondering wether the problem could be the shy lights and where they are putting water. Left had one will be taking a big hit from the down pipe. Im struggling to see any detail on the pics to see just whats going on arounf the skylights.
Working around standard sizes for a new build makes sense, but as you are converting, changing the hole sizes can be a pain and look terrible, thats unless you are intending making them much bigger anyway in which case head for standard sizes where possible.
if you are buying windows its the hole size, let them know it is the opening size and they will deduct an appropriate amount for fitting room.
