Everything posted by markc
Help Please - Glass Window Ledge - Too Big
markc replied to canalsiderenovation's topic in Windows & Glazing
Frosting is ok but as its toughened you have to be careful with the edges. at 8mm it will grind/sand down pretty quickly with a diamond plate -
In a manner of speaking es, but to make things easier/simpler/cheaper - build the box structure as a unit sitting on the walls, use either joist hangers or screw straight through as you have no access problems. Then when its all fixed and levelled (if necessary) use straps to secure the whole thing down to the walls
Is it toughened? if not then you can `sand` it down with a diamond sharpener. or rebate the opening it has to go into -
@Joe87 yes thats the idea.. Turn the whole roof into a box structure
Bonkers idea or a great idea?
markc replied to canalsiderenovation's topic in Landscaping, Decking & Patios
Im impressed ... and somewhat envious, secluded plot and canal frontage -
If you are using 9x2 joists, I would use the same as a front and rear beam with joist hangers. ( as opposed to sitting the joists onto a wall plate) You wouldnt need the post as the corner would be supported by the front member (sitting on the front wall) and the end joist (sitting on the end wall)
Storage Combi or not - advice and help please
markc replied to GraemeHM's topic in Boilers & Hot Water Tanks
MyGF has a small under sink electric water heater and it’s fantastic, I reckon it holds about 5 litres and perfect when cooking and hand washing -
Pre sealing is not a good idea for storage, you don’t want to seal the back where the adhesive will be and if you seal the top and edges but not the bottom them water uptake will be different and the tiles can cup. as nod says, remove any shrink wrap/polythene to prevent sweating and allow air circulation, a board over the top is fine. Dust won’t hurt them.
The one above is ideal, the other thing you need to consider is stability - does it turn a corner at the ends? will it be subject to high wind loads? likelihood of crowds or groups of people leaning on it? 20m and 2m high is a big surface to catch wind and will need something to stop it falling over as one big slab
Can i use a toilet without a flush plate?
markc replied to Adsibob's topic in Bathrooms, Ensuites & Wetrooms
No problem with using without the plate, finger or small stick to trigger the flush -
production manager said they were ok and that it's really difficult to get things perfect on their machine. Omg? the struts are either pressed in by a giant hydraulic G Clamp that swings around on a balanced beam, or they are tacked in place with a hammer and then the joist run through a big roller that squeezes them in. I would aim to start in the middle, use temporary braces to get the middle straight and held in place, then work outwards. Ideally, leave the braces in until you have to remove them to lay the floor.
Tools for cutting Fibre cement slates
markc replied to MikeSharp01's topic in Roofing, Tiling & Slating
Scribe and fold (similar to plaster board) for cutting, slaters knife/hatchet for trimming and shaping. Or you could use a grinder and diamond disc but the dust is annoying -
Insulating an existing loft room - guidance sought
markc replied to maznaz's topic in Heat Insulation
In that case i wouldn't worry about thermal bridging - although there is a cavity it will have loads of mortar and other stuff creating bridges. Nothing to stop you pulling down the plasterboard or even leaving it in place and adding insulation on the inside. Are the three rooms built as habitable? fire escape etc? -
I think its time to make a stand, do you know where they are based? go see them, knock on the door and sort it out
How old is the house? -
A pozi joist, truss, spine beam etc if supported on its bottom cord without restraint at the top will move and twist a bit. Nothing to worry about as the noggins will (should) put everything back straight. We soon found out that pozi joist packs need to be left banded or stacked flat if not being fitted straight away or the packs would decide to fall over if left unrestrained as the joists moved and twisted.
No need to sand - this was done on flat roofs to toughen up the surface and prevent stuff sticking to it .... birds feet etc.
Majority of builders/roofers would take the easy route and basically lay a flat roof but then a small area of fall local to the outlet, like a shower tray. Its not a big area of roof so if you work on the premise that some water will pool around the lanterns - with waterproof upstands. Saves a lot of work and expense putting all the falls in.
Lanterns are always going to obstruct falls in at least one direction. Your idea is great in principal but as you fear the builder is unlikely to follow it to the letter and you probably end up with a flat roof with a lowered outlet.
is this just how workers are, my 'high' expectations, or are they actually just being poor, and also the way forward. They are being unprofessional as a bare minimum, plus you are not allowing any wiggle room. Arranging follow on trades for the day after an expected completion is unrealistic. Paying them on day rates to disappear early etc is a breach of contract, Get hold of the owner of the company and point let them know whats going on (they may well be very aware anyway), keep good records of times etc. for later on. Dont burn your bridges too early.
Pumped waste design for kitchen sink and dishwasher waste
markc replied to Adsibob's topic in Waste & Sewerage
How deep/shallow is the sewer? If the kitchen floor level is 1300-1400 below road level, the kitchen waste would only be a metre or so below so you may be ok dependant upto length of run to get there. -
+1 on this, also door knockers on UPV sound bloody aweful.
Hello and welcome, First bit of advice - dont believe what you see on TV, their budgets and costs and make believe. That aside, have fun, DIY is all about learning.
